Everything posted by cabrapente
ancre Le Fleuron by cabrapente - FINISHED
cabrapente replied to cabrapente's topic in - Build logs for subjects built 1501 - 1750
- 332 replies
- le fleuron
- 64 gun
thought had not put the candles. but the book of 74 guns, is very good. Now if I'm thinking ... I tried to make the sticks, hand brushing and not come out. on the lathe, I can not use guvias because the stick is too long. I found the solution. two pieces, with a hole to fit and glued with sandpaper. with this method, it bounces off the stick very right. at the ends, I put rubbers, very tight, so you do not split ends. gluing one day and in 15 minutes the stick is made. cabrapente- 332 replies
- le fleuron
- 64 gun
ancre Le Fleuron 1729 by rekon54 - 1:24
cabrapente replied to rekon54's topic in - Build logs for subjects built 1501 - 1750
always impress me with your work. thanks for sharing. cabrapente -
- 332 replies
- le fleuron
- 64 gun
Today I received a book dedicated to the rigging of 74 guns. I have been a surprise, because it contains the plans for its construction.- 332 replies
- le fleuron
- 64 gun
Spanish is written in "escuadra". but I think the best definition is carpenter's square. Is it true? cabrapente- 332 replies
- le fleuron
- 64 gun
this is achieved, giving little by little and with some practice. the straight cut, only you can do it with the band saw. I had a small as PROXXON, and the blades cost money . now I have this red which is small, and very good. you can put different width blades
I think the same. of all jobs, 1% use the jigsaw. everything else, I use the bandsaw.
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
angle. is used to give rigidity to the union. I use google translator and does not always work- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
I modified the bandsaw again. Now I've put a "feeding hacksaw" much wider. the cut is perfect. not need sanding. tablitas sac less than 2 millimeters-- 332 replies
- le fleuron
- 64 gun
thank you very much Giorgio. never quite understood the construction process. is the first time I see it so clear. you're still my teacher. cabrapente greetings. -
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
- 332 replies
- le fleuron
- 64 gun
ROYAL CAROLINE 1749 by Doris - 1:40 - CARD
cabrapente replied to DORIS's topic in - Build logs for subjects built 1501 - 1750
splendid wonderful. Thanks for demonstrating that a good job, does not have to be expensive materials nor many tools ... good work is done with the heart. a greeting. cabrapente- 881 replies
- royal caroline
- ship of the line
gary congratulations. I hope to learn to work as well as you someday. is an inspiration to all. a greeting. cabrapente
