marsalv
NRG Member-
Everything posted by marsalv
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
To No Idea - I mostly use the two flute router bits (https://cnc-plus.de/en/End-Mills-266/2-Flute-281/Carbide-Two-Flute-Router-bits--2-Flute-End-Mills--CNC-Cutter-Bits-2983.html). Waterway.
- 589 replies
- le gros ventre
- cargo
Thank you guys for all comments and likes. To No Idea: tilting base is specially designed and "home made" for existing Proxxon vice. To dvm27: I have visited Sherline web - this maschine is fantastic, I´ve never seen anything like it before. After about one week all ropes are finished, cca 190 ropes in 14 thickness. Lenght of one ropes is approximately 180 cm.
- 589 replies
- le gros ventre
- cargo
The spare anchor is in place, I did all the other anchors during one work. Now I take a break "from the wood" and start making the ropes.
- 589 replies
- le gros ventre
- cargo
The remaining deck beams have been added, a spare anchor remains to be added and the interior of the hold will be complete.
- 589 replies
- le gros ventre
- cargo
Hi Derek, thanks for reply. Information at the beginning of the log I meant that there is no fixed orlop deck. At first I thought I wouldn't install this removable orlop deck at all, but later I changed my decision. I added the barrels to the water hold and covered the whole with the remaining deck beams.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Thank you guys for all your likes😉. To hdrinker: CNC milling maschine was used mainly for cutting of frames. But the beveling had to be done manually. Beveling of hawse timbers was somewhat more complicated. Aft, all the bulkheads are now completed.
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
- 589 replies
- le gros ventre
- cargo
Hi druxey, all woods will darken after waxing, but there will still be a visible color difference between white, black and brown wood. Deck beams are completed, it remains only the last aft one and the deck level breast hook.
- 589 replies
- le gros ventre
- cargo
Thank you Johann, I have to say that you have no reason to learn from me becouse your work on La Créole is fantastic. I use "white" hornbeam and the "black" hornbeam for the bolts. Black wood simulates iron bolts and white wood the treenails.
- 589 replies
- le gros ventre
- cargo
