Bill97
Members-
Everything posted by Bill97
Sure Ferrus I am always interested in reading about new techniques. Still deciding which way I am going to go.
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Henry. Would parrels have been used on the lower yard? On my HMS Victory I used them on the top yard and topgallant yard but I don’t think I did on the lower yard. I remember Longridge directing a different rigging method for the lower yards.
- 1,508 replies
- Le Soleil Royal
- Heller
As I am looking ahead I am trying to decide if I should turn my own wood dial rods to make the yards or just encase a wood rod inside the Heller plastic halves to strengthen it. I understand from you guys that the topgallant yards are too long so I will be making new ones shorter. I think the easier route would be to just add wood to the inside of the halves, but am up to the challenge to just make the new yards.
- 1,508 replies
- Le Soleil Royal
- Heller
Thank you Ian. So I think I will just leave them perpendicular and don’t bother with bracing.
- 1,508 replies
- Le Soleil Royal
- Heller
Henry back a page or two around comment 1000 you gave me some advice on bracing the yards I believe you called it if I wanted to turn them a bit on the mast. You said that the yards will have parrals to hold them to the mast. The Heller instructions do not show, unless I am missing it, the installation of any type attachment apparatus for the yards. Is this another Hellerism? I planned to make and use parrals. Was surprised not to see anything suggested for attachment. On that same subject especially referring the yards being braced. I held the the bottom yard (nautical term) up to the mast where I planned ti secure it. If I brace it even a small amount it rubs up against the lower shrouds. Would this be correct?
- 1,508 replies
- Le Soleil Royal
- Heller
Ian the yards and running rigging are where the final exam will be administered to see if I can recall everything Dr Ian Longridge taught me during my Victory build 😊.
- 1,508 replies
- Le Soleil Royal
- Heller
Ladies and gentlemen please take a moment to recognize this historic moment in time!! Today, the twenty-first day of September in the year 2023, I did in fact reach the summit or the highest point of my Heller Le Soleil Royal. This is truly an auspicious occasion. Proud to say looking at the ship from the stern I see all three mast, and all 3 sections of each, line up behind one another! I did aggressively trim back the cross trees and trestle trees of the fore and main mast as well as remaking all 3 topgallant masts with wood dial rods. The very fragile trestle tree on the mizzenmast did suffer some damage and I will need to repair it before I can add the topgallant shrouds.
- 1,508 replies
- Le Soleil Royal
- Heller
New fore and main topgallants. I kept all the plastic joint pieces, even the silly cylinder pieces. Drilled everything out and replaced with dial rods I turned to fit. Based on our discussion I made the foremast 4” and the main 4 1/2”. Surprisingly after it is too late to do anything about it I found both the fore and main topmasts were the exact same length if 9”. The bottom section of the mast is where some big difference is and now another 1/2” on the topgallant.
- 1,508 replies
- Le Soleil Royal
- Heller
While I was debating with myself as to the height of my topgallant masts I worked on installing the four anchors.
- 1,508 replies
- Le Soleil Royal
- Heller
Ian looking at the card cutouts I did to represent the shroud spread which of the three topgallant heights look the best regardless of the area. I want to build my ship with a combination of both authenticity and visual appeal.
- 1,508 replies
- Le Soleil Royal
- Heller
Marc see if this helps. I took card stock and cut out the shape of the shroud spread for the fore and main topgallant. All three have 1/8” cut off the cross trees. Photo 1 is with the topgallant unaltered from the kit size. Photo 2 is the topgallant at .5 of the top mast. Photo 3 is the topgallant at .4 of the top mast.
- 1,508 replies
- Le Soleil Royal
- Heller
Ok thoughts, opinions, recommendations. Here is a mock up of the main topgallant mast height and the corresponding shroud spread. Also I am looking at an aggressive cut of 5mm off each side of the cross trees and the aft side of the trestle tree. That will be the same as the distance between the cross trees. Pictures 1 and 2 are using a 3 5/8” topgallant Pictures 3 and 4 are using a 4 1/2” topgallant Pictures 5 and 6 are the height of the Heller included topgallant of 5 1/4”. Thoughts and opinions. Do any of these seem satisfactory or go back to drawing board?
- 1,508 replies
- Le Soleil Royal
- Heller
Now on to working with these topgallant masts and trestle trees. 🤔
- 1,508 replies
- Le Soleil Royal
- Heller
With the completion of the mizzenmast topmast stay and backstays I have completed the standing rigging up through the top masts. Interesting the at the mizzenmast topmast stays are a pair of crows feet that tie to the lower shrouds of the mainmast. Starting to catch up to my Heller HMS Victory cased below it.
- 1,508 replies
- Le Soleil Royal
- Heller
Henry that is our favorite part of Scotland. There is a little town just a bit north of Inverness called Dornock that we have visited. Your trip sounds fantastic. Happy Anniversary. How many years?
- 1,508 replies
- Le Soleil Royal
- Heller
Henry welcome back from your Scotland trip. I really enjoy visiting Scotland. Where did you visit Thanks for your reply. Looks like I am going to be trying my best to make a silk purse out of this pig’s ear already mounted on my mast. Of course I will also need to glance forward to the foremast which has its trestle tree already mounted and locked down as well. Or maybe my SR was reincarnated in the 1800’s 😊
- 1,508 replies
- Le Soleil Royal
- Heller
I am definitely going to reshape the cross tree as close to the appropriate size as I can manage. Not sure exactly what I will do but that is my plan.
- 1,508 replies
- Le Soleil Royal
- Heller
Oh Ok. That makes since. Simple triangle geometry. I am working on the main topmast stay and back stays right now. Looking at the cross tree and the mast top below I can see the cross tree/trestle tree is definitely too big. Would you shorten the aft end of the trestles a bit to make it look smaller? You definitely made the right decision making your own to proper scale. I am going to finish all the standing rigging for the topmasts and then give a good study to how make the topgallants look right. By the at I have finished all the ratlines for the topmast shrouds.
- 1,508 replies
- Le Soleil Royal
- Heller
Gentlemen as I read through our current discussion and look closely at my ship, especially what I have already completed, I can see as you have pointed out errors in Heller’s design. Unfortunately some of these errors are in items it is to late to correct. The error now being the cross trees and trestle trees which are now permanently locked in position under the shrouds. My only hope is to do the best I can to make the model visually interesting and attractive despite the lack of accuracy. Ian you are absolutely correct the topgallant mast can not be struck with the trestle tree designed as it is. Marc I measured the width of the cross trees. They will have the topgallant shroud spread the same width as the topmast shroud spread. You mentioned shortening the cross trees. I don’t understand how this would change the spread. Henry have you reached this point? If so what did you do and how does it look?
- 1,508 replies
- Le Soleil Royal
- Heller
Marc as usual you have given me a lot to think about. I had not thought about keeping the shroud spread appearance the same all the way up the mast. Will have to mock it up as you said to get a good feel. Thanks to you and Ian for your help today.
- 1,508 replies
- Le Soleil Royal
- Heller
OK I know I am spending way to much time on MSW tonight discussing my ship with you guys! 😊 Ian I picked up my Anderson book to read through Chap 3 again after you referenced it above. I stumbled on something that concerns me. I hope you or Marc can shed some light on. On page 50 of Anderson’s book he explains the position of the topmast cross tree and trestle tree. He shows the third cross tree placed forward of the mast top. The Heller instructions, and the way I have already done it, is to have the third cross tree aft of the mast top. 😳
- 1,508 replies
- Le Soleil Royal
- Heller
