ECK
NRG Member-
Everything posted by ECK
Continuing on today, was able to top off the bulwarks and complete the decoration of the stern galleries. Getting closer to the big paint.
- 233 replies
- Indefatigable
- Vanguard Models
- 233 replies
- Indefatigable
- Vanguard Models
Yup, just following the instructions as there usually is a good reason to do things in a certain order (as I have found out the hard way in the past). It is always intersting how the Mark 1 eyeball will often catch the subtle changes in the curve depending on the angle even if they do not seem like much.
- 233 replies
- Indefatigable
- Vanguard Models
Thanks. In the past when I tried the other way ven with a line drawn I did not get the subtle curve between the gunports
- 233 replies
- Indefatigable
- Vanguard Models
A bit more work, painted placed the inner bulkheads, Added the decorative molding. To place it I made a template of sorts. Took a piece of scrap made it 14.7 mm wide and about 5 cm long to run above the wale with a pencil. I then taped above the line to allow me to glue the molding below.
- 233 replies
- Indefatigable
- Vanguard Models
Just following your great instructions and manual/plans. The parts align nicely although a lot of care needed with the 6 mm ones as they break easily.
- 233 replies
- Indefatigable
- Vanguard Models
Spent the afternoon completing the quarter galleries and the stern fascia. Also put in the quarterdeck engraved maple.
- 233 replies
- Indefatigable
- Vanguard Models
- 233 replies
- Indefatigable
- Vanguard Models
Finally finished all the carronades. Undecided yet to rig except for breech line. Also did the 9 pounders The carrondes going into the main cabin need to slide so they can be tucked in during painting
- 233 replies
- Indefatigable
- Vanguard Models
Working on the stern cabins. painted beam you see are for the main cabin. As I had to make 4 carronades I decided to do all of the as air brush makes the painting easier. Also airbrushed the guns and knees for the Captain's cabin.
- 233 replies
- Indefatigable
- Vanguard Models
- 233 replies
- Indefatigable
- Vanguard Models
Looks good, I think I will go the same way with the window colors
- 443 replies
- Indefatigable
- Vanguard Models
Days work done. Assembled the stern beams including all the vertical and horizontal knees. Although will not really be seen, the picture of the gun deck looks great from deck level with the knees in place. Not sure how they would turn the capstan on this deck without removing the posts.
- 233 replies
- Indefatigable
- Vanguard Models
It took awhile to get all the beams and supports ready. As you can see, I lined them all up and spray painted them. Getting rid of the laser burn on the main beams took forever. Unfortunately the laser cutting several of them out must have had a drink or two as the cuts were a bit wobbly and required quite a bit of work to clean up. Hopefully will not affect the fitting of the deck. The char I did not remove from the pillars takes a lot of paint to cover.
- 233 replies
- Indefatigable
- Vanguard Models
If you look at the constitution they do not use hooks on the double block attached to the side. Anyway, I finished my extra work and can now move on to finishing the gundeck
- 233 replies
- Indefatigable
- Vanguard Models
So looking for contemporary examples, HMS Victory upper deck guns, you can see the double and single blocks. I believe these are 24 pounders. Alsop on USS Constitution, albeit an American ship, similar and they are 24 pounders I did not use hooks as scale so small. So from available ships seems like double/single may be for 32 and 24 pounders. I suspect the single/singles may be more for 18 and 9 lbers.
- 233 replies
- Indefatigable
- Vanguard Models
I use the gun rigging recommended in Sphinx and Duchess of Kensington. Also if you watch the 3-D video I posted earlier the below screen shot shows similar rigging although a double block is on the rear
- 233 replies
- Indefatigable
- Vanguard Models
- 233 replies
- Indefatigable
- Vanguard Models
So got a air brush for Christmas, never used one until now . Tried it out on all those gun carriages. made life a lot easier. I liked the insert that ensures they will stay put as my experience with just gluing the wheels always results in one getting loose later. Hers they are with guns dry fitted. For some extra work I decided to rig the 4 guns on each side that can be seen from the upper deck. Once I slide in the barrel later i can hook the loop over the end of the cannon. Used 2 mm single and 2.5 mm double blocks and 1 mm rigging line.
- 233 replies
- Indefatigable
- Vanguard Models
Hope the back is recuperating with the fresh air and scenery.
- 587 replies
- Indefatigable
- Vanguard Models
- 233 replies
- Indefatigable
- Vanguard Models
Found this from another members Youtube link. Nice 3-d breakdown of the Victory
- 233 replies
- Indefatigable
- Vanguard Models
Completed most of the lower deck fittings. Will b e spending the weekend making up the stove an many, many gun carriages.
- 233 replies
- Indefatigable
- Vanguard Models
