marsalv
NRG Member-
Everything posted by marsalv
Tnak you guys. To No Idea: I have one Proxxon milling maschine, I only added electronic control to the x-axis. As for accuracy I agree with Derek. Some stern improvements.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys for your feedback. My experience with hand carving is minimal and not very good. Therefore, the use of CNC milling maschne for carvings seemed to be the only possible solution. But even the actual production of cnc carvings requires knowledge of several computer programs to create a 3D model and prepare data for the CNC milling machine. So it's not just about turning on cnc and waiting. Answer to scrubbyj427 - CNC maschine is small maschine made in China, but so far I'm satisfied. Now some new pictures - stem.
- 589 replies
- le gros ventre
- cargo
Thank you guys for nice comments. Scrollwork and moldings are done with CNC milling maschine. The same situation is for the parts on next pictures. All carvings are made with CNC. It is likely that some of you will condemn this process, but you will not stop technical progress. I would be quite interested in your opinion on the use of modern techniques for creating carvings.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys. Answer to Glenn: The groove is made so that you only have to push the plank into the groove. For sure, however, it is still glued with double-sided tape. I started work on stern - moulding rails.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To dowmer - this time I used brass, which is then tinned, and tin foil, which is glued to the deck with double-sided adhesive tape. To glbarlow - the maximum length I can do on a milling maschine is 28 cm, for longer plank I use "special jig" - see picture. I insert the plank into the groove in the jig, perform the milling of the first part, remove the plank and move it forward and continue milling. I continue with breast hook, collar beam and bowsprit partner.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Hi Michael, moldings are made on CNC milling maschine. I am using VCarve software for this purpose. You have to create only curve (cross section) of molding and maschine does the work itself🙂. You can see in this example that my workmanship is not so superb as you noted🙂. Preparation of deck beams for forecastle and quarter deck.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys for all likes and very nice comments🙂. To archjofo: why that modesty, your work on La Creole is amazing. To JpR62: the moldings are done with milling maschine. I continue with planking the outer parts of the hull.
- 589 replies
- le gros ventre
- cargo
To Druxey - thanks for informations, I discussed this situation with my friend who had the same problem. I cover these lead items with clear varnish and the whole hull is then preserved with the wax. I hope that it will be OK. To Alexandru - I am using the french Sajou thread for the ropes (https://sajou.fr/en/339-fil-au-chinois-gloving-thread-1000m-cones). Unfortunately this thread is only in one thicknesess. Completed ceiling.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To No Idea - I mostly use the two flute router bits (https://cnc-plus.de/en/End-Mills-266/2-Flute-281/Carbide-Two-Flute-Router-bits--2-Flute-End-Mills--CNC-Cutter-Bits-2983.html). Waterway.
- 589 replies
- le gros ventre
- cargo
Thank you guys for all comments and likes. To No Idea: tilting base is specially designed and "home made" for existing Proxxon vice. To dvm27: I have visited Sherline web - this maschine is fantastic, I´ve never seen anything like it before. After about one week all ropes are finished, cca 190 ropes in 14 thickness. Lenght of one ropes is approximately 180 cm.
- 589 replies
- le gros ventre
- cargo
The spare anchor is in place, I did all the other anchors during one work. Now I take a break "from the wood" and start making the ropes.
- 589 replies
- le gros ventre
- cargo
The remaining deck beams have been added, a spare anchor remains to be added and the interior of the hold will be complete.
- 589 replies
- le gros ventre
- cargo
Hi Derek, thanks for reply. Information at the beginning of the log I meant that there is no fixed orlop deck. At first I thought I wouldn't install this removable orlop deck at all, but later I changed my decision. I added the barrels to the water hold and covered the whole with the remaining deck beams.
- 589 replies
- le gros ventre
- cargo
