Jeff59
NRG Member-
Everything posted by Jeff59
Finished the jackstaff using finer tube and bracing wire, bit more to scale when you compare to photos of ship. 👍 even got the chrysanthemum painted and fitted, it’s now a Japanese warship 😂 finally l am trying to add small chain for securing the anchors, 42 links to the inch smallest l could find so kind of works 50 links to inch would be better if you can find it ? This is a lot more fiddly than l was expecting, worth it ? Done one and dragging my feet to do the other two. That’s me for the moment, shall push myself forward 🤛
Also tied in the rigging from here up to mast, used 0.2 wire on the heavier cable at lower point but after painting wasn’t happy, looked too heavy so removed it and used 0.1 wire instead, this worked for me, reason for wire rather than lycra was the wire gives a slight sag when you get it the right length, again a lot of care needed as it’s easy to knock and damage things at this stage, which is what l did 😡 more of that French language, once calmness resumed fixed everything and happy again. 😂 used my trick with using photo etch on ends of wire and Lycra again, ok.
Could see from previous builds that the bow rail number 1 was an issue with the jackstaff same as stern so opted to this before handrail, worked out well 👍 also noticed how it’s strange when the brass etch is on the model it looks larger before painted, seems to look more delicate after paint applied.
Fitted these to model before doing the railings around the anchor mounting points, these railings aren’t as straightforward as you would think so take care here, keep checking when you’re bending them , they do fit spot on eventually.
Short update on progress guys, seems a lot of work with not much difference, just about there with forward deck area details. Finished reworking the anchors, good to get that out of way, that let me paint and fit to model with chains.
I am so impressed with your Portland project, could l offer to put my name down for first one of you produce 👍 Do have a model of knorsk Love to build in my collection, a rather nice two decker and also like Joe Tika’s model of HMS Victory, so not adverse to biting of more than I can chew. That does look awesome though. Well done, like that enough to take it on. 🤛
Thanks, had a look at your project, awesome, know how much work goes into works like that 🤛 have a laugh, here’s one I started in 1982, Le hussard, promise to finish it some day 😂
Bad news for you Herby, it’s two shades of grey 😂 well one is Tyre Black but really a dark steel grey. But I know exactly what you mean. 🤛
That’s me for a bit, have to back track and see what l did with the anchors earlier in build and do the next two. 👍 take care guys, shall return when l have some more progress. 🤛
The part of railing removed for this then gave me the stanchions for folding down on side of ship. 👍 the 0.1 wire was cut about 16.5 mm and a very slight curve added, this was then fed through the small hole in superstructure and rested the other end on rail, added a touch of glue and then nudge wire into place. Plenty coats of paint till you think it matches the thickness of the etch railings 🤛 better than going to 0.2 wire and it looking heavy. 👍 still to finish painting these yet. Next part l have done is fitting an anchor and chain made ages ago, this is the spare anchor that is not connected to the capstans, bit of a blind one on this part of build, no photos or references to go on, so again this is just my solution, feasible though, you would just swap the chains over the capstan next to it, think that would work. Even the ship today doesn’t show this or indeed the heavy bosses further forward, bit of a dark horse this one. Last photo shows Mikasa at anchor, used this image as reference for the chains on the side.
Another thing l noticed when browsing through photos of Mikasa as she is today, were the two small hooks on side of superstructure, l am totally guessing on them being for the rail chains after the gun shields lowered for operation of the guns in action, well at least they are right height and position for this to work, totally my choice to do model this way, doesn’t mean it’s right but works for me. Had to mark and drill two holes through side of bridge to let wire pass through. 0.3 or less for 0.1 wire.
Take care when doing these rails, no extra ones in the box, indeed l had made some of the rails here ages ago, one must have fallen on the floor and didn’t notice in time, Jacqueline came in and stood on it, didn’t tell her though, she turned it back to IKEA, flat pack with a few extra kinks, unsalvageable 😂second set to the rescue 🙄 Once the rails were bent up and before painting did dry fit up on model, one photo shows it needing slight adjustments, the second showing adjustments made, happy at this stage to paint them, just don’t knock them if you can🤞
A short update guys, hope you are all keeping well and happy because that’s important. Right, when l moved to the forward deck area my first task was to paint the mahogany rail onto the bridge superstructure, those not building the 1902 version can forget this detail, obviously this would have been easier done at an earlier stage than this, just a late change of mind on my part. But l was better painting this before l put handrails in the way. Next was fabricating the rails then painting, finally tacking in place then touch ups with fine brush. Have to say l like adding the rails, it always brings the model to life. Post a few photos now 👍
Thanks Greets, at the end of my build l shall highlight what l think are the main corrections to help guys following with their builds. 🤛
Thanks Herby, it’s good when you get to the end of a problem, the journey to that point is sometimes frustrating, we soldier on. 🤛
Ended up cutting the hand rails in the middle at back, then trimming till got suitable gap for staff to fit between them, and also trimmed the bottom plate to suit new position, then reduced the size of brazing, felt it was a bit heavy, used 0.3 wire in its place. Also added the small piece of rigging helping to support the platform up. Well that finishes the stern deck details so put remaining photos up of work done and how it looks, that will be me starting on the front now, foredeck for everyone else. 😂 At least it’s a change of view for me. 🤪 Thanks that’s me for now. 👍
The problem here is nobody seems to have the staf in the right position or configuration, here’s a photo or two to show how it actually was.
After building this complicated set up it doesn’t fit in as it should, thought I was going to have to remove the small platform to install the staff. Have to go just now shall finish when I get back 🤛
If you look carefully you can see what I mean, so I cut the rigging out and reset in correct position 👍 also glued the small deck davit in place after last boat rigged. Fine I thought must be on easy street now, just the aft ensign staff to fit, wrong 😩 set up not right as usual.
I was intending to run a piece of rigging from mast to deck at this point using wire but when I started to look at old photos changed my mind again, decided that there wasn’t any rigging from mast to stern of ship whatsoever , you can always see the two lines on bow to mast on lots of photos but same photos never show lines on the stern. If l’m wrong can always add it later. Whilst looking at photos I also noticed the way the rigging worked for lines for battle ensigns, new there would be two lines up to this point and had run them vertically to each other, this photo shows them spaced apart on the centre stanchion.
Hi guys, another short post on progress, glad to get the last boat out of way it was no easier than the first one 🙄
