SiriusVoyager
Everything posted by SiriusVoyager
  1. Thank you Chris and Greg! I am going to take 2-3 weeks off to work on some projects around the house. In the mean time I think I will make some decking to practice some finishing and weathering. The next boat will be the Occre Palamos. I snagged it on clearance for $60 and it seems like a good next step.
  2. The last step was installing the jib and adding the last few lines and tidying up a few loose lines. The jib was easy to hoist. The instructions mention that if the rings are too difficult to attach to the fore stay and the jib that it can be tied on. I found the rings to be one of the easier aspects of building this model. Simply open with small pliers or tweezers and they can be pinched closed with finger pressure. After that it was simply finishing the rigging and tidying up the lines which is fairly clear from the instructions. The only issue I had was that the jib halyard wouldn't fit over the cleat so I tied it down on the samson post. I did find that I ran out of .7mm line for some reason and didn't have enough for the topping lift. Fortunately there was plenty of extra line leftover from the pram. And there is the finished model, with all of its flaws, frustrations and lessons learned. I don't think anyone will confuse it for an airplane so I am satisfied. Thanks to everyone who gave advice and encouragement!
  3. Thanks @GGibson! I bought some alligator clips and forgot I had them. They probably would have worked well. I will have to remember that for next time.
  4. The mast is a bit easier to install than on the pram since there is internal structure to hold it upright and in place. I started making the eyes for the fore stay and the bobstay turnbuckles after the lines were attached. This wasn't an ideal method as it was difficult to control the tightness of the lines. Success! Except that I tied the fore stay to the jib halyard eyelet rather than loop it over the stop cleats. DOH! For the remade fore stay and the back stays I clamped the lines down and made the eyes on my work mat. Remaking the reef points earlier caused me to run out of .4mm line so I used some navy blue thread for the back stays. This method of making the eye splices worked much better. They were easier to make and the tightness could be controlled at the knot rather than by creating tension while creating the eyes. Be careful not to glue the eye splice to the work mat. Much better.
  5. I had the same problem with the stem not being flush with the deck. I cut a small piece of scrap to fill in the gap. As far as the transom and the deck lining up, I think the deck is mostly correct based on the where the mast goes. I do remember having to sand down quite a lot of the transom to get it to fit. I can’t tell from the angle if that is a possibility on your boat.
  6. I am pretty sure my problem ended up being that the spine wasn’t perfectly straight, and the bulkheads not perfectly square. I think as long as dry fit each strake to the previous one and adjust the fairing accordingly your planking will be good.
  7. Welcome!
  8. Welcome to MSW
  9. Welcome!
  10. Thanks! Hanging the lines off the edge of a table with weights is a pretty good idea. I will keep that in mind for next time.
  11. Thank! I’m definitely learning a lot on this build and maybe more importantly, learned what I need to research for the next build. Hopefully that one will be vastly improved. I do now have about 178,946 black beads that may never be used for anything else now haha!
  12. I didn't even realize that posts could be formatted like that. Looking good. I'm glad fixing the transom worked out for you!
  13. Making the main sail was fairly straightforward. The trickiest part was the reef points. On one side of the sail I made the reef points as the instructions stated. I didn't like the method. I soaked and stretched the line, but still had a hard time getting the line to be straight. It was also kind of annoying cutting a bunch of one inch pieces of line, then trimming them down to 3/4 of an inch once attached. For the other side of the sail, I soaked the line in diluted white glue, then clamped it down while pulled taught to dry. The line stayed straight and was easily cut to the final length of 3/4 of an inch and were much easier to attach to the sail. The mast hoops took a bit of time and patience to attach but was otherwise straight forward. I did have to attach a couple of the rings twice because the small gap allowed to line to pass through. I would recommend welding or gluing the edges together to simplify the process. It was time to attach the sail to the gaff and the boom. And the gaff broke again... I fixed the gaff again and finished getting the main sail attached. I wasn’t sure how much line to use so I estimated 3x the length of the head, which was just barely enough. For the foot I used 4x the length of line and it was much easier to work with. I found it a bit annoying that beads can be added for realism, but aren't included with the kit. It doesn't mention a size and the beads I bought were a little too big.
  14. The mast, boom, gaff and blocks are done. I coated the blocks and the mast hoops in a thin layer of shellac in the hopes that it will prevent the copper wire from corroding. They were all pretty straightforward to make, except for the gaff, which I ended up breaking twice, once at each predrilled hole. I only have photos of the first break. I also learned at this time that superglue does expire. It was quite frustrating trying to glue the pieces back together and having it not stick at all. Fortunately I had other superglue available. To get a stronger bond I sanded two sides flat near the break and glued on a couple of small pieces of scrap wood. I then filled in the little gaps with wood filler. After some sanding and painting, it turned out ok. I am glad I didn't have to carve out another gaff.
  15. Welcome!
  16. I remember the issue with the false stem. I think you are supposed to make one with some scrap wood or one of the supplied strips. The instructions don’t really address it, but it should be doable from the blueprints in the front. As far as the transom, if you are using white glue, isopropyl alcohol does a pretty good job of releasing the bonds. You may be able to fix it without having to undo all of the planking.
  17. Welcome, i'm looking forward to the build log.
  18. Looks like you are off to a good start. Those rolling bevels can be tricky on those thin strakes, but don't stress about them too much.
  19. Unlike in the Pram, we have to make backstay chainplates out of a strip of brass. As I read this, I assumed chaos would ensue. It actually wasn't too bad. Fortunately I do have a torch to anneal the brass. I used my little finger drill to make the holes. It wasn't as difficult as I thought it would be, it just took a bit of time and elbow grease. Maybe too much elbow grease since I broke the bit. The most difficult part was centering the bit over the brass strip. I drilled the larger hole at the top of the strip first. There is a little drawing of the plates in the instructions so I simply measured the distance between the holes to find the distance for the next drill spot. I then drilled that hole, then used snips to cut the plate off of the strip. Repeat for the second. A little filing, sanding and polishing and they turned out ok. When I went to install the plates I realized that there was a bit too much brass below the nail hole, so I had to trim them down a bit. I don't like the nails that are supplied with the kit (left) so I swapped them out with some brass sewing pins (right). Installed. The instructions say to bend the plate 20 degrees now, but I will do it when I install the mast. I like how the sewing pins are more flush than the nail would have been.
  20. The rudder, tiller and traveler are installed. The tiller and the rudder were easier to install than I had anticipated, and they actually work! I couldn't get the brass rod for the traveler to bend at exactly the right spots so it isn't quite 90 degree bends, but I think it is fine. The camera angle makes the traveler look cockeyed but it is straight. The fairleads and the bobstay eyelets were easy enough to install. The trail boards and the bowsprit are also done. I decided that I didn't want to use the supplied design for the trail boards, so I just tried to match the dark gray of the cabin roof. I had to read the instructions for the bowsprit multiple times, but once I understood what it was doing it made sense. The photo below has the backstay chainplates installed, but I will talk about those in the next post.
  21. I’m working on the third boat of the series right now. I definitely need a lot more practice and experience before I feel confident enough to jump into something expensive. I ended up finding a kit on clearance (50% off) that I liked, which will be my 4th boat. Depending on your budget and how you feel after the third boat, that may be something to consider. Of course make sure you get something that interests you, that is definitely the most important aspect of any hobby.
  22. I painted the hull gray, dark blue, dark gray on the top of the cabin and golden brown on the cabin hatches and inside the cockpit. I wasn't very happy with how it looked initially. After some discussion at home it was decided that it was too matte so I decided to add a coating of shellac and I think it looks okay now. I forgot to take a photo prior to the shellac. I think I would have preferred white rather than gray now that it is done, but for now I am content with it's appearance. It was also mentioned that looks like a Detroit Lions boat and now I can't unsee it. I will definitely be investing in some higher quality masking tape for my next model.
