marsalv
NRG Member-
Everything posted by marsalv
Thank you guys for all your comments and likes. To scrubbyj427: I am using CNC maschine made by China, these maschines are avaiable worldwide (see the picture). I started works on inner bulkheads.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Scrubbyj427 - I am using pear wood (steamed and not steamed - different color) and black hornbeam. Completion of the quarter gallery.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To Oliver1973 - The holder for Proxxon vice is selfmade (not my production). I continue with rear windows (lights?).
- 589 replies
- le gros ventre
- cargo
Tnak you guys. To No Idea: I have one Proxxon milling maschine, I only added electronic control to the x-axis. As for accuracy I agree with Derek. Some stern improvements.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys for your feedback. My experience with hand carving is minimal and not very good. Therefore, the use of CNC milling maschne for carvings seemed to be the only possible solution. But even the actual production of cnc carvings requires knowledge of several computer programs to create a 3D model and prepare data for the CNC milling machine. So it's not just about turning on cnc and waiting. Answer to scrubbyj427 - CNC maschine is small maschine made in China, but so far I'm satisfied. Now some new pictures - stem.
- 589 replies
- le gros ventre
- cargo
Thank you guys for nice comments. Scrollwork and moldings are done with CNC milling maschine. The same situation is for the parts on next pictures. All carvings are made with CNC. It is likely that some of you will condemn this process, but you will not stop technical progress. I would be quite interested in your opinion on the use of modern techniques for creating carvings.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys. Answer to Glenn: The groove is made so that you only have to push the plank into the groove. For sure, however, it is still glued with double-sided tape. I started work on stern - moulding rails.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To dowmer - this time I used brass, which is then tinned, and tin foil, which is glued to the deck with double-sided adhesive tape. To glbarlow - the maximum length I can do on a milling maschine is 28 cm, for longer plank I use "special jig" - see picture. I insert the plank into the groove in the jig, perform the milling of the first part, remove the plank and move it forward and continue milling. I continue with breast hook, collar beam and bowsprit partner.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Hi Michael, moldings are made on CNC milling maschine. I am using VCarve software for this purpose. You have to create only curve (cross section) of molding and maschine does the work itself🙂. You can see in this example that my workmanship is not so superb as you noted🙂. Preparation of deck beams for forecastle and quarter deck.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys for all likes and very nice comments🙂. To archjofo: why that modesty, your work on La Creole is amazing. To JpR62: the moldings are done with milling maschine. I continue with planking the outer parts of the hull.
- 589 replies
- le gros ventre
- cargo
To Druxey - thanks for informations, I discussed this situation with my friend who had the same problem. I cover these lead items with clear varnish and the whole hull is then preserved with the wax. I hope that it will be OK. To Alexandru - I am using the french Sajou thread for the ropes (https://sajou.fr/en/339-fil-au-chinois-gloving-thread-1000m-cones). Unfortunately this thread is only in one thicknesess. Completed ceiling.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
