Posts posted by JoeHolden
The second planking was pretty straightforward. Following Bob Hunt's practicum, I bought some 1/4" striping tape from the local auto parts store and used the tape as battens to define each planking zone. The tape was moved as each area was planked.
I tried to stagger joints and was successful in that attempt, but I lost control of plank shapes as I turned the bilge and had to 'cheat' a bit to keep strakes running reasonably fair.
After reacclimating myself with the practicum and the kit materials, I picked up where I left off 14 years earlier and glued the rest of the black strake in place. I had the planks cut to length and the scuppers had been shaped, so all that was left was 2 coats of black paint and glue the pieces in place.
I've found on other construction and woodworking projects, that a coat or two of paint before assembly usually eliminates the need to cut a painting line too close to the next color. I'm not worried about the major field, but only about keeping the edges crisp between colors.
The upper exterior walnut planking was pretty straight forward as was the blue painted sheer strake. One more note on painting beforehand. Notice the gunports were painted red with the paint spreading over onto the outside of the hull. When the exterior walnut was added, it immediately created the crisp line I was looking for.
It took a total of 3 days spare time activity to pick up where I had left off years ago, wrap up the upper hull exterior, and prep everything (mostly my psyche) for the lower hull second planking.
Oh, I almost forgot... At some point in the 14 year hiatus, the hull had been dropped and the top of the transom and port side fashion piece were broken off and hastily glued back in place. I began repairs in this area as well.
I purchased the Model Shipways' Armed Virginia Sloop kit in 2006. Since this is my first build and I have no experience with boats, ships, or shipbuilding and terminology, I also purchased the Lauck Street Shipyard practicum for this kit. Actually, I stumbled upon Bob Hunt's website while googling "Wooden Model Ships", and upon discovering the concept of practicums being available to me, a rank beginner, I instantly gained the boost of confidence I needed.
I had worked through the first 2 1/2 chapters of the practicum when life got in the way, and I packed everything away for "another day".
Well, a worldwide pandemic and a retirement date moved up by a few years, "another day" has arrived.
I wish I'd have taken more build photos back then, I'll post what I have.
Chapter 1 of the practicum covered assembling the keel, attaching bulkheads and sub decks, stern and transom fillers and fairing the hull.
Chapter 2 was devoted to planking the hull; finishing prep work, knightheads & timberheads, mast mortise and the first planking.
And finally, I worked through Chapter 3 as far as completing the wales, spirketing plank, inner bulwarks planking and I had just begun installing the black strake when the project was put on mothballs.
This first post will include photos of completed work from 14 years ago with one pic of where I picked up the project on 1-January-2021. Since that time, I've made it a point to snap a few pics every time I'm working on the AVS with more focus on technique this time around. I have spent considerable time studying other AVS build logs, (especially GuntherMT's excellent build) looking for everything from build tips and tricks to color schemes and even tiny details on how one builder vs. another solves different challenges. I hope this log will help answer a question or two for future builders. -
7 hours ago, GuntherMT said:
The AVS is a great kit, I really enjoyed building it (link to log in my signature).
Darn it, Brian! I saw your reply this morning and spent all of my spare time today going through your build log for the AVS. I accomplished nothing on mine!
On a serious note, I'm really glad I took the time to go through your log. I found it both encouraging and intimidating. I'll be following your lead on a few techniques and taking a more amateurish approach on others.
Thank you for taking the time along the way to leave a detailed roadmap for others.- mtaylor, GuntherMT and Ryland Craze
- 2
- 1
Some 14 years ago, I began my first build, Model Shipways' Armed Virginia Sloop, 1768 with the aid of Bob Hunt's practicum. At that time, I was a member here, but under what handle and password has long faded from memory.
Life took a few turns and the whole kit and caboodle was packed up for another day.
That "other" day came 'round just about 4 or 5 weeks ago when I dusted off the box, brushed up on the lessons in the practicum binder, and took a second, hard look at the hull, finished only through the first planking.
After much stalling and procrastination I once again began cutting and gluing. This time, I'm working on the second planking in walnut. The going is slow and deliberate and I already see some of my mistakes, but now I'm ready to get through this step and move on.
I'll post a few pics, first to show where I left off all those years ago, and then some to show the progress I've made in the last couple weeks.
It's good to be back!
Armed Virginia Sloop by JoeHolden - Model Shipways - 1:48
Second planking continued...
