marsalv
NRG Member-
Everything posted by marsalv
Pandora by marsalv - FINISHED - 1:52
marsalv replied to marsalv's topic in - Build logs for subjects built 1751 - 1800
Hi Greg, it was not so complicated, it just needed enough patience and time . Next task - the shrouds. -
Thank you to all for the comments and likes. Tha last rigging on the bowsprit - main stay collar and bumkin shrouds - is done. Now I start the works on the shrouds. -
Thank you Albert. So finally is here a moment when I started the installation of masts and related standing rigging. As first I installed bowsprit and the following ropes: gammoning, inner and outer bobstay, bowsprit shrouds. At the same time, I have prepared footropes with a netting, the picture shows only temporary attachment, the final attachment will occur after the installation of the stays. -
Thank you NMBrook, it is nice to see you again back on the forum. Rest of yards is completed with all blocks and prepared for installation. -
Your welcome Harley. So all blocks for the yards are prepared and I started to install them on the yards. There are only two yards completed in this moment, but I hope that the works will go faster now. -
Hi Johann, it is nothing difficult. Thimbles are made from brass tube 1,0x0,1 mm (resp. 1,5x0,1 mm). The tubes are cut to lenght cca 0,8 mm (resp. 1,2 mm) (see first picture) and then they are slightly compressed on both sides by a punch and hammer. So blocks for masts are prepared and partly installed on the relevant masts, now I will continue with the blocks on the yards. -
Thank you guys. Toms10 - I'm very glad that my log serves as an inspiration for other modellers. And now a few more pictures - installation of blocks on the lower masts. -
Thank you guys for compliments. Before installing the masts on the model, they must be fitted with different blocks. I started with installing the blocks under the tops. -
Hi Johann, thanks for the link. Your method is much better as mine. I have to find time and thoroughly read your log because it is GREAT!! So finally I finished al mast parts and now is time to prepare for rigging. -
Albert, Dirk - thank you for comments. Dirk, I spend most of my time building a Pandora and I do not have much time to watch other posts, but I must say that your work on USS Confederacy is also wonderful. Lower masts are finished with colouring, tops are completed by deadeyes and railings. -
First of all I would like thank you all for very very nice comments - I am very happy for that. And now the answer for Greg´s (dvm27) qustion: the wooden woolding hoops are made from very thin pear plank - dimesions are 0,4 x 1,0 mm. This plankmust be thoroughly moistened in water and then it can be carefully wrapped around the corresponding round rod. Both end of the planks are fixed and after drying (preferably overnight) you get a wooden spiral from which the individual rings are then cutted - see picture. And now a few new photos - lower mast tops. It remains to add rail, deadeyes and blocks - it will be made after coloring. -
Thank you guys, the answer to the jdbondy question: See the picture in my post dated 4 August. There is an aid tool which I use to make networks. After thread stretching is important thoroughly to overlap the netting with diluted PVA glue. After drying is possible to cut the netting into the required shape. Work is now slower, thanks to my own stupidity, I often have to make some parts agani and again. Some pictures from lower mast production for today. -
Thank you guys for kind words and likes. After some week I finished with yards production. Now is time for masts and tops. -
Roter Löwe 1597 by Ondras71
marsalv replied to Ondras71's topic in - Build logs for subjects built 1501 - 1750
Hi Ondras, nice to see you here with the new build. -
To Ilhan: Parts of hammock cranec are made from different messing tubes and profiles. Individual parts are then soldered together with silver soldering paste. Installation of hammock nettings and swivel guns - the last part of the hull at this moment. Now I am going making the masts, tops, yards etc. -
To gorington: The caulking is simulated with black paper glued to the planks. Steering whell - the quarter deck is finished. -
Thank you Nils. I added some small items on the qurter deck, now remains the last item which will be placed on the quarter deck - stering wheels. -
I forgot to answer the Tigersteve´s question - brass blackening is made with blackening agent for Tiffany technology (http://www.vensy.cz/vensy/eshop/12-1-Tiffany-technika-cinovani/31-2-Chemie-pro-cinovani/5/345-Patina-cerna-tiffany-technika), warm solution 2:50 (water). The next one is binnacle.
