Everything posted by jct
Just wondering if your wiring material is hollow, looks like small tubing in the pics, if so you may be able to get it to conform to shape by inserting a small diameter solid wire into it and then bending, I've always scratch built my plug wires from small diameter solid core electrical wire and found that leaving the wire in the insulation makes them much more manageable, minimizes the memory factor, if you will.
THX Denis...shoot I remember when the AMT 3in1 kits cost a buck...probably dating myself there the chassis mod is one of those deals where a single change leads to multiple down the road...a lot of trial fitting and cutting to get it all right, it makes a real difference in the look though, you'll really notice it in the finish pics. I should have known the decals were gonna be brittle they've been stored to over 15 yrs, from everything I've read about the decal solution I ordered it should do the trick, but at least the paint job is simple enough to duplicate...got lucky having the right colors in stock too
Thanks much for the likes and the great participation on this log... After masking I airbrushed the French Blue...my place is over 100 yrs old and we still have the hot water rads, they are great for cooking a paint job...this will bake out for a few days then the strips masked off and the dark blue shot Darker blue on a stick
Thanks to all for the likes and comments With the body lower the injector hat needs a little room in the interior shroud...Just cut the old one away and added about 1/8 inch to the it's height clipped the final roll cage loop down as well and focused on finishing the chassis it still needs a little touch-up work When I went to decal the body I discovered that the decals were very brittle. you can see what happened, So I've ordered Micro Scale Liquid decal solution to prevent the others from breaking up, I'll airbrush the strips on the body, they are a two tone blue...French and Ford engine, both of which are in my enamel stock
THX...the new funny's are a lot more areo, but I lean towards the old stuff, glad to see the nostalgia division catching on like it has, I like the look of the original car...well almost anyway the "hoses" were fairly easy to make, I've a spool of the stretchy decorative cord in silver, just hit it with dullcote and add clear blue and red to simulate the fittings, pretty convincing is smaller scales...don't know how well it would work on big stuff
Here's the link to the Mustang log for those interested https://modelshipworld.com/index.php?/topic/19936-lew-arringtons-brutus-funny-car-in-124/
After following Popeye;s Funny car build for a bit I decided to drag out something that has been on the back burner for many years...Lew Arrington's Brutus Mustang...this is converted from the old MPC Blue Max kit, which was based on the old Revell funny car molds, a lot of work was done to reconfigure the hood ...removing the hood scoops and filling and smoothing the hood, all the chrome plating has been stripped, and the blower hat hole was also reshaped for the next step... ...as most folks who've built the old Revell Funny cars kits know, they sit way too high, both body on the chassis and ground clearance wise, pics of the lowering process to correct the stance follow the rear end mounts were relocated to lower the rear end Then the tins were filed to allow the body to sit lower And lastly the hinge point at the back was cut away, 1/16 inch of material removed, and then glued back together and reinforced With the stance change the stock seat will not fit into the roll cage as the rear end sits higher...I sectioned the seat at the top just below the tin section, about 1/8 inch removed, the tins were then glued back on started populating the chassis Did a little plumbing, added the fuel tank and main and return lines, not sure how correct it is., but it fills the space. The engine has been detailed with scratch built fuel lines, butterfly control valve and injector hat lines, along with plug wires, not gonna do much more in the way of detail here as I plan to display this with the body down...no sense correcting the stance if she's gonna be flopped Then did some work on the rolling stock, I had ordered Bear claw rear wheels as that is what Lew ran in 73, but one got misplaced so it's kit wheels in the back
HI All, I haven't updated the log for a while...I've taken a bit of a brake from the Hanna build for a couple reasons...firstly the shop was flooded from a catastrophic water heater failure...things were at snorkel depth there for a while but all is well and drying out now...will still be a few days/week till I can get everything sorted and back in order. No fear the Hanna build will continue... so while I wait I'm finishing an old Funny Car I started about 15 plus yrs ago, inspired by Popeye's build https://modelshipworld.com/index.php?/topic/19775-revell-revellution-funny-car-116-scale-by-popeye-the-sailor/, , Thanks for your time and attention
Model Shipways paint on plastic
jct replied to jct's topic in Painting, finishing and weathering products and techniques
Thanks Kurt...I've always used Testers and Model Masters exclusively till I made the switch to acrylics...for airbrush I've too have relied on Badgers line Thanks for your input -
Thanks all, may have to drag out the enamels...
