Posts posted by acaron41120
Quick question on using sanding sealer. I have used it many times on ships whose hulls are painted with great success. But I'm unsure if I should use sanding sealer if I am staining the wood. I'm afraid that if I used sanding sealer then stained the wood, the stain would NOT soak into the wood s it should. Am I correct in my thinking?
My neighbor lost part of his pecan tree. The only thing left was a 4 ft piece of the trunk which was in good condition. He cut that down and ground the stump. He knew I build wood model boats and asked if I wanted it. I said sure and have it in the back by my fence drying out. Now for my question. Is pecan a good wood to use in making a model boat? I have the plans of the Bluenose and I would like to try my first scratch build of the ship using pecan. What say ye master builders?
Did the ships cannons on the starboard side line up directly across from the cannons on the port side? Also were the cannons set the same on a frigate/man-o-war located the same as say the Mayflower or Santa Maria etc.? Were they located that way from country to country or did it depend on which country built the ship? I've checked several model plans and Google and come up with everything lined up across from each other. Wanting to add some authenticity to my kit. Thanks for your help.
Question on the hatches for the gun ports on a 16th century ship. Well all ships I guess. Did the hatches that covered the gun ports fit flush inside the port opening or did they overlap the opening a bit? Couldn’t find anything specific in any material I have. Thanks in advance for our assistance.
Just wondering if there is a tool maker that makes a tool similar to a punch that would cut the square holes in the gratings contained in kits. I don't want to create a new way of doing things but it would be nice to take the grating in the kits and be able to punch out the holes in the gratings rather than using a pin vise and swiss file to square the round hole. Thanks.
I understand how the ship’s anchor rope is tied off at the anchor but not back at the capstan. Was it tied off near the base of the capstan and then wrapped around and out through the hawse hole to the anchor or was it tied off to a separate eye? Just getting ready to add a few finishing touches prior to installing the top deck. I guess the question of the rope tie off applies to all the capstans. Thanks for you excellent help.
Showing my ignorance with using planes here but if I understand correctly, I start with a square piece of wood stock that's almost the correct size of the mast; ie. 8mm round; then cut down the square piece to the correct size and then finger plane it until close to round and finish by sanding it round. What about starting with a square piece, cut it down do the correct size for the top of the mast and from there insert it in my drill and use the drill like a lathe and sand it round using my sanding stick? I think I'd feel better doing that. Would that work?
What is the best method of cutting the top portion of a mast square? I do all my building using hand tools and I've managed it but it was very difficult. I have used single edge razors and Exacto knives followed by sanding. What do you experienced builders do? Thanks in advance.
Thanks for the help. I think I'll set the lanteen sail on the mizzen mast and the top sails on the main and fore masts and have the rest of the sails furlled.
- Louie da fly, mtaylor and Knocklouder
- 3
Quick question (hopefully). When a ship of the 1500s etc. left the port, which sails were set? I don't imagine all sails were set. I would like to set the sails on my Mayflower the same way. Thanks in advance or the help.
- BLACK VIKING and mtaylor
- 2
Thanks for all your help. My kit of the Mayflower does not have much detail...mainly decks, cannon ports (sans cannons) and two lifeboats. I want to add a little detail to my build. Even though you can not see the stove or pipe, I might add at least the pipe through the forecastle just to port of the grating. I will add a capstan but just aft the main mast. So far I have replaced the plastic pieces in the kit by making those pieces out of wood (the beakhead was a real pain).
Does anyone building or has finished building the Mayflower know where the binnacle, capstan(s), stove and water pump were located on board? Thanks in advance for any thoughts or where I could go to find out.
- Keith Black and mtaylor
- 2
Finally almost done with the hull of my Mayflower. Going with the recommended color scheme of white below waterline and a dark color stain on the rest of the hull. So 1st question. What color stain do most modelers use? I see a lot of beautifully stained models but haven a clue if they are dark oak, walnut, mahogany or whatever. 2nd question. Is it possible to mix stain colors to get the color you want? For instance mixing Minwax dark oak with Minwax light maple, etc.?
I'll have to bring out my Nikon and use that for posting photos. I like it better anyway. Thanks for that info.
While scouting the different build logs I came across a NRG Half Hull Planking Project by T Livine and decided that I should get this and learn the proper technique. After receiving this tutorial kit I did my usual kit inventory and all was well. The bulkheads are thicker than what is normally found in the kit and that in itself makes the fairing (shaping) of the hull easier AND it gives more surface for the planks to adhere to the bulkheads. So without further ado, I begin. Pictures will be aded at the end of this segment.
Following the instructions I attached the the plan to the building board (1/4 inch foam board) purchase from our local craft store. Then I carefully removed the parts for the beginning of the build. The stem post, keel, keelson, stern post etc. and dry fit them all on the plan. The slots in the keelson for the frames were cut a little narrow which allowed for a better fit after some slight sanding. Then came the first of my worries...the rabbet. Kits usually don't have nor do they mention a thing about cutting the rabbet. I thought of trying it on my Mayflower build but not knowing enough I refrained from trying its until I learned the correct way. This kit was great at teaching the proper way to cut the rabbet. I wish I had known about this kits for my other builds. After reading and re-reading the method in the tutorial, I carefully marked the rabbet and used a small file to carve it out. I think I did a fairly good job of it.
I then removed the frames from the supplied sheets and sanded off the char so the frames could be glued. Did you know that glue doesn't hold well on the areas with char from the laser cuts? I didn't! Starting with the first three frames, I had to file just a little off of one of the slots in the keelson for the frame. It took me three days to get all the frames mounted to the keelson and now I have to add the supplied spacers between frames for stability and strength. Next thing will be to mark the bearding line and remove the deadwood below and aft of it.
Well stay tuned. I'll add the missing photos when I figure out why they won't post here. Until next post....build on!
Dry fitting the keel, keelson and stem post.
Marking the Rabbet on the Keel and Keelson
After twisting my knee working outside, I finally got back to the planking tutorial. I tackled the bearding Lind, deadwood nd most of the remaining frames. I still have a few remaining frames and the transom to take care of before I start fairing the frames. This time I won't have the false deck to help me get the shape correct but this IS a tutorial right! These next photos are where I am in the build now. Somehow the last photo wants to upload upside down.
Many of the articles and tutorials I have read talk about kits not having enough bulkheads. Indeed, many of my kits certainly could have used a few more. Which leads me to my question. How does one make additional bulkheads? For instance, if I am adding a bulkhead between No. 3 and 4, how do I know the shape of the added bulkhead? It seems that it would be wider than 3 but less wide than 4. What would someone use to get that width or is it just a shot in the dark and hope for the best. Any thoughts from you more experienced modelers is greatly appreciated.
Question on Sanding Sealer
in Painting, finishing and weathering products and techniques
Posted · Edited by acaron41120
Thanks everyone. I will continue on using the method I have been using as it turns out it was the correct method. I usually sand and fill using the sawdust from sanding with a mixture of the sawdust and glue which works much better than sanding down the commercial fillers that just don't seam to sand down enough. Before painting, I use a tack cloth and then add one light coat of sealer and follow up with the color of choice for my particular ship. For Mayflower, and the Golden Hind I will stain the hull with a quality stain and then paint from the waterline down flat white.
Again thanks everyone for your help.
