Bill97
Members-
Everything posted by Bill97
Henry that is incredible! What an amazing experience. Have you built a model of the Constitution? Surly you have. I need to check the index. How great of an information source that would be. I can picture it. You working on your model and trying to figure out how something should be. Then thinking, I will just check the real thing tomorrow when I am on board. You have got to attach a photo of you on board in your 1812 marine uniform.
- 1,508 replies
- Le Soleil Royal
- Heller
Henry I am steadily reading through your build now picking up a lot of great ideas and techniques. I was pleasantly surprised to read the part about you working as a character on the USS Constitution! That is pretty cool. I know that was a number of years ago when you wrote that comment. Are you still doing that in the summer? I have really enjoyed visiting the ship when I am in Boston. Have done it several times over the years. Who knows, our paths may have crossed on the ship one day in the past. I built the Revell 1/96 Constitution years ago. Some of its crew deserted and became crew on my Heller Victory 😊.
- 1,508 replies
- Le Soleil Royal
- Heller
I have entered a phase of my build where there won’t be much progress to report on a daily basis so my post will be fewer for just a bit here. I don’t see a point in posting just to post. Of course the friendly exchange of conversation is nice even if not pertaining to model ship building. I am solid into building the hundred and some odd cannons. My building table looks like an old factory assembly line with many partially completed cannon carriages lined up to move forward for the wheel attachment. Barrels are also being assembled and painted in another “factory”. Soon the painted carriages and barrels will be joined together and prepared for loading on the SR. My intention is to separate out the cannons that will ultimately be seen. They will be in need of trunnions modifications.
- 1,508 replies
- Le Soleil Royal
- Heller
Henry did carving a new semicircle for the trunnions cause the barrel to drop about 1/16” or so?
- 1,508 replies
- Le Soleil Royal
- Heller
Looking at this picture in the instructions I see there are only 24-28 cannons that will be in full view once the model is complete.
- 1,508 replies
- Le Soleil Royal
- Heller
Ok as far as placement of parts. I set the wheels to where the edge of the wheels are flush with the front and back edge of the carriage. It is also interesting that if I set the trunnions right in front of the trunnion support the barrel is in a satisfactory position. Since the front of the barrel sets on the little thingy in the front (another nautical term) the trunnions on the model pieces serve no real purpose except cosmetic. So now for the cannons that will be visible I will just need to come up with a convincing trunnion movement. I could simply cut them off, save them, and once I glue the cannon to the carriage put a tiny bit of glue in the raised semicircle and drop in a trunnion. Might be easier than trying to drill all these barrels.
- 1,508 replies
- Le Soleil Royal
- Heller
I agree Ian. To make sure I see what you are seeing, the one on the left is the bashed cannon? If I zoom in on the bashed cannon I can see a small pinkish spot where I guess you he trunnion used to be. Daniel did not move it a lot. Just enough to get the (no nautical terms here) band around the end of the cannon to set on the block thingy on the back of the carriage? 😊
- 1,508 replies
- Le Soleil Royal
- Heller
Ian I did PM Daniel. He sent me this a link to his SR build on a German site. I told Daniel my German translation skills were lacking. However it did contain this one photo of his cannons.
- 1,508 replies
- Le Soleil Royal
- Heller
Along with tinkering with the cannons I did finish painting the hull today. Still have to decide if I want to add the out of scale wale bolts.
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Marc. That makes painting easier! This is kind of interesting. I turned the primed carriage base piece over and there are some fine molded lines that would for sure place the wheels close together. I just just stacked the parts together for one of the guns to see what I think. Not exactly sure where I should place the wheels exactly. When I laid the corresponding barrel next to it you can see where the trunnions would have me place it. But if I move the barrel forward half, or more, is forward of the carriage which gravity would make it difficult to keep it raised. I wonder if the trunnions are only slightly wrong for center if gravity?
- 1,508 replies
- Le Soleil Royal
- Heller
One thing I am curious about. The Heller instructions and some of the build photos I have seen have the entire carriage, including the wheels, red. Would that be correct? Would the wheels have actually painted red? I can’t imagine that being the case.
- 1,508 replies
- Le Soleil Royal
- Heller
Well different from the Victory cannons, there does not appear to be a preset place on the bottom of the carriage to put the wheels. It seems as if I/we can place the wheels where they look the most appropriate. I am going to move them closer to the ends of the carriage.
- 1,508 replies
- Le Soleil Royal
- Heller
Ian I started last king at the carriage parts and barrels for the cannons. I clearly see what you mean by the trunnions being to for forward in the barrels! When I compared where the barrel would set in the carriage with the trunnions as is to an extra Victory cannon I have, it looks like the trunnions are almost 1/8” to for forward. The barrel on the Victory cannon is even with the end of the carriage. The SR barrel as is would continue on out past the back of the carriage and look really awkward as you said. You said you may not move the trunnions on the hidden guns but I am curious (and will find out soon) if the barrels will extend out of the hatch if I don’t. Of course I could maybe figure out an easier way to cut off the trunnions on the hidden cannons and just slide the barrel forward in the carriage using some other hidden support.
- 1,508 replies
- Le Soleil Royal
- Heller
Veszett I would love to, and not just for the single malt! Of course now guys I have to lean more toward the bourbons rather than scotch, which I like very much as well, or I would be forced to move out of Kentucky! 😀
- 1,508 replies
- Le Soleil Royal
- Heller
There is a newer bourbon distillery here in Louisville (Rabbit Hole) that distills one of it’s four bourbons in a sherry cask. It is has a really nice, smooth flavor. Look for it at your favorite liquor store. A little pricy but worth it.
- 1,508 replies
- Le Soleil Royal
- Heller
Now your talking Marc! I have a bit of Glenmorangie Single Malt I picked up in Scotland. I sip it as well. Both it, and it a nice bourbon, helps get all the holes lined up. And if you throw in the fumes from some Testor glue. Now you got something. 😀
- 1,508 replies
- Le Soleil Royal
- Heller
As I was saying. Bolts removed. Holes puttied. Bourbon sipped! May be a little smooth jazz playing. 😋
- 1,508 replies
- Le Soleil Royal
- Heller
Marc, like you, I really enjoy adding the small custom modifications. Enjoyed that with my Victory as I learned from you guys. I do want to add the wale bolts as I am very much using the picture above which I really like as my inspiration. I think I will try to grind the pin heads down a bit (probably still be out if scale) and improve my pattern. As we have said, there are not to many visitors to my ship room that will point out that the wale bolts are clearly out if scale. 😊 I more want them to comment that is a beautiful model ship I built and appreciate the small details I incorporated. I guarantee 100% of the people who will see mine will ask what is that ship? Will have no idea of it’s origin or period architecture. I want to work in that middle area. Much better than OOB but short of perfect authenticity. That is a more happy place where bourbon can be included while building. 🥃😀
- 1,508 replies
- Le Soleil Royal
- Heller
Marc it may be best I just not do the wale bolting before I get to far into it? Lot of time and effort if it is wrong! I can repair the few I did already. So in the photo included here, it is wrong as well?
- 1,508 replies
- Le Soleil Royal
- Heller
Needless to say just a very small section complete, but now that I have the hull painted and weathered to my liking I am am starting the process of nail holes in the planking and bolts in the wales. This may take a while. Marc I bypassed the anchor lining since I am pleased with the painting and did not want to risk messing it up.
- 1,508 replies
- Le Soleil Royal
- Heller
So you made the entire way up flush not just the two lower main wales? And you used Evergreen or some other styrene as the filler? Brilliant! Along the edge of the styrene, front and back, did you just leave the edge or putty and blend into the planking? Hard to tell from your photo.
- 1,508 replies
- Le Soleil Royal
- Heller
Thanks Marc for the photo and further explanation. I guess filling that area flush helped keep the anchor from hanging up on the lower main wales as it was hauled in? I obviously notice on yours that you have that area still white. What is your painting plan?
- 1,508 replies
- Le Soleil Royal
- Heller
I quickly, with a little panic, checked all the SR builds I am reading through and have not found any with that area painted black so I am going to live with mine as is.
- 1,508 replies
- Le Soleil Royal
- Heller
