Everything posted by Mirabell61
Roel, Many thanks for the explaination of the appropriate Colregs chapter. I`m looking for my little can of Humbrol matt black already Nils
- 300 replies
- lightship
- Feuerschiff Elbe 1
Thank you very much Roel, I never heard of "Colreg regulations) before, . Good to learn something further and especialy with resp. to Nav .lights housng dull black backround. Good to learn something new for my modeling. You`re right, at this stage I can easily correct that. I looked up Colreg regulations in Google and found a listing of these regulations, but unfortunately not the passage where it stipulates the matt black neccesity to nav. lights containment background. Please could you kindly copy me that passage, if you found it there. Many thanks. I believe this is also of interest for fellow modelers as well. Nils
- 300 replies
- lightship
Mirabell61 replied to mtbediz's topic in - Build logs for subjects built 1751 - 1800
Hi Mustafa, excellent build, she is a beauty scratch model in progress ! Will you fit out rigging and perhaps even sails later on ? Nils -
Update this sequence is dedicated to the build of the wheelhouse, nav- and controlroom. Also the planked deck for the "monkey platform" is ready for mounting. The nav. light containments will be integrated in to the wheelhouse railing panels Nils brass windowframes ( square-tube) are fitted in, tight fit the wheelhouse walls are from 0,8mm ply mounted to the framework section is painted and the monkey plattform deck has dryfit The "glassing" of 18 windows silicone glassing bits pressed in, tight fit into the window frames the "monkey plattform" deck will be permanently glued on, when the wheelhouse section is screwed down to the boats deck
- 300 replies
- lightship
Hi Keith, there is no particular reason, the reason is just, that I was looking for a way to do the window frames. Using squarebar tube it worked well with my Ergenstrasse, The brass squarebar is 1 mm thickness, in scale that would simulate the windowframe dimensions so here it goes again ...... for small scale ( etc 1:160) an alternative is to fix approriate slide guides on the inside of a window front and then slide in one an acrylic stripe that covers all windows simultainiously That is completely without any glue and a clean job. I used that version on my "Kaiser Wilhelm der Grosse" model Nils
- 300 replies
- lightship
Veszett, The brass square tube was easy to get, but it looks that my supplier for 6 x 6 mm silicone rod has run out of stocked material. Fortunately I still have enough left from my Ergenstrasse. The other flat sides with theire window outcuts will be easier to make Nils
- 300 replies
- lightship
thank you very much John, I`ll take off the wheelhouse now (screws) and do the remaining sides. The six preliminary pillars of the frame will stay in place until the sides are all closed and then cut away. Nils
- 300 replies
- lightship
Hi Veszett, I refrained from using flat transparent polysterol or food containment packages because its too messy with the glueing in, and CA leaves sometimes leaves a nasty stain. I`m quite happy with the methode I described, also the silicone is translacent (semi transparent), so I need not worry what the inside of the appropriate superstructure looks like, I do`nt have to fit it out Nils square silicone bar 6 x 6 inside a 8 x 8 square brass tube, sorry for the rather poor photo quality mounted it would look like this (second from left window )
- 300 replies
- lightship
Thanks for your words Uwe, all the coming items are being built from pictures as good as I can I found a solution for finding the "lost" anchor cable in the closed hull, and to secure it. I`m currently trying my luck with the wheel- and nav house from 0,8 mm ply, I´ll try to do the square windowframes like already done once for the "Ergenstrasse", which has the same scale. Its a bit more tricky and fragile here in order to bring 8 windows over the limited wheelhouse breadth Nils a hole was drilled into the forecastle bulkhead, the "lost" achorcable of the hall anchor fished through this hole and secured with a wooden stopper. This lays between bulkhead and its cover item. Paint touchups pending later on the arrangement for the waistdeck fastenings of the mooring cable made a little framework for the wheelhouse sides. A wooden spacebar provides for the right height afterwards there are panama fairleads to prevent dammage to the railing the framework is fastend to the boats deck with screws so that it follows the decks sheer a card template for making the front window front, the other sidewalls will be done likewise the windowframes will be made from brass square tube, the glassing done later with square extruded semitransparent silicone bar
- 300 replies
- lightship
You`re right Veszett, thanks for your input .... unfortunately I had no oportunity to vist the real ship yet and take my own photos, so that my orientation comes from other models built by other skilled modelers. I`m pleased with my own version. There is a white skirt outside around the decks length, that would incorporate the decks hight with the aft section, in fact it would narrow the sight on to the decks house from the side I`m including 3 pics from other well built models from master builders Nils this is a model of Horst Henryschowski (the deck is laying on the aft section model of Helmut Thomas, which is my favorite benchmark Model of Helmut Thomas the real thing moored at Cuxhaven. The white tent on top is for visiting guests only, since the ship is out of duty
- 300 replies
- lightship
Thank you Rick, I am pleased that you are following and that you like it. Yesterday I mounted the boatdeck supports on stb. side, it will take some minor paint touch up, also the underside of the deck at the glueing points after also the port side supports are on Nils
- 300 replies
- lightship
Many thanks Uwe and John, for your words Nils
- 300 replies
- lightship
Thank you Keith, yes, I bought a bunch of longer and broader rubber bands some time ago and now they come good to use. The light mast (till unfinished) was one of the first parts I started with. There will be a ladder from boats deck to the light platform later on. That will be quite tricky to solder .... Today I closed the long deckhouse with the deck on it, and first made a pic of the last possible look into the hull. The moment the deck was glued on I realized that the cable from the hall anchor was only prefixed with a tape, so I have to find a solution for fixing the cable permanently, because I had unfortunately forgpotten to do so Nils last look into the hull. here one can see the cable I had forgotten to tie to the frames or somewhere else. Also the turnbuckles can be seen. Bollards and Panama fairleads are also mounted on foredeck and along the long deckhouse the chain end (of mushroom anchor) coming from the front bulkhead (on deck) is going to be fastened to the spring loaded buffer element the underside of the boatsdeck is painted except (taped off ) for spaces where the supports will be fixed and the deck to be glued on to the superstrcture below
- 300 replies
- lightship
Update made the boat`s deck and planked it, also coming for edges and aft stair outcuts. The fastening points (turnbuckles) for the mast stays were mounted. It would be difficult to mount the bottlesrews after the deck is on. The blanc patches on the deck in the areas for the boats will be plated with a profiled anti slip layer Nils the card template for the boats deck start with the planking. Deck and planking strips are both 0,8mm thick, so the total thickness is 1,6mm. That is flexebil enough for sheric bending down when glueing it on. measures to bring the curvature into the deck supports will be mounted (10 on each side) between deck and bulwark
- 300 replies
- lightship
many thanks Roel and Keith, I learned a lot from your input with ref. to duty on lightships Nils
- 300 replies
- lightship
Hi Roel, the propulsion was done with a 650 PS MTU / MAN diesel engine Nils
- 300 replies
- lightship
Hi Keith, acc. to the techn. data of the Elbe 1 there was a 12 head crew, but i also unfortunately do`nt have any information for their individual tasks. Probably in duty-shift operation at a time there were 6 on duty and the other 6 had free time, (or on stand by). The Elbe 1 is (was) the largest German lightship ever. Nils
- 300 replies
- lightship
congrats Kevin, your Hercules is a very fine tugboat, well done, also thanks for your conclusion notice Nils
Thank you Phil, for your input, I took a look at the Columbia WLV604 lightship per WW-web. A nice Vessel, perhaps we shall see a model of her here at MSW someday. Nils
- 300 replies
- lightship
many thanks for your words Andy, you`re right, I also sometimes make a decision on a certain build sequence and start preparing to the intended thing, but after thinking it over twice I recognize that if I would do so, there is no more access to an item that lays behind or under the section I`m planing to do. So foot on the brake before continuing. For example, before the boatsdeck is placed, I have to make sure that the ship`s bollards are near to the appropriate fairleads and the footpoint-fastening positions of the lighttower stays are placed so that they do`nt interfere with other items, and that the stairs to the boats deck are clear form what is to be mounted items above later on. For mounting the boatsdeck to the long deckhouse and to install a number of supports along the length, I decided to make a bunsh of wooden supports which have slight overhight so that the can be tuned to precise fit when mounting. In this case I refraigned from making a brass framework to mount on. Nils these are the 20 wooden supports for the boatsdeck. 2mm pine squarebars with ply-knees a template for the boatsdeck, for evaluating positions etc. the boatsdeck has a shere and a longitudinal curving. The standovers (port and starboard side ) need to be supported and fastened to bulwarks below and deck above. Before that the 0,8 mm ply deck needs to be planked, like the main deck below. All must be in accordance in what I wrote in the beginning of this post
- 300 replies
- lightship
