Danstream
Everything posted by Danstream
  1. Great result Olli, congratulations! I am amazed by how fast you have been in building your model. In just a couple of month you went from start to finish. Well done, Dan
  2. The kit looks fantastic and you have done an outstanding work with the interior. Cheers, Dan
  3. Hi, I am sanding the first layer and I had also to apply some filler in some areas. A close up of the bow which is almost finished. The stern looks a bit more problematic. I ordered some riffler files that I will be using to improve the bearding lines and the taper of the keel. The pattern of the strakes is almost ok. I will improve it with the second layer. That's all for now, not much to show but I can tell you that a lot of wood dust was produced. Best regards, Dan
  4. Hi all, after a long period of inactivity, I am resuming this post of mine. At a slow pace, I went on with the 1st planking adding another band of strikes to the hull. I continued by bending the planks in-plane and out-of-plane and tapering them at the bow and at the stern. I switched to using nails for temporary fixation of the strakes because I could not fit the bulldog clamps anymore. Finally, after long, the hull is fully closed up. The result is far from being perfect and I had several misalignments between the strakes, but I hope that a careful sanding and filling will smooth out the blemishes. I will adjust the tapering of the single planks of the 2nd layer using the first one as a valuable reference. I must fair appropriately the ends of the planks in the deadwood zone of the stern to get a smooth transition from the hull to the vertical thin section of the rudder. Thank for following and for any suggestion or comment. Dan
  5. Yes, I loved these western movies, they were packed with these cold-humor lines and situations. I don't know whether they would be considered acceptable nowadays. Anyway I liked them a lot. Great actors, great scripts, great director and above all memorable music. If you like it, tries the following: Cheers, Dan
  6. they look fantastic as the rest of the bike. The treatment of the various materials is exceptionally well done. You should start one of the other bikes and post it here. Congrats, Dan
  7. Dear all of you who are following this build, I would like to inform you that my build is momentarily on hold, because: - in the last period, I am working on my ship build, although I don't have anything interesting to post yet; - with my retirement, I resumed an old hobby of mine which is drawing and painting, see below; - I am going to drive a long trip down to Italy to visit roots and that will keep me away from my hobby desk for several weeks. About the Mosquito, the installation of the Squadron vac-formed canopy is concluded and the result is quite ok, I will show you that as soon as I will have some progress, when I am back. About the other hobby, let me post here two exercises of mine that perhaps should please at least Chris, @ccoyle, seen the quote he inserted in the footer of his signature. These are drawings made by pencil and that I copied from pictures of the actors that I downloaded from internet. Sorry for the digression, Arrivederci, Dan
  8. You gave me an idea to copy. I second the others, great model and beautiful photography. Cheers, Dan
  9. Everything looks so believable! Great modeling! Cheers, Dan
  10. Hi, this post is dedicated to a problem that I had once I mated the fuselage halves and wanted to install the canopy included in the kit. Actually, the canopy of the kit is very well made with a very clear plastic, but unfortunately it was found accidentally separated from its tree. Consequently, the plastic in the vicinity of the gate was torn off and stress cracked in the bulk of the part as shown below: The depth of the of the frame at this location is very narrow and once painted it is not enough to hide the offended area. After some attempts to sand and polish the defect, where instead of improving I worsened it, I decided that the canopy had to be binned and replaced. After a search on the web, I bought two vacuum-formed canopies produced by Squadron. I must say that I never used these types of canopies and I was uncertain about their quality. The bag contains a blister with two canopies, but only one of them is usable for the model I want to build (i.e. the standard type). My doubts were associated with the very thin material used and with the necessity of precisely separating the canopy part from the rest of the blister. However, according to some articles, these canopies with their thin thickness are supposed to be even better than the original kit parts. For cutting, as prescribed by Squadron, I used a fresh X-acto blade making multiple passes with minimal pressure while the canopy was supported by a blu-tak plug pressed inside it. I first practiced on the bulged canopy before proceeding with the good one. At the end, the cutting and subsequent trimming fortunately turned out to be quite precise: Next, the gluing operation followed. According to Squadron and to most of the articles that I read, the most suitable glue to be used is the Micro Kristal Klear. The glue had to be thinned with water to decrease its viscosity and allow it to penetrate by capillarity in the gaps between the canopy and the sills: I brushed the thinned glue along the gap cleaning the excess with a wet pointed cotton swab. Because the thinned glue shrinks a lot when cured, this process has to be repeated as many times as necessary to satisfactorily fill the gap and obtain a fairly strong bond. So far it is going fine, but I will be able to see the quality of the result only when I will brush some paint over the joint. That's all for now, best regards. Dan
  11. Indeed, actually, on top of what I said (I simplified a bit the story), as you said, all the spokes must be pre-stressed in tension (the lost art), so the ones on top increase cyclically their tension load and the ones on the bottom decrease it without becoming compressed and so avoiding buckling. Torque (of the engine or the brakes) is transmitted from the hub to the rim thanks to the eccentric positioning of the spokes (if the spokes passed through the axle, no torque could be transmitted). I stop here. Best regards, Dan
  12. It is a beautiful model, everything looks so believable, the metallic parts are great. In connection with the spoked wheel, let me have a little digression that might be amusing for some. When I a was a fresh graduated engineer, during a job interview, I was asked to discuss the loading capabilities of thin rod loaded in axial compression. Clearly as intuition said and as confirmed by the maths behind, long and thin rods could not take meaningful loads when the radius is very, very smaller than the length. The next question was: "then, how a spoked wheel of a bike can carry your weight?". After a bit of thinking, I concluded that the weight is carried by the upper spokes that are loaded in tension, so, when riding a bike you are 'hanging' on the upper spokes and nor supported by the lower ones. This was a surprising fact for me that I never realized before. By the way, the interview was successful. Sorry for my digression, best regards, Dan
  13. @JKC27, thanks for your compliment, I hope not to disappoint you. Very interesting that you have a Mossie being restored at hand. It could turn out to be very useful 🙂. Regards, Dan
  14. The introductory pictures of this kit are very promising (indeed, the instruction booklet reminds a lot the style of the WnW's). In addition, a Spitfire cannot be missed. Cheers, Dan
  15. What a sharp looking plane you have, Dave! Very well executed, the paint finish is spotless and it looks wonderful with its vivid livery. Congrats, Dan
  16. Rob, I find this build fantastic. Close-up pictures as well as wide shot pictures are great and reveal a lot of details to be seen. I also learnt a couple of things that I will unashamedly copy in future. Bravo, Dan
  17. Dear all, these are last steps with the fuselage interior. I added the gunsight to the cockpit and these are its last images before enclosing it in the fuselage: The fuselage interior was painted black and then mottled with the interior green. The cockpit posed with the port half: And with the starboard half: The first important milestone, the fuselage is now buttoned up: With few additions, the parts of the kit allowed to fabricate a nice and detailed cockpit. The last piece of equipment glued on the edge of the coaming: The bomb bay with the false breeches of the four cannons now looks like this: For @Old Collingwood, I tried to take a picture of the cockpit seen through the open hatch, but it is not in focus: That's all for now, thanks for following, Dan
  18. Thank you OC! Yes I am planning to pose the hatch open, I saw that you can peek inside and appreciate some nice details from there. Dan
  19. Dear all, a short update with nothing exciting, but I needed to complete some necessary activities in preparation for closing the fuselage halves. One very tedious task was to address the many ejector pin marks on the fuselage inner sides. Then, the interior was furnished and some 'fantasy' cabling was added: The two halves are now ready to receive some black paint before the interior green. Meanwhile, I finished to weather the bomb bay with the application of some black and brown Tamiya panel liner: It turned out quite OK when inside the fuselage, although I must say that little of it will be seen because it will be covered by the structures that will held the bombs and half of it will be hidden by the doors of the cannons bay: In the nose, I am replacing the Browning machine guns muzzles with the very nice Master brass additions: I will glue them in place later on, probably after the application of the camouflage. I am not going to detail the gun bay and probably I will close this compartment after having glued the muzzle definitively in place. Finally, I am posting a picture of the completed cockpit tested inside the fuselage to show how much of it will be visible: That is all for now, thanks for following, Dan
  20. @mtaylor, @Old Collingwood, I also have interpreted the plate where the backrest of the navigator is located as an armored plate. I even made some chipping on the edge of it. However, even assuming so, the head of the navigator was not protected. But I have seen such an arrangement also when I built the interior of the Beaufighter where the pilot seat backrest stopped at the shoulders height. Cheers, Dan
  21. Your propellers look terrific too! The overall composition with the rest of the airframe is just spectacular. Cheers, Dan
  22. That's a terrific model and diorama. There is a lot to look at. My favorite picture is the one where you can peek inside. Congrats, Dan
  23. Good work on the propeller. If I may, this is my take with normal pastels over a layer of Tamiya paint, followed by Tamiya clear orange. Cheers, Dan
