ECK
NRG Member-
Everything posted by ECK
Most of deck done. Now for the problem that vexed me . The stern rails pillars are extremely fragile. The are much smaller than on the Sphinx. The grain also goes across so easily brocken, which of course I did. Multiple times and as a result I had to remove them all and fashion new ones from 3x2 mahogany strip. I drilled holes on top and bottom to pin them in. With paint and all worked ok. Not perfect and clean as the original but much sturdier. Otherwise I would have to have an entire sheet sent from across the pond. Unless you are very close, I think it looks ok. I think the rails and pillars would be best 3-D printed. Another issue is that the pictured cannon assembly in the manual is not the same as the parts with the kit in that the the holders of the cannan are integral to the piece and not something you add later. Assembly is as seen in the HMS Sphinx instructions.
- 22 replies
- Duchess of Kingston
- Vanguard Models
Outer hull done. Next will be the deck fittings. One issue that came up is that the 3D printed dome for the main entry to the stern cabins was way to small for the hole it had to cover so I had to make one out of balsa wood. You can see the side by side size difference.
- 22 replies
- Vanguard Models
- 22 replies
- Vanguard Models
- 22 replies
- Vanguard Models
- 22 replies
- Vanguard Models
I painted the hull early as I like to not tape and turn things over when other things attached that might pull off.
- 22 replies
- Vanguard Models
- 22 replies
- Vanguard Models
- 22 replies
- Vanguard Models
Planking continues With your support, we stay on course: your donations to MSW for 2022 are fully tax-deductible
- 22 replies
- Vanguard Models
- 22 replies
- Vanguard Models
Sanded with a small triangular orbital sander and some hand finishing, looks about right. Plank fits well.
- 22 replies
- Vanguard Models
Have completed the jigsaw puzzle of the hull. A few spots needed thinning to fit (in the stern). Now letting glue dry and will start sanding tomorrow.
- 22 replies
- Vanguard Models
So after 3 days, could not wait anymore and started my next project, the Duchess of Kingston. Quite a bit smaller than HMS Sphinx. The parts fit perfectly, tight, square and feels solid.
- 22 replies
- Vanguard Models
So now the HMS Sphinx is complete. Admiral Cochrane can be seen inspecting it to gie a sense of the 1:64 scale. Until the Indy is ready for purchase, I will keep myself busy with the Duchess
- 73 replies
- Sphinx
- Vanguard Models
Finally, almost there. Only have, sheets, braces, anchors, mount ships boats and railing left to do.
- 73 replies
- Sphinx
- Vanguard Models
- 73 replies
- Sphinx
- Vanguard Models
- 73 replies
- Sphinx
- Vanguard Models
It will be my postponed Christmas present.
- 488 replies
- Indefatigable
- Vanguard Models
- 73 replies
- Sphinx
- Vanguard Models
Thanks, that is actually an interesting design point which I have not seen on other ships
- 73 replies
- Sphinx
- Vanguard Models
Sorry, I meant Driver , for the spanker. Anyway, I do see the directions for all the other yards but the lower ones but have done several in past and have the drawings from Diane so not a major problem.
- 73 replies
- Sphinx
- Vanguard Models
So have some questions. I am about to attach the yards. Interestingly there is drover on this model, on the plans or the finished picture. Not sure why. Also, although I can see lower yard trusses in the finished pictures, there are no instructions about them. I can make them from previous model instructions (ie Diane and Agamemnon) but am I missing something ?
- 73 replies
- Sphinx
- Vanguard Models
- 73 replies
- Sphinx
- Vanguard Models
Masts done and line up nicely but will not set them until yards on with pins. Next is the bowsprit but I usually actually attach it after the shrouds done as I learned in the past my arm catches the tip and breaks it at some point.
- 73 replies
- Sphinx
- Vanguard Models
