dsadberry
Posts posted by dsadberry
Thanks again. I appreciate the advice.
Thanks @drjeckl. Yes, I see what you mean. I will work on it some more. And yes, I have been testing the lay with a thin brass strip that work really well.
I have another question. Would you recommend that I attach the keel assembly first, or plank it first? I'm thinking that with the LN at least, that I should plank first, but would like your opinions.
- GrandpaPhil, gieb8688 and bolin
- 3
13 hours ago, Rick01 said:
I don't know if it's due to the photography or not, but it does seem to have a slight longitudinal curve. Noticeable in the first side shot and last head-on shot. If so, at this stage packing out a filler on the inner side of the curve should be enough to fix it. I run a steel straight edge along the keel when I check mine as I fit any fillers.
Basically how I handled mine, I also fitted these items before planking, not after as the instructions indicate.
Rick
You are spot on, Rick! I do see the curve. Thank you so much for catching that. I need to train my eyes better. It may not show in the photo very well, but it looks like the bend is between the 6th and 7th bulkhead. It's early enough in the build that I can fix is as you say. Thanks again for the catch, I really appreciate it
Dennis
Below are some shots of the frame. I tried to make it as square as I could. It looks pretty good to me, but what do you guys think. I also added the first balsa wood filler block. The others should go quicker. I decided to add the fillers first and then do the fairing. I have a couple of questions in that regard: Is it best to use balsa wood? Or should I be using something like basswood? Should I have done the fairing (or at least a rough fairing) before adding the filler block. My thinking was it's best to do the fairing with the filler block, but my concern is that the balsawood is so much softer the the bulkheads and that may cause a problem where I remove too much of it. And finally, I don't think I want to try a rabbet on the keel because there doesn't seem to be enough real estate, but thought I would fair the hull down to maybe 1ml and then when I add the walnut prow, keel, rudder post that I would have my rabbet. What do you all think?
Hi Folks
This will be my first build log and also my first ship build. I chose the Lady Nelson because as @ccoyle mentions, "it has the "three nots" needed for beginners, i.e. not a lot of planking, not a lot of guns, and not a lot of rigging". I am new to woodworking as well so this will be quite a learning experience. I will appreciate any guidance you all can offer in regards to shipbuilding as well posting on this forum.
I have put together the keel and bulkheads. I noticed that the bulkheads fitted loosely and also low, so I shimmed the bottom and one side with index card stock.
- VTHokiEE and Ryland Craze
- 2
19 minutes ago, GuntherMT said:
Welcome aboard! There are a few of us ship-builders scattered around the Phoenix area, but no regularly meeting group/club other than one in Sun City that meets during the workday making it impossible for anyone who isn't retired to attend.
I live on the opposite corner of the city as you, out in Buckeye, but I know we have a couple MSW members in the SE valley area much closer than you.Hi Brian,
Good to know that there are some guys out here on the east side. Hopefully I'll get to meet up with them. Since you're in the valley, do you know any hobby stores that carry wooden ships?
Hello all. I'm a 57 year old guy looking to get into wooden ship building. I live in Queen Creek, AZ, which is in the far southwest corner of the Phoenix metropolitan area (not a big ship building town, that Phoenix ). I have been been all over the internet looking for direction. So I'm very happy that I found this forum!
I've built plastic models cars, planes, and a plastic ship years ago, although I never finished the rigging. I've also built an RC car. But I am definitely a beginner in wooden ship building. That said, I am very interested in learning planking (I have the book, "Planking Techniques for Model Ship Builders" arriving today). I want to build a model with planking, but am unsure which makers or models are right for my first attempt. I currently have the Amati Lady Nelson pending in Age of Sales, but I've read several comments that Amati instructions are very difficult for a beginner. What do you all think? Is the Amati Lady Nelson a good choice for a beginner? What are some other suggestions? Any advice will be greatly appreciated.
Regards,
Dennis Sadberry
Lady Nelson by dsadberry - Amati/Victory Models - 1:64 Scale - first build
Thanks man. I appreciate the encouragement. I am glad I did the bulkhead fillers. Planking start tomorrow! I gotta be honest, im nervous.
