joep4567
Posts posted by joep4567
- GrandpaPhil, Cathead and mtaylor
- 3
- Mike Zoll, GrandpaPhil, mtaylor and 2 others
- 5
- Ryland Craze, Cathead, GrandpaPhil and 2 others
- 5
- Ryland Craze, Cathead, mtaylor and 1 other
- 4
when in doubt put a rock on it!
- FriedClams, mbp521, mtaylor and 1 other
- 4
- leclaire, Ryland Craze, mtaylor and 2 others
- 5
- GrandpaPhil, mtaylor and Cathead
- 3
- Cathead, mtaylor and GrandpaPhil
- 3
- mtaylor, GrandpaPhil and Cathead
- 3
I decided that maybe the correct approach was to make the paddlewheel and then design the hull opening around it. I came up with what i thought is a suitable diameter and draw up a pattern to follow. The first step was to cut out the hubs followed by milling the spoke pieces. Using the pattern and a jig i assembled the spokes for the first wheel. Three more to go. The wheels will be mounted on a 3/16 shaft.
- GrandpaPhil, Ryland Craze and mtaylor
- 3
- 3
It would help me if someone with the Chaperon would give me the dimensions of the recess for the paddlewheel.
I'm currently building a Revolutionary War brig and it is coming along ok but i have watched some threads on paddlewheel kit construction so i ordered some Chaparon plans to get me started. My thinking is that in the event i tire of one i would switch to the other for a while. Anyway I thought i might be able to scratch build this one. The idea is not have what is historically accurate but rather a representation of the period in general. I would really like input from other folks on what i'm doing as i have no ship building experience. I decided to try another method of hull construction as opposed to planking because the flat bottom lends itself to another. I used the full scale keel plan from the kit and made to sides with the intent of a flat plywood bottom. I rabbited the sides for the bottom and rounded over the exterior sides.
- mtaylor and GrandpaPhil
- 2
Chaperon by joep4567 - 1:48 - Sternwheeler
in - Build logs for subjects built 1801 - 1850
I decided that I needed to plank the sides of the hull for authenticity.
