Everything posted by chris watton
OK, the other day, I had my final STL file for one of the two Aubrey figures. Unfortunately, my white primer went a little 'bitty', so doesn't look the best, but you can see the general details - this will be included in the kit: I also decided to design the hand pump bodies and brackets for 3-d printing, as having to make up 6 of these would be a little boring to do for the modeller. My sample Surprise photo etched sheets are also now with me, all I have to do now is finish building up the hull and take pics for Jim to work from - Time is just melting away...
It's going well! The more complex the designs, the longer these things take. A lot of CAD work, so nothing to show as yet. I can tell you the decal sheet is done and has been delivered, and most of the resin print production is done. It is quite a large and complex kit with many pre cut and pre engraved parts, the latter more than even Indy, and all of this takes time to develop. Once I start cutting my final designs and build it up, for Jim to follow, I can post pics of my final prototype build, but until then, it is all just on CAD, on my PC. This applies also to the photo etched files. I need to complete these at the same time the laser cut designs are more or less cooked, and those are 90% done. Rest assured though, this is all I am working on, although I do get side tracked a lot due to having to produce more stock for current kits....
My fault, I really should have added an explanation in the manual. The tiller that you see is auxiliary - there is another tiller arm a little further down the rudder. If you look at the rudder, you can see I simulated the start of the lower tiller arm (a little stub near the top, but lower than the deck tiller arm) If you also showed a picture of the actual rudder, the lower tiller stub would be seen.
Very beautiful job you have done. I have sad many times, I am always amazed at the very high quality of work I see on this forum, and your Alert is right up there!
- 38 replies
- Alert
- Vanguard Models
Very well done, Kevin, you should be proud!
- 443 replies
- Indefatigable
- Vanguard Models
Damn, I thought I put more than enough deadeyes in - I shall add a few extra for future kits.
- 426 replies
- Vanguard Models
- Sphinx
Vanguard MDF
chris watton replied to hornet's topic in Building, Framing, Planking and plating a ships hull and deck
I did already email you with my answer, so here is a portion of that emial I have already sent you you: I have used MDF for the past 18 years, starting at Amati - I am very surprised you did not know this! As I have explained countless time now, for some of the more complex designs, ply was no good, why? Because the tolorances on the thicknesses are comical, they can be anything between 2.7-3.4mm for a 3mm thick sheet. This is OK with very simple kits (just a simple keel and a few bulkheads), but not when so many parts need to slot and interlock well - using ply would be a disaster, as batches can vary a lot in thickness. Also to add, when sanding the bulkheads, it is much easier as the material is all the same. -
Yes, I use CA for the same thing, but that is never left on the model, it is just to make it easier to push the rope through the holes in the blocks.
- 332 replies
- Harpy
- Vanguard Models
Always best to glue as little as possible for masts and rig, because if something is accidentally broken, things are so much easier to repair. I do wince when I read that some use copious amounts of CA on their rigging, rather than a little dab of diluted PVA.. Harpy looking fantastic!
- 332 replies
- Harpy
- Vanguard Models
The pear is 0.8mm, the 0.2 doesn't seem a lot compared to standard 1mm thickness, but it does seem to make a lot of difference when manipulating the sheet to shape, plus there is less need to soak the part before bending to shape. Pear does like to hold onto that water for at least a day or so (sometimes much longer), making it look as though the part is way too big before shrinking back to original size.
I know that Cutty Sark was an Hachette parts work development, which I thought was a shame, as I think that was a great looking model and very detailed. Not sure about Prince, I know I did give it a redesign about 11/12 years ago from my earlier 2002 original, with gun ports incorporated into the hull: Even a fully detailed Royal Mail carriage!
Well, I worked all day today, continuing Surprise stuff. This morning, I decided to make the templates for the fore and quarterdeck bulwarks, which are to be pre-cut. So first, the upper deck and beams were to be removed. My initial idea was to do the same I did for Indy, with most of the outer sides planked. However, I could not get the thought out of my mind just how nice the sides would look if they were pre-cut and engraved, with treenail detail - that would look great when painted ochre (or just varnished). So, with this in mind, I made a template for the whole of the hull side down to the top of the main wale line (or in Surprise's case, where the planks get thicker). The pics show the end result of a day’s work, with many templates laser cut in white PolyBak, with each successive template (and there were many) tweaked a little more until, eventually, the final template is cut in the material that will be used in the kit, pear, shown in the pics. There was no warping to the undersides near the bow, and curved around very nicely on my disposable 'mule hull' The downside to this, and the reason I initially dismissed doing this, is cost (0.8mm pear sheet needing to be 800mm long and 4 required just for the outer hull) and time. It will increase the overall cost to the kit. But it does mean planking, like on the smaller kits in the range, is relegated to the bottom half of the hull only, with all upper sides being completely pre-cut and laser engraved. It also means I can work slots into the bulwark sides for the fore, main and mizzen channels, these worked very well for the new Speedy and Harpy. I hope I have made the right choice.. Oh, for the rudder fixing, I am doing the same as I did for Indy, with 3-d printed gudgeon and pintles that simply slot into the rudder and rudder post, I do very much like this method as it is both simple and looks accurate.
