Everything posted by John Ruy
- 204 replies
- marine model company
- charles w morgan
A few paint layers and some sanding she now has canvases roof tops. Decided to stay with yellow ochre vs white based on what I could see of the hurricane house roof in this photo taken in Boston Harbor. Bob, I did find an example of white oxide painting on this model in the Mystic Museum. This model looks to be depicting very early in her career. Besides, I didn’t want to repaint the bulwarks at this point. So that was a great detour and distraction from rigging, but now it’s time to get back to tying those tiny tiny rat lines. cheers 🍻
- 204 replies
- charles w morgan
The kind can of worms we like. Have great vacation. I agree on the smooth top. 👍
- 204 replies
- charles w morgan
This makes a lot of sense, however I think I’ll stay with what I have. I may go back and lighten up my roof tops with a few coats of lighter ochre to give it a sun faded look. This time I’ll let the scribing on the decking fill in a bit to look more canvas covered. Thanks Ron for asking the question, thanks Tom for adding to the discussion and thanks Bob for brining our modeling world to life. Ron, I am Looking forward to seeing what you do with this on your MS CWM. cheers 🍻
- 204 replies
- charles w morgan
Thank you Bob for your knowledge. Covering is what I suspected... That covering at my models scale would basically be the paint used. In this case would I be correct in assuming the covering would have been painted yellow ochre? 😎
- 204 replies
- charles w morgan
These drawings are very interesting in that they show planking to be used for the “top and sides” and yet state the top being canvas covered. My plans were drawn in 1939 and have no mention of the canvas. It looks to me to be depicted here as a covering over the deck planking. 🤔 I think your correct, more research needed. Example my plans show Gallis Roofing over the Tri Works, where MS instructions actually state the Tri Works roofing was removed during the 1983 restoration. Fact remains these great ships were working ships the evolved over time. We just have to pick a time in their history to depict. Still very interesting... One things for sure, it’s all an individual work of art no matter how we decide To build it. 👍
- 204 replies
- charles w morgan
In my research I have not come across anything indicating canvas roofing. I took another look at my vintage plans. This is the only note regarding roofing. The roofing is to resemble planking. The plans also indicate to place the rope tubs for the whaleboats on the hurricane house roofing. That said I also have not seen any models representing a canvas roof on the hurricane house. This photo is from one of my resources https://www.charleswmorganmodel.com/ Let me know if you come up with any historical reference for a canvas covering. We could use sail material over the planked roofing to represent that look. cheers 🍻
- 204 replies
- charles w morgan
They look great, too bad they will be under the roofing. Kind of like that great helm you built. But then we don’t do this for others to see, as much as to know ourselves it looks good. They look good. 👍
- 294 replies
- charles w morgan
- model shipways
Progress on the Upper Fore Stays. Switching to sewing thread. Really getting small/tiny More later... 😎
- 204 replies
- charles w morgan
Fore Shrouds completed with battens. Well worth the effort to tie them rather than simply glue them on. Magnification Required... Trimmed up nicely. Tip be sure the fabric glue is dry on the knots before cutting. Onward...😎
- 204 replies
- charles w morgan
Looks great Ron. Your Helm came together nicely. 👍 Model Railroading fixtures is a great idea for the doors.
- 294 replies
- charles w morgan
- model shipways
Final coat of White Acrylics on the hull. Page 78 of 130 completed in the very detailed instruction booklet. Great kit for developing those micro carpentry skills. 😆🍻
- 104 replies
- model shipways
- new bedford whaleboat
Finished remaining ceiling planks. Rubbed on a bit more yellow ochre to match things up and gave the planking a coat of Varathane Clear (satin) to seal it. Thanks for your comment Ron, the details in this kit are just beginning. 👍
- 104 replies
- model shipways
Ceiling planks next to the stern and bow sheets have a good amount of twist in them. Requires some creative clamping. Bow sheets complete... Centerboard case constructed and installed. Centerboard also installed Cut and prepared ceiling planks for staining. Varathane weathered gray. Ragged on, not brushed. Rubbed in Yellow ochre to give the planks some highlights. Sanded with 150 grit to rough give the planks some worn/used appearance. Followed that with another rub of weathered gray varathane. Glued down ceiling planks starting from the centerboard our. Then cut to fit the center plank. Remaining ceiling planks will need to be trimmed carefully to fit tightly. Latter 😎
- 104 replies
- model shipways
Plan on lots of time. I am using scribed decking sheets to cut out battens and lashing them down. Definitely need good eyes or a lighted magnifier. Maybe both... 😆
- 204 replies
- charles w morgan
Stern Sheets and Ceiling installed. Feeling good about the appearance of grayed out planks. 😎 On to the bow sheets. 👍
- 104 replies
- model shipways
Reconstructed the Gallis Framing on the Aft Roofing. Looking much better... Added battens to the Fore Mast Shrouds still need to lash them. Painful detail, but it’s what I live for... Onward and forward, it’s how we progress. 😎
- 204 replies
- charles w morgan
Installing the Thwart Risers and Adjacent Ceiling is very tedious. Decided to nail these in place using Lill Pins as opposed to the copper etched nails in the kit. Used CA glue on the nails, flush trimed them from the outer hull and repainted. First Ceiling Plank in glued only no nails. These are due cut and fit pretty good, although they do require a lot of coaxing and clamping. Also placed the timbers for the stern sheets, another tedious task to get level and flat. On to the bow sheet framing and finishing the ceiling. I decided to keep this planking all natural and will be representing nails with the lead from the tip of a 9mm mechanical pencil and finishing with non-gloss clear coat of some sort. Any suggestions for the sealer?
- 104 replies
- model shipways
Thanks Gunther, I just might take you up on that. It is probably close enough for the direction, I have the correct drawing for the detail. I can also look at all of the great direction I get from the build logs here. I’ll let you know if I don’t find the actual Peterboro manual, before you go to the trouble. Thanks
Finished sanding and painted the hull today. Proceeded with setting nails and decided I didn’t like where this was going. Took another look at this photo graph taken last year in Mystic and decided the nailing was not visible in reality and was not enhancing my models presentation. I removed the nails I had set, filled the holes and repainted the outer hull. The Third brush coat looks great. Inner hulls came from the builders with a coat of buff paint. According to the instructions the shade varies with the builder. I used my custom yellow ochre and mixed in white to give it a more buff look. I am thinking I will use the yellow ochre for the inner planking to achieve the appearance of the Whaleboat I saw in Mystic. Onward. 🍻
- 104 replies
- model shipways
Framing the hull completed. Quite the process, given it’s my first time bending and laminating timber. Looks decent... Hull fastenings? To nail or not to nail, that is the question. I am hoping I made the right decision. I decided to jump in and nail it! This should be an experience, to say the least. I hope it pays off. I will be painting this hull and the nails should add the desired detail and realism I am hoping to achieve. I am just hoping it doesn’t drive me over the edge. 😆 should be done with this step by Winter. more latter. 😎
- 104 replies
- model shipways
I’m back to the New Bedford Whaleboat. Internal hull now marked and secured in the mold for framing. Framing timbers are soaking so they can be fitted and glued into the hull. I will begin framing the hull tomorrow. Latter 😎
- 104 replies
- model shipways
