Freebird
Members-
Everything posted by Freebird
BTW - Thanks for all the likes! Much appreciated! Best Regards …. Rick
- 155 replies
- Medway Longboat
- Syren Ship Model Company
Had a little time to accomplish a task or two, so I decided to tackle some metal work. Like most items on this project, the metal work is something I’ve never done. Took 3 tries to make half mast hoop, still needs a little tweaking. The straps weren’t too bad, again took several attempts to get the holes drilled in a straight line that was centered. Not perfect, but being I was running out of metal I had to quit while I was ahead. Next up is to blacken the brass. Merry Christmas to All! 🎁🎄 Best Regards …. Rick
- 155 replies
- Medway Longboat
Just catching up on this build, beautiful! Quick question - will the figurehead be available separately? Merry Christmas to all! Rick
- 488 replies
- Indefatigable
- Vanguard Models
Haven’t had much time to work on the longboat. I added the frieze, added some filler to fill the gap in the cockpit and added a few more coats of paint. The knees for the thwarts have been fitted and are being painted, several more coats are needed. I really like Chuck’s technique of applying many coats of thinned paint, results are really nice. The transom frieze was very difficult to size, I’m not really happy with it. I may redo it. Best Regards …. Rick
- 155 replies
- Medway Longboat
Thank you, Todd! It’s been a fun and challenging build. I too hope that Chuck will cut a few more. Best Regards …. Rick
- 155 replies
- Medway Longboat
Started to add some color! Very happy with the shade of red, but not happy with the texture, it’s too flat and needs just a little gloss. BTW - I’m using Chuck’s painting technique, this is only 2 coats. The aft thwart and cockpit seats are just posed for the pictures. Cheers …. Rick
- 155 replies
- Medway Longboat
Here’s a couple of pictures, still have to fix the gaps on the seat. I’m way out of practice, I couldn’t for the life of me make the slots tight around the frames. Cheers …. Rick
- 155 replies
- Medway Longboat
Excellent! Thank you! Cheers …. Rick
- 155 replies
- Medway Longboat
Chuck, quick question. Before I start on painting, is it ok to put a coat of WOP on? Cheers …. Rick
- 155 replies
- Medway Longboat
Ahoy All! After being a landlubber for the summer, I’m back! Work has once again resumed on Medway. I will say that my skills have tarnished some, not unexpected. When I left off, I had installed the starboard riser. This weekend I installed the port riser, made/fitted the last thwart and started on the cockpit seats. I still need the nail the port riser and add some WOP. it feels great to be back in the dockyard! Pictures to follow. Cheers … Rick
- 155 replies
- Medway Longboat
Tim, Thank you for the intel! Far too simple! Thanks again! Best Regards …. Rick
- 79 replies
- Fifie
- Victory Models
Tim, Beautiful, beautiful model! Just one question. I understand your method of blackening the wood, but how did you do the blue? It’s so totally awesome! Best Regards …. Rick
- 79 replies
- Fifie
- Victory Models
More progress, nails applied and drying on starboard side and risers clamped to start shaping. Best Regards …. Rick
- 155 replies
- Medway Longboat
That looks very nice, Bob. The wide parts are a bear to work due to their thickness. The other laminated floorboard parts were much easier to work. BTW, those belaying pins look great! Another task that I’ve never done and will be interesting when I get there. Fine job you’re doing! Best Regards …. Rick
- 217 replies
- medway longboat
Bob, thank you for the compliment and thanks for all the likes. The 1/16” thick floorboards were a real bear to work into shape, that was a full day’s effort for just one piece. Not complaining, just my experience. I also had to touch up the fairing near the bow to allow the floorboards to flow better. A couple of the frames were a too little high. If I’m gluing where WOP has been applied, I lightly sand the area so the glue can get a better grip. I'm working on risers and again, being the wood is 1/16” thick, it takes more effort to bend the wood. What worked for me was to wet the wood and clamp it in place and then gently heat it with my heat gun and let it cool for about 15 minutes. Worked pretty well. Starboard riser is glued in place and looks good. Now to get the port side on an even/level with the starboard side. That’s tomorrow’s project. Keep going on your longboat, you’re doing a fine job! Best Regards …. Rick
- 155 replies
- Medway Longboat
Quick update floorboards, forward and aft platforms are in. The 1/16” floorboard was a real challenge to shape and install as was the forward platform. Very pleased though with the results. Going to install the risers next and then add some color. A very satisfying build! Best Regards …. Rick
- 155 replies
- Medway Longboat
Awesome! Thank you for the intel, Chuck! Best Regards …. Rick
- 155 replies
- Medway Longboat
Quick question - what adhesive is used to attach the frieze to the model? Also, before the frieze is cut from the sheet, is any type of clear coat applied to protect the graphics? Thanks for the help! Best Regards …. Rick
- 155 replies
- Medway Longboat
That looks really terrific. You would never know that this is your first ship model. This is NOT a beginner model and you are doing a fantastic job. You should be very happy with the results thus far. Chuck, thank you for the compliment. Many mistakes have been made, but this is expected. I retired a year ago, and have wanted to build a ship/boat model for many years. Now that I have the time it was time to fulfill this desire. Your kit is truly outstanding and I’m enjoying this build immensely. Next up will be your cutter Cheerful, another beautiful model. Your Winchelsea is my goal build though. Thank you for all that you do for us modelers and allowing us to fulfill dreams. Jeff - Thank you. I’ve been following your builds and have been inspired. Diver - I’ve studied your build and have learned a lot. Thank you for kind comments. Best Regards …. Rick
- 155 replies
- Medway Longboat
Thanks to All for the likes! Much appreciated! Quick update. Overall, very, very pleased so far. First ship (boat) project I’ve ever tackled and while I’ve made some mistakes, I’m really impressed. Even the admiral is impressed. Cap rail has been glued into place and shaped along with fairing of the frames. Bolsters have been carved and sanded to shape, took 5 tries for the starboard and only 1 for the port side 😏 and thanks Chuck for the extra bolsters! Exterior has been given 3 coats of WOP and the interior 1 coat. I’m ready to add the sheer strip and to start adding some color. Best Regards ….. Rick
- 155 replies
- Medway Longboat
Chapter 2 completed….. Have some boo-boos to fix once the hull is off the building board. Thanks Chuck for designing such an awesome model! Best Regards ….. Rick
- 155 replies
- Medway Longboat
Chuck, thanks for the idea. Whatever I end up doing, it’s going to start from the inside like you suggest. I first have to get the hull off the building board. I’m almost there, working on the last wale on the starboard side. Has been an awesome project so far! Best Regards …. Rick
- 155 replies
- Medway Longboat
Guys, thanks for the likes and the help, much appreciated! Port side fixed and wales added. Final sanding of the port side accomplished and a coat of WOP applied. Totally amazed at the results. However one issue reared it’s ugly head. Just under the wale, I sanded through the wood (UGH!) . Looking for ideas on how to minimize/hide this. Really need some ideas. Thanks for the help! Best Regards …. Rick
- 155 replies
- Medway Longboat
Gregory, Thank you for the compliment. Making mistakes is all part of the learning process and I’ve learned a lot from reading other build logs and how issues were overcome. This is my first wood ship (boat) project and I’m learning a lot. Quite honestly, I’m surprised at the results I’m getting so far, it’s a great testament to Chuck’s design. I’m really enjoying this build. Best Regards …. Rick
- 155 replies
- Medway Longboat
Next I clamped the wales in place to see where I’m at. Of course the bottom of the wale doesn’t follow the seam of the plank. If I drop the wales to follow the seams, I’ll need to add another filler piece at the sheer. But more importantly, if I did this, the bolster would now be out of whack (navel industry term) with the wales and other alignments would also be off. So I’ve decided to live with the seam below to wales. At least some of it will be covered by the bolster. At least I made the same mistake on both sides so it’ll look even. Best Regards …. Rick
- 155 replies
- Medway Longboat
