Tomasz B
Everything posted by Tomasz B
  1. Very welcome aboard ⛵️
  2. Hi all. Working on ropes attachment and coils... no idea yet where this 2 should be attached to, i i keep searching for solutions 🤯😅
  3. Hi all. Little work done with sail. And finally some ropes glued permanently. I don't know this ropes can be attached this way, i think sailors used everything on ships i believe.so maybe ?
  4. Very welcome aboard. I watched Tally-ho restoration as well. It looks so challenging isn't it.
  5. Very welcome aboard.⛵
  6. Very welcome aboard.⛵
  7. When i upload pictures i just drop them on desktop and drag them over to my post and then place them in between text if needed or on beginning or last thing....
  8. No pictures visible-is it just me or someone else?
  9. Hi Radek, i know it takes long but i cant wait to see finished model. Great build.
  10. Hi. slide in wire (in my case guitar strings, i play guitar so i always have many of them😁) and cut with wire saw.then used sawing needle to open it up if it closed and used dremel diamond cone like file to sharpen it...
  11. When i started planking first layer i did steam bend with my kettle. 😁 and then nailed them to the wooden board with proper shape...time consuming cuz they have to dry ...
  12. Very welcome aboard Ferrus. I wish you best with your build.
  13. Very welcome aboard Michele. Starting your own vlog is the best way to get more help if you struggle with something. Good luck with your models
  14. Very Welcome aboard... Looks so promising, do you planning build vlog ? Hope you are.
  15. Very welcome aboard sir. It's a great community very kind and helpful ppl.. Can't wait to see your models.
  16. Here is my favourite tools i made long time ago (like 20 years old they are) for my card models. this precision screwdrivers was grinded down to shape it like a chisel very flat chisel but works with wood very easy. this needles was cut down and guitar string inserted to push materials out. Finally made this chisels out of high carbon push rods... took me 1 day to make them but worth it...
  17. Meanwhile did this things 🤷 omg doesn't even know how to call it...
  18. Very first is done just one side ,but is very time consuming...
  19. I am thinking of doing martnets this way without deadeyes looks better imho.not sure again is it ok or not
  20. Thx nice to know that how to spot things from paintings.i will bear in mind that . hm i have arrows to 😀
  21. Meanwhile did main sail martnets example how i planning to do it... Anderson book state this may be the correct one for my build. both side of course .
  22. The earliest one with belaying pins is Vasa i think... Not necessarily British ships should be builded same way but most likely back days nation's share they technology or spy them just like now.😁so maybe they have ones......
  23. Thx a lot. I do research but it looks like there is not much about 15th to 16th century ships unfortunately... Golden hind was disassembled on beginning of 1600th so this ship based on technology from 1500-1570. I believe is much easier find information about ships from 17th till now....i try my best...😁
  24. Thx Sir. Yes i was thinking to do it like this, just wasn't sure... Would you mind if i copy part of your rigging and apply it to my ship ? 🙏 Unfortunately andersons book doesn't cover anything before 1600 year... i just didn't know i can do it the way he explained... Martnets should be on both sides of sail or just one side ?
