Redshadowrider
Everything posted by Redshadowrider
  1. . Ready to start planking. Whoa... 😄 just getting your attention. Ready to plank the lower deck at bulkhead 20. I have all the bulkheads in place and all block spacers in, squared, and glued. You can see the last ones at the bow still under clamps. Now, I am going to wait 24 hours to let the glue dry. Then it's onward.... Process Note: During this step, I did a couple of things differently than instructions indicate (No, not that I am an expert, far from it.) However, I have read more than enough threads here to know that squaring the bulkheads is extremely important, so I took my time. However, I put in the bulkheads first (no glue) then began to square up with other sections as I added them. By not gluing the bulkheads to the bulkhead former, I was able to square ones that were off without twisting glued wood at the center. Each block has been squared, shaped and glued in even with no glue on the bulkheads. As you glue in each bulkhead, there is glue on the block on 3 sides. Bow and Stern sides are glued to 2 bulkheads as well as the former. I doubt they will move, but one more step I will add. Once all blocs are in, and the glue dried, I am going to come back on the underneath side and use the CA Applicator with extra thin CA and put some glue on each intersection of the bulkhead former and bulkhead. This should make it solid as a rock.... or good enough. Newbie Error: Not quite a mistake, but a slight error. I couple of the spacing blocks are extended just above the bulkheads on the deck floor. I have a chisel that I can use to remove just a little without hitting the bulkhead. Try not to do this.. Luckily I have only 2 to clean up and it is not too difficult. Just remembered something else. If you build your own building board, try to incorporate a base and lazy susan rotation hardware. I was really glad I had it when jumping from side to side on this part. Just remember to make it so you can lock it down at any angle. Now the pics.
  2. Thanks for the tip on sanding the high spots. With planking being so thin, It is probably a lot like the lite ply or balsa surface we need perfect before adding the covering on the planes I fly. I will do the once over before moving on. As indicated, I had no 1X2 stock around, so I masked up and went to Lowes. (My second home, or maybe my first...just not sure.) Picked up some tite bond glue that dries clear and a 1"X2"x6' poplar strip and started. In the picture you can see the first 3 spacer blocks in place and clamped. I think sanding after they are in should take care for the fairing of the hull. Well time for lunch and drying the glue, will pick back up this afternoon.
  3. Chapter 2 (continued): Reading the instructions, it covers the process of “fairing” the bulkheads. It is to be done before gluing the spacer blocks and bulkheads in place. However, I am thinking that I am going to reverse the steps. Since I am going to square up each bulkhead as I glue it in place, there will be less of a chance that the bulkhead will move during the fairing process. Only 1 or 2 bulkheads were not square, and then, a very small amount, so I think the risk of an issue will be very small.
  4. Well, I got the carving done on both the fore and aft bulkheads just now. Still a little to do to firm them up, as I still need to sand the inside of the bulwark. I may elect to go ahead and put in the spacing blocks, after "firming" up the hull. Doing the outside with the Dremel Sanding Disk is somewhat tedious, but that's part of the deal. We have those in RC flying, so I am ok with that. I now need some 1"X2" stock for the bulkhead spacers and I know that I have wood, but 1X2's is a size I haven't used much. Process Note: If you have used a Dremel for work like this, I recommend it. I think it came out more accurate and was easier than using these "newbie" carving hands. I used, just a sanding disk for 95% of the work and it was a great set up, just by coincidence. The dremel sanding disk that has the replacement sandpaper disks makes it a good for the coincidences. 1. The sanding disk radius is the same radius as the thickness of the lite ply. It's almost like a router sander. However, since it is sandpaper you are replacing blades quite a bit. I used the cylinder type on only 1 bulkhead and it was the very first one at the bow. Most have small amounts wood removed that can be handled with the disk. The first one has the most wood to be removed. I started with a sanding cylinder and finished with the sanding disk. YMMV 😄 Here is a pic of the bow... still a little hard to see due to the wood coloring, but here it is.
  5. Thanks Overworked. I don’t know how I would survive without my dremel when working on my planes. I am considering using a sanding disk rather than the wheel. You are correct about the wheel taking a large amount. Will update with results.
  6. Next step has been completed. All bulkheads have been placed in their proper positions. I am happy to report that only 1 or 2 did not sit at a 90 degree angle to the bulkhead former, but they are so close, the strengthening blocks that go in next will certainly take care of that. Next step is to begin "carving" the bulwarks and bulkheads that need to be shaped. I have looked over them, I can see that once this is done, the bulkheads will line up correctly with the bearding line. I am sure some small adjustments will be required, but it doesn't appear to be a huge job ahead. Process Question: The instructions indicate that I should "carve" the bulwark and bulkheads to shape them to the curve of the hull for planking. I am wondering if anyone has tried using a Dremel to sand the angles into each? It seems to me that I am just asking for a bulwark to break even with just a small amount of pressure.
  7. Question on Bulkheads: In the Chapter 2 instructions, I have started going through the bulkhead fitting. At the same time, I am checking the alignment for bulkhead former to see how close to 90 degrees they are. Have completed sanding and fitting from the stern to the bulkhead that has a O ..with an X through it. The instructions say to face the numbered bulkheads to the stern and the lettered ones facing the bow. Does it matter with the O with an X in it? Stern or Bow? LOL
  8. Thanks for reminding me about cutting off the keel overhang. I was going to ask and forgot to. All the pictures I have seen, show it is only about 1.5 to 2 inches past the stern. I will cut it back to avoid the inevitable accident I would have.
  9. Keel and Knee Stem are in place, and glued. Just clamped up and now watching glue dry 😄 Cut the bulkheads from the light ply board and cleaned them up. And thanks, Overworked, you are absolutely right about the next model. I did that a lot in the RC plane hobby, so It's something this house is familiar with. I have, I think, a total of 15 planes of flyable condition from 40" wingspan all the way up to 83" .. I had to start building smaller. 😁 NEX STEP: On to CHAPTER 2!
  10. Thanks for adding your comment. Unfortunately, the rabbet was already glued in place, so I was unable to do it the way you suggested. Maybe next time. 😁
  11. Progress Made Although it is hard to see because of the color of the light ply, I have completed the bearding line on both starboard and port sides. It is now ready for the knee stem and keel. Newbie tips: You can see in the pictures the tools that I used. Although the instructions show an x-acto knife being used, I found it a lot easier using a good chisel (pictured). I also used the emory board, and sanding stick in the hard to get places and I was pleased with the outcome. As far as the rubber bands and CA applicator, I recommend that you keep them handy along with extra thin CA in the applicator. You will and I mean will, at some point slice into the rabbet and you will need to pause to fix it. The CA applicator, and rubber bands make for a quick fix. (I know you don't have to ask how I know that.. ) 😉 Onto the kneed stem and keel.
  12. Finally I have started carving the bearding line. The pictures are of the stern portion on the port side. I did order and received the chisels that I noted in a previous post. I gotta say that a good chisel is worth it. I know those that I ordered are not top of the line, bu they came recommended. I have included two pictures, but details are hard to see. OHHH, for a macro-lense ....LOL I will post again after completing the bearding line. both port and starboard sides. First bearding line pics.
  13. This morning, I tried a different approach to carving along the bearding line. I think this will help me visualize what amount of wood I need to remove beyond what the different drawings show. I removed 3 bulwarks from the laser cut template and used them to see where they fell along the bearding line. Since I started carving already, here is how I am using them. I took each bulwark and placed it on top of the hull at the spot where they will be glued into place. By doing this, I will be able to see where, and how much of the hull to remove along the bearding line. Time will tell if this works as I move forward and stern. (Tip...Just make sure you put the bulwark, in the right place for the visual.) 😉
  14. I am thinking that I also have to keep the planking free from any obstruction between the bulwarks. That will avoid the occasional bulge if the plank hits it on the backside. I will see more when I test fit each bulwark. ...and, I have a wood carving chisel set on order. I think I will be ok. I just got nervous carving away wood. 😁
  15. Now that the mistake was resolved, I have started the true next step, carving the bearding line. As you know, the bearding line along the bottom that it is difficult to carve without hitting the rabbet. It leaves me with a question in the intent. I know that the rabbet is a slot for the planking. Is the intent to remove enough material so that the planking is hitting the bulkheads only? If so, I can slide in bulkheads 2 at a time and sight between them to ensure clearance. I have done a search on it and still am confused a little.
  16. As indicated, this is a newbie build reporting good and bad by the builder.. (me) I am hopeful to keep this to a minimum NEWBIE Mistake #1 - Read a page ahead on next steps, and forgot to go back to the page I was on. Not a big deal as it has been resolved, but I need to be more careful. I started gluing the stem knee on before I had carved the beard line. Probably not a big mistake, but it would have made carving much more difficult and possible damage to the stem knee. Caught it, cleaned both parts of the residual glue, and now moving on to the carving. (LOL...need some small chisels first though.) Considering these: https://www.amazon.com/Power-Carving-Tools-Seven-Piece/dp/B0037MI3K2 ALSO - LOL on the jack stands... They are from Harbor Freight and have been recalled...due to the virus, just haven't taken them back in. 😁 Will sell cheap...
  17. Thanks guys, I am glad to be started. BTW, Overworked....we have lived in Glen Ellyn on two separate occasions.
  18. That is some great work Walrus. We got back from seeing our new grandson, and I finally got started on mine. Your build log will be my go to for help, and pictures as it is a terrific resource. I started a build log from the view of a newbie. It will be more photos with some written content when required. After all, it is just my first. Keep up the great work.
  19. I am going to attempt to create a build log that is somewhat different. It is intended to follow my first ship construction including both the good and bad that occurs. I have built and flown RC Aircraft for about 18 years now, and have some experience with wood construction. However, I know that what I am starting is quite different. I have to stop building planes since some are now so big, they barely fit in my pickup bed. That being said, I will gladly take advice and comments as I go along. Since there are numerous build logs by experienced builders here, I will try to stay with a photo log and keep the writing to a minimum. It will be mostly from a newbie point of view any way, and I am not sure what tips and skills will convert from planes to ships. So here we go.... First, I needed to add some items to my tool box/bench. Not much need for a 9mm wrench, hex wrenches, or other larger tools. So I bought some diamond files, spring clamps in different sizes, and built my own building board that can be seen in the pictures. I used scrap wood I had laying around, added a lazy susan to be able to turn the model 360 degrees if needed. I built clamp devices that will allow me to turn over the build when I begin planking. To keep the table from spinning, I put in two blind nuts and a butterfly screw on each side. This will allow me to clamp it from either side so it will stay put. Today, I was able to begin the first step..... Hoist Anchor and get under way. 😃
  20. Can you point me to where I can find these pieces? I have found the site for obtaining the carronades. I am in the process of making a decision on buying them. After all it is my first build and while it may be the way to go, I have a lot to learn.
  21. Maybe an easier way is to take a rolled piece of tape in each hand. Holding it between thumb and forefinger leaving a flattened part to push against the copper and backing. Then gently pull it apart leaving the copper on one side and the backing on the other. I would add pictures, but happen to be out of state seeing our new/first grand son. It might take some testing to see how it works. In the video, I just envision trying to separate the pieces by using the xacto knife as bending at least one corner on every copper plate.
  22. Newbee here. Regarding the process of removing the adhesive backing from the copper Plates. We have a similar issue in the RC plane hobby with the covering materials. The covering has a thin layer of heat sensitive glue on the back, and then a layer of protective film on top. To separate the film from the covering we use tape like on the quarter round, but we also use tape on the colored film side. The tape attaches to the film backing on one side and the tape on the other side attaches to the colored film. This allows for an even pull to both protective backing, and the covering side. I am thinking that placing the backing on a flat double taped surface With copper side up. Then using either a piece of 1/4 round to roll lightly over the copper, or a flat piece with tape to gently lift the copper plate off of the backing. It might help to protect the shape and detail of the copper intact. I am just thinking, and would try it, but I am miles away from even starting mine.
  23. Hi All, new builder here and am getting ready to build this beauty. I do not want to hijack this thread, but will be following along. I have been building rc airplanes for quite awhile now, but my garage is full of them hanging on the wall. I either needed to stop flying, or change what I build, so this was my choice. I hope to transfer my skills over to this hobby and am looking forward to following this build. If you want to point me elsewhere (since I am a new bee) I am open to that as well. I am reading 3 different books: Planking techniques by Donald Dressel; Ship Modeling from Stem to Stern by Milton Roth; and How to Build First-Rate Ship Models from Kits by Ben Lankford. Also have almost completed my building board/keel clamp. Hope to be able to follow this thread and become more knowledgeable. Here is my building board... still a few things to complete, but it is mostly done. oops....And the Chuck Passaro practicum. Building Board
