Pete D
Members-
Everything posted by Pete D
Just an observation. If you could change MT47 and MT52 through 180 degrees , should that not correct the issue .
There are in fact 2 sets of blocks . One that hang down on the 0.5mm thread about an inch long , and then 2 at the top mage from siezing a single block and attaching it so that it point up , and will be used when you attach running rigging on all the yards. If you look at my build there is a picture that shows that set of rigging
I did not find any 10mm diam brass ring that are recommended for use for the spanker sail . I made some from the 1mm brass wire that I have . Then attached the spanker sail to the mizzen mast
I have decided to do the sails attached to the mizzen mast next . Just appeared like it was next in line. Started on some of the running rigging for the booms
Then on to the sails . This is a bit daunting as I have never done sails before . I did read about aging the sails , but decided to go with the original as supplied sails. I started with the flying jibs as it seemed these would be a little simpler given the space to be able to work with. Identified , assembled and attached the brass eyelets to the various jib sails. I needed to practice my needlework skills as there appears to be quite a bit in the future . Attaching them to the forestay via the eyelets was not as bad as I thought it would be . Photos of work in progress and completed
The weekend warrior has some updates I have continued to work on the running rigging on the masts and spars
Started on some of the rigging on yards these are images of where they are secured to belaying pins . I have not neatened or cut them yet
I have found that a floss threader comes in really handy when having to thread the blocks and eyes with those small holes that older eyes struggle to see
Continued to attach all the mast stays . Some of the back stays have a block attached , this is the process that I used for attaching the block
I had not seen this as been an issue . In my limited experience I have seen rigging tied to pins and posts . So I sort of assumed that this would be the case. I have reached this stage and this is the result The most right had thread is JT41 , attached between the post and the belaying pin. It seems ok to me , not sure about the purists though . Apologies for the photography
I found the same . I always seem to keep all the offcuts of the timber , pins etc . so I fashioned the eyebolts out of whatever I could . For reference I have shown an original eyebolt and pin , and then eyebolts that were made from the pin as well as a bit of offcut of a short eyebolt . Will require a pair of round nosed pliers . Hope this helps
HMS Beagle by Krupi - OcCre - 1:60
Pete D replied to Krupi's topic in - Kit build logs for subjects built from 1801 - 1850
Looks great , looks like coppering was the way to go -
Just a small update. Managed to complete the ratlines on the upper and lower foremast . Before and after the neatening up process
