Everything posted by Azzoun
So. The portion you're starting with there is rigging the shrouds to the dead eyes. Generally would be dark dark brown or black to show that they were tarred. You're best bet is to attach the shrouds at the top of the mast first, then using a spacer that holds the top deadeye at a certain distance, wrap and secure the shroud to the deadeye. Then rig the deadeyes together like you're doing but use some thread/rope about 1/3 of the thickness of the rope you're using there.. here are some pics that may help Joshua
Hi Will, welcome to MSW. If you're into maritime history, you should consider checking out the Philadelphia Ship Model Society, our next meeting is this Sunday at Laurel Acres park where the membership will be running RC models in the lake. www.PhiladelphiaShipModelSociety.com All the best, Joshua
Anyone out there working on a card model?
Azzoun replied to gagliano1770's topic in Card and Paper Models
I recently acquired a number of paper model kits that I'm interested to take a shot at however everything is in German. Can anyone suggest where I can get English instructions? Or just info in general on the kit? Thanks! -
Jerome, could you advise on where you're located? Our club receives numerous requests that we cannot fullfill. Joshua
It's your model, but I've seen most people use flat black because in small scale, to high of gloss looks out of scale. If it's brass, many of use a diluted blacken solution that will chemically turn the outside of the metal black which can then be polished. These steps should be performed prior to assembling to other parts of the model. What do you think? You enjoying building model ships? Making better progress than I would have expected! Joshua
Congrats! Looks amazing... If mine comes out looking that good, it'll be amazing to see in the water!
Next NRG Conference
Azzoun replied to YankeeClipper's topic in NAUTICAL RESEARCH GUILD - News & Information
Battleship NJ?, Philadelphia? -
Ted, Thanks for keeping us posted. I also own this Nichimo kit and had considered selling it except my kit is mint. My initial intent was to build it as a static model but now have acquired the more accurate Trumpeter version. Now, I've decided I want to make the Nichimo RC as it was meant to be. And so, acquired the hardware but I'll be following your log to the finish line, looking forward to seeing the end product.! Joshua
Your build log is primarily for you to share your work and seek assistance. If there's time between updates, that's more the normal than the exception. Take your time and enjoy the process, there's no hurry. Contribute to your build log in a way that serves you, your audience will chime in as they can, if they see it. If you want more interactions with members on this site, visit their build logs or discussion threads and chime in. You should check out the New London, Connecticut Northeast Ship Modelers' Conference on Youtube. Joshua
Hey Lego! Looks like you're learning a lot on this build and that's the point! Despite anything you may be unsatisfied with, when the build is done, it'll be hardly noticeable, especially to those who don't build models. Keel looks nice and straight now! So, couple fileable items for next time is along with making sure the keel is straight before you start, before you glue in the bulkheads (cross members to the false keel), you'll want to make sure they fit square to the keel. Is your false deck now glued to the tops of the keel and bulkheads now? The back section should align with edges of bulkheads like in the front. You'll definitely want to straighten that out. If you used the white pva wood glue, rubbing alcohol will dissolve the glue and unbind it if you need to re-do. To answer your question, the deck planking should be smooth and flush with the other planks, so you'll need to keep sanding to achieve that. Joshua
https://www.bluejacketinc.com/ build ships for commission, maybe reach out to them? Joshua
