Zero
Members-
DKM Graf Zeppelin by Zero – FINISHED - Trumpeter - 1/350 - PLASTIC - Mk.1 Design
Landlubber Mike reacted to a post in a topic:
lmagna reacted to a post in a topic:
mtaylor reacted to a post in a topic:
Thank you! Hope you like the camo:) The figures are from the North Star. It's been a long time to come to the forum. The ship is completed:) I will post it on the open competition day:)
- 33 replies
- graf zeppelin
- trumpeter
Beef Wellington reacted to a post in a topic:
Happy New Year to you all! It's been a long time updating this post. Buying on painting the whole ship and the figures. Thanks to you all, the whole ship is almost complete.
- 33 replies
- graf zeppelin
- trumpeter
- 33 replies
- graf zeppelin
- trumpeter
Thank you! I always refer to your work before I did my part.
- 33 replies
- graf zeppelin
- trumpeter
Zero reacted to a post in a topic:
The boats from Trumpter are definitely disaster. The cockpit from those boats are solid square. I decided to use Veryfire for the replacement. 🤗
- 33 replies
- graf zeppelin
- trumpeter
Really appreciate all of the supports! That really cheers me a lot. Billion Thanks! I have checked the 3D Kagero and found that the railings(?Not sure how it should be called) is thinner than what the MK.1 design provided. And here comes the holes drilling challenge again
- 33 replies
- graf zeppelin
- trumpeter
First time trying on the preshade of the planes. It take me hours but the outcome seems not bad. The MK.1 PE set does not include the canopy while the Infini does not provide details PE and weapons....
- 33 replies
- graf zeppelin
- trumpeter
Here are the 10.5 cm SK C/33 guns. The above one is Trumpeter with MK.1 PE and the other one is Veteran. The details of trumpeter is okay but you might choose Veteran for more details.
- 33 replies
- graf zeppelin
- trumpeter
- 33 replies
- graf zeppelin
- trumpeter
Adding details for the bridge. (Wires, ducts and vents) Sonce I am making non-combat status scenario, the doors had to be drilled and keep it opened.
- 33 replies
- graf zeppelin
- trumpeter
Sure:) After masking like the pictures below, you may spray the mr.hobby surfacer for few times(3 to 5 times). If you wanna get a rougher lines, you can use the 400/600 ones. I used the 1000 in this model.
- 33 replies
- graf zeppelin
- trumpeter
- 33 replies
- graf zeppelin
- trumpeter
It seems that I have sanded too much and the alignment of the two catapults are imbalanced...One is higher and one is lower💀
- 33 replies
- graf zeppelin
- trumpeter
- 33 replies
- graf zeppelin
- trumpeter
The PE was so hard to bend. Therefore, I needed to burn it with a lighter so the PE became more flexible to work with. The gap between the PE was filled with putty.
- 33 replies
- graf zeppelin
- trumpeter
