Mirabell61
Everything posted by Mirabell61
  1. Thank you very much Peter, and for your kind words I`m pleased that the Gorch Fock has inspired you to do the model Nils
  2. Uwe, many thanks for your input and your words Relating to the lightscreens I asume that during its duty the ship was updated acc. to Colregs, and after Roels comment I looked up the color of the sheets (photos) on the real thing, it looks like they are realy matt black, and the ship was on duty and on position until 1988. for me it was always clear that the lightscreens would be red /green because I thought the color would increase the illumination of the nav. lights, also I never heard of the Colregs regulations before. Now my decision is to go for matt black. Nils
  3. Roel, Many thanks for the explaination of the appropriate Colregs chapter. I`m looking for my little can of Humbrol matt black already Nils
  4. Thank you very much Roel, I never heard of "Colreg regulations) before, . Good to learn something further and especialy with resp. to Nav .lights housng dull black backround. Good to learn something new for my modeling. You`re right, at this stage I can easily correct that. I looked up Colreg regulations in Google and found a listing of these regulations, but unfortunately not the passage where it stipulates the matt black neccesity to nav. lights containment background. Please could you kindly copy me that passage, if you found it there. Many thanks. I believe this is also of interest for fellow modelers as well. Nils
  5. Hi Mustafa, excellent build, she is a beauty scratch model in progress ! Will you fit out rigging and perhaps even sails later on ? Nils
  6. Update this sequence is dedicated to the build of the wheelhouse, nav- and controlroom. Also the planked deck for the "monkey platform" is ready for mounting. The nav. light containments will be integrated in to the wheelhouse railing panels Nils brass windowframes ( square-tube) are fitted in, tight fit the wheelhouse walls are from 0,8mm ply mounted to the framework section is painted and the monkey plattform deck has dryfit The "glassing" of 18 windows silicone glassing bits pressed in, tight fit into the window frames the "monkey plattform" deck will be permanently glued on, when the wheelhouse section is screwed down to the boats deck
  7. Hi Sterlingclements, beautiful and excellent built "America". I love the sights into the ship Well done !! Nils
  8. Hi Keith, there is no particular reason, the reason is just, that I was looking for a way to do the window frames. Using squarebar tube it worked well with my Ergenstrasse, The brass squarebar is 1 mm thickness, in scale that would simulate the windowframe dimensions so here it goes again ...... for small scale ( etc 1:160) an alternative is to fix approriate slide guides on the inside of a window front and then slide in one an acrylic stripe that covers all windows simultainiously That is completely without any glue and a clean job. I used that version on my "Kaiser Wilhelm der Grosse" model Nils
  9. Veszett, The brass square tube was easy to get, but it looks that my supplier for 6 x 6 mm silicone rod has run out of stocked material. Fortunately I still have enough left from my Ergenstrasse. The other flat sides with theire window outcuts will be easier to make Nils
  10. thank you very much John, I`ll take off the wheelhouse now (screws) and do the remaining sides. The six preliminary pillars of the frame will stay in place until the sides are all closed and then cut away. Nils
  11. Hi Veszett, I refrained from using flat transparent polysterol or food containment packages because its too messy with the glueing in, and CA leaves sometimes leaves a nasty stain. I`m quite happy with the methode I described, also the silicone is translacent (semi transparent), so I need not worry what the inside of the appropriate superstructure looks like, I do`nt have to fit it out Nils square silicone bar 6 x 6 inside a 8 x 8 square brass tube, sorry for the rather poor photo quality mounted it would look like this (second from left window )
  12. Rudder chain device is great Valeriy, obviously it was not hyraulic operated yet Nils
  13. Thanks for your words Uwe, all the coming items are being built from pictures as good as I can I found a solution for finding the "lost" anchor cable in the closed hull, and to secure it. I`m currently trying my luck with the wheel- and nav house from 0,8 mm ply, I´ll try to do the square windowframes like already done once for the "Ergenstrasse", which has the same scale. Its a bit more tricky and fragile here in order to bring 8 windows over the limited wheelhouse breadth Nils a hole was drilled into the forecastle bulkhead, the "lost" achorcable of the hall anchor fished through this hole and secured with a wooden stopper. This lays between bulkhead and its cover item. Paint touchups pending later on the arrangement for the waistdeck fastenings of the mooring cable made a little framework for the wheelhouse sides. A wooden spacebar provides for the right height afterwards there are panama fairleads to prevent dammage to the railing the framework is fastend to the boats deck with screws so that it follows the decks sheer a card template for making the front window front, the other sidewalls will be done likewise the windowframes will be made from brass square tube, the glassing done later with square extruded semitransparent silicone bar
  14. You`re right Veszett, thanks for your input .... unfortunately I had no oportunity to vist the real ship yet and take my own photos, so that my orientation comes from other models built by other skilled modelers. I`m pleased with my own version. There is a white skirt outside around the decks length, that would incorporate the decks hight with the aft section, in fact it would narrow the sight on to the decks house from the side I`m including 3 pics from other well built models from master builders Nils this is a model of Horst Henryschowski (the deck is laying on the aft section model of Helmut Thomas, which is my favorite benchmark Model of Helmut Thomas the real thing moored at Cuxhaven. The white tent on top is for visiting guests only, since the ship is out of duty
  15. Hi HALLPHNK, nice paintings, but in the first pic its the first time I see a squarerrigger sailing backwards and the top flags are in wind direction Nils
  16. Thank you Rick, I am pleased that you are following and that you like it. Yesterday I mounted the boatdeck supports on stb. side, it will take some minor paint touch up, also the underside of the deck at the glueing points after also the port side supports are on Nils
  17. Thank you Keith, yes, I bought a bunch of longer and broader rubber bands some time ago and now they come good to use. The light mast (till unfinished) was one of the first parts I started with. There will be a ladder from boats deck to the light platform later on. That will be quite tricky to solder .... Today I closed the long deckhouse with the deck on it, and first made a pic of the last possible look into the hull. The moment the deck was glued on I realized that the cable from the hall anchor was only prefixed with a tape, so I have to find a solution for fixing the cable permanently, because I had unfortunately forgpotten to do so Nils last look into the hull. here one can see the cable I had forgotten to tie to the frames or somewhere else. Also the turnbuckles can be seen. Bollards and Panama fairleads are also mounted on foredeck and along the long deckhouse the chain end (of mushroom anchor) coming from the front bulkhead (on deck) is going to be fastened to the spring loaded buffer element the underside of the boatsdeck is painted except (taped off ) for spaces where the supports will be fixed and the deck to be glued on to the superstrcture below
  18. Update made the boat`s deck and planked it, also coming for edges and aft stair outcuts. The fastening points (turnbuckles) for the mast stays were mounted. It would be difficult to mount the bottlesrews after the deck is on. The blanc patches on the deck in the areas for the boats will be plated with a profiled anti slip layer Nils the card template for the boats deck start with the planking. Deck and planking strips are both 0,8mm thick, so the total thickness is 1,6mm. That is flexebil enough for sheric bending down when glueing it on. measures to bring the curvature into the deck supports will be mounted (10 on each side) between deck and bulwark
  19. many thanks Roel and Keith, I learned a lot from your input with ref. to duty on lightships Nils
  20. Hi Roel, the propulsion was done with a 650 PS MTU / MAN diesel engine Nils
  21. Hi Keith, acc. to the techn. data of the Elbe 1 there was a 12 head crew, but i also unfortunately do`nt have any information for their individual tasks. Probably in duty-shift operation at a time there were 6 on duty and the other 6 had free time, (or on stand by). The Elbe 1 is (was) the largest German lightship ever. Nils
