DaveBaxt
Members-
Everything posted by DaveBaxt
First question . Do I need one, If I do what for? What sort of wattage is required and what else do I need ? ie type of solder, flux etc . I am currently on my second model but my first period ship The Bounty. I have been informed that this model by Amati does not require any soldering, however I think it would have made a better job than gluing the brass rings to the cannons.
Brass rings for rigging on HMS Bounty
DaveBaxt replied to DaveBaxt's topic in Masting, rigging and sails
A I haven't been very specific eye bolts then rings. Its the rings I am worried about. Cheers Dave -
Although I am currently still a way off rigging. I have noticed the brass rings that secure the ropes to the deck are very soft and would not take much to open them up again as you do when attaching them to the copper eye pins. It has occurred to me do they need a drop of CA glue to prevent this or should the lines not be too taught to make this happen ? I do read on here though that some people do not like to use CA glue anywhere.
Several attempts at pin racks in the centre, The kit says 1 mm x 5 mm walnut but I kept splitting the wood when drilling . Eventually tried 1 mm ply and got away with that for the single pin rack as you can see in the photo. Unfortunately I did not have enough for the square pin rack that fits around the forward mast so have used 1.5 mm x 6 mm and used overlapping joints as in "Ship Modelling simplified" by Mastini.
Proud owner of a Dremmel drill stand
DaveBaxt replied to DaveBaxt's topic in Modeling tools and Workshop Equipment
Thanks guys for clearing that up. and I now see where you are coming from . If I can get my money back I will. Until then I will have to make do with a power drill and sand paper or perhaps a mini plane as I have one of them. I do have some spare dowel to practice on so hopefully I will be able get the hang of it at some stage. -
Continued with deck fittings forward including the ratchet mechanism on the windlass and the windlass itself. All in all a very enjoyable part of the build especially after rigging the Cannons. After checking the diameter of the masts were what they should be it was necessary to remove material from the glands at the bottom where the mast go through the deck .Sorry I do not know what the name of this is. I am pretty much ready now for the Anchor rope from the forcastle to the hold. I also tried painting the windlass drum and give it a weathered look.
Thanks every one I clearly did not think this through properly. I also need to try this out and hope that as it is made by Dremmel, I should at least be able to use it for drilling. As regards the making of masts it was not my idea to hold the mast in the Demmel but to hold some kind of small rotary sanding tool and hold the mast in my hand. I suppose it would be just as well to hold the mast in an ordinary electric drill and use the Dremmel in your hand with one of Dremmel's sanding attachments. -
Not sure if this should be under tools or masts and rigging. AS the title says I am now the proud owner of a stand for my cordless dremmel in the hope it will make life easy when drilling those rails for the belaying pins. What I was delighted to see was that you can swing the stocck 90 degrees so the dDemmel is in the horizontal position. I am shortly approaching the time when I will be tapering the masts and spars and wondering if anyone uses their Dremmel to taper masts in some way and if so how do they achieve this? Just for the record I am starting with Walnut Dowel
Thanks shipman for letting us know about that. Interesting to know if that happens even when unopened.
I think we discussed this earlier and I ordered some liver of sulfur then which is before I ordered the Brass black I think I will have to chase up ebay. Should have been here before now. Thanks again for your input.
Question regarding the base of the mast
I Thanks Allan. I will check the diameter of the mast just in case they are bigger than 8mm as I have no idea. I only read something about reducing the mast diameter where it enters the deck Ship Modeling Simplified by Mastini but I think that was if the holes in the deck required drilling. For the record the mast were quite tight in the holes in the deck certainly after planking the deck so I filed out the holes in the deck to make a loose fit. Not slack so just hoping this would be ok. Best regards Dave -
John Thank you for your reply and sending that photo ( nice job by the way) That looks like its worked great on the painted area. Fortunately most of the areas I have done so far have been painted. I have started dipping all of my eye bolts and rings in Brass Black and it even works on the copper although takes a bit longer. I also found out that this stuff is pretty deadly on any tools that are not stainless steel. Shouldn't have used those pliers for lifting things out of the blacking solution.
Thanks for that Allan and I think I will make sure I have the required marerial before tackling the work. I will see if I can get my hands on some close grained wood for my next model. In the mean time I will probably go for the cast ring and just paint them. Do I need to file out the holes or can I just narrow the mast slightly to fit through the ring? I must thank you once again for all your help. I really do want to eventually do things the correct way but at present just want to continue with the basics and eventually get more involved with my second and hopefully more models of this type. Best regards Dave -
Ok Alannanyed I get what you mean and I understand what everyone is telling me and I appreciate all the help and advice I have been given. So How to I make a ring large enough to fit over the mast without a lathe. Is this something I need to make out of a block of Walnut ( not supplied with the kit and do not have at hand) I still think as this is my first model of this kind and only my second model ever I am jn two minds whether or not to take the easy option and just try and get her built The guy in the Amati video just used the rings supplied in the kit and he had some pretty cool ideas and as far as I can see made a excellent job of building the Bounty. -
Wonder why they didn't have some kind of gland with heavy greased packing rapped around the mast as that would be the easiest way to keep the water out .Pretty much how they had internal glands on shaft,valves etc. Just a thought but could br way off base. -
Does using the wedges make it easier to step the masts. The rings are very ornate and although not acurate they kind of go with the Cannons. -
Sorry I don't know what the metal ring fitted to the deck where the mast goes through the deck. I am currently in the process of fitting everything to the deck ,working my way from aft to forward and from inside to outside. Before I go onto surrounding the areas such as more racks for the belaying pins I thought I would now add these mast rings as I think the access would be easier doing these now. The mast fits snug through the deck but is too tight on the mast and it will be necessary to taper the mast to fit into the ring. If I fit the ring now should I taper the mast first or can I do it later after the ring is fitted to the deck. Will fitting the ring now have any effect on stepping the mast later on.Hope this makes sense. Best regards Dave
Including painting and correcting lots of mistakes and also left quite a few I have eventually completed the fitting and rigging of the cannons. Altogether it has probably taken me almost a week to completed. Today I have also moved onto the bilge pumps and capstan. I have also started blackening some of the brass work before fitting to try and make it a bit more realistic. Photos to follow.
Gratings
DaveBaxt replied to DaveBaxt's topic in Discussion for a Ship's Deck Furniture, Guns, boats and other Fittings
This forum is absolutely amazing with some of the ideas. They might be obvious to some people and make a lot of sense. But I have to take my hat off to all of you. Thank you.Best regards Dave -
Gratings
worked a treat thanks shipman. All I need now is to find something that CA glue will not stick to. Any ideas? -
After 3 days working on the blocks and rigging for the Cannon I can actually see the light on at the end of the tunnel. All the work is completed off the ship and now ready to attach the ropes to the bulwarks. As the instructions say the attachment is actually on the bulwark and not the stantions .I think I will make pad eyes instead of eye bolts as I don,t want to accidently drill through the planking I will add another 1 mm so a total thickness of 3 mm before going through the otherside. I will cut the eye bolts to 2mm which should be long enough to be secure.I could just use the stantions next to the Cannons but this will give me very little room for the blocks. here is the work so far. Just for the record I wasted lots of blocks and tried several times to seize the ends onto the rings using black thread before I eventually got the hang of it but it has served me well so should make a better job of the larger blocks on the rigging. Any thought or comments would be welcome.
Hello guys.What a coincidence I just ordered some of this the other day and just received this yesterday and have only just noticed this post. I have started fitting some blocks to the cannons and have already used some brass rings and copper eye pins. my question is can this stuff be added to parts which have already be fitted. I don,t mean the rigging just one or to places using a cotton bud stick. Would there be any staining to surrounding areas? Best regards Dave
I have taken the plunge and decided to paintsthe cannons Iron black and the gun carriges yellow orcre as this the colour which came with the kit. I was also supplied red orcre but I believe is used on the carrages fn the Bounty but think this a bit dark for my needs .I thought I would try a bit of weathering by using some brown acrylic paint and applying using a very stiff brush with very littlle paint on itth the yellow orcre. I don,t believe it is perfect by any means but I am satisfied enough not to have regretted painting the cannons in the first place. I have also ordered some brass blackening for the numerous brass rings with the kit. Here is a photo of the completed paint job and looking at it closely I can see there are one or two places need touch up. Any comments would be appreciated. Best regards Dave
