Jolly Jo
Everything posted by Jolly Jo
  1. Thanks Mark. It's basically double cooked linseed oil with pine extract from the German manufacturer VLVR
  2. The bulwarks got raised as planned after the third gun port was cut. As the oak strakes were wider than the bulwarks I had to cut and sand them to the right width. After repainting the bulwarks the walnut cap rails could finally be glued on and oiled.
  3. Good job Mark, the bend looks really good! As an old the saying goes: The better the bending, the less the sanding
  4. Blackened the barrels with burnishing gel and built a carriage prototype from oak today. The wheels are from stained 4 and 3 mm beech wood as I didn't have any other at hand. As the oak didn't stand out much from the deck I decided to paint the carriage red and also sand the tail piece. The wheels are darkened in Photoshop to decide whether to paint them black or go for walnut. I'll order some walnut.
  5. That's what I thought about my first first planking as well but it doesn't have to be perfect to fulfill it's purpose anyway. And it is likely to look much better than you think after sanding. Good luck!
  6. Hello all, today's work was making a mockup for playing around with bulwark proportions and different aspects of armament. My plan is to raise the bulwarks. At first I thought I put the deck to high but I didn't. Checking other build logs again I saw that all of them had about two and a half planks above the false deck whereas I put on just two. Therefore I will top them up with two stripes of 1.4mm oak wood of my stash I already bent to shape. The mockup represents the new height. Next will be cutting two additional gun ports aft. I couldn't shake the feeling that just two 3-pounder guns per side wouldn't have been enough, even for self defense. Therefore I contacted @Daniel Dusek, the new owner of Mamoli, who generously sent me 6 barrels of his new designs for this ship. The barrels are a bit longer and better made - all muzzles got the same, evenly centered bore now. Thanks again Daniel! I was also thinking about the gun port dimensions which are currently 8x8mm like stated in the manual. I tried 7mm square on the mockup and like it better so I will change the existing gun ports accordingly. Next will be scratch building carriages (the one on the pictures is an original cast metal one for the small guns) and then gun port covers.
  7. Oh dear, the Mantua boat looks at if they found it under the shelf... The Vanguard cutter turned out very nicely!
  8. Your second version of the captain very much reminds me of Robert Lindsay as Captain Pellew (which both I admire). A figure as reference is great I think. I use a clunky stick so far... As for figures in a diorama or standing model: Historical accuracy would be something I would look into. Paintings of the period should be available digitally, in books and museums for reference. As your crew will be privateers they would have worn whatever was available and practical. Maybe the Captain would have been better dressed for status. In the end: It's your model, do whatever you please 😉
  9. Steve, thank you very much for your encouraging words! Seeing our schooners side by side would be nice but as yours will be a privateer mine should better keep a distance... 😄 I've seen plans and models of the Grecian but honestly I don't like the look. I think it was made in this special manner to reference to columns in classical Greek architecture and hence named Grecian. Nevertheless I am already working on a solution... Thank you for following. I'll follow your build too.
  10. That sounds reasonable on a real boat but, as I see it, in this case the second planking is most of all intended to cover the naked lime wood from first planking with walnut for a nicer appearance. Therefore, as it visually wouldn't really make a difference when painted, I skipped this step.
  11. Hello all, Easter business kept me away from the shipyard so I couldn't make much progress. Nevertheless I painted the inner bulwarks green (instead of planking them with 0.5 mm walnut) and decided on the deck planking pattern. I thought a two step would be a little clunky for the long and slim deck so I went for the three step version. Furthermore I choose to lay just one pair of king planks for the same reason. Later I looked at the deck plans of Chapelle's "Baltimore Clippers" again and dropped the idea of wide waterways with staunchions, again due to the narrow deck. Happily planking away I realized that I didn't adjust my planking layout accordingly so I ended up short with some planks. As I didn't want to rip the deck apart I glued two stripes together to form a wider plank (impression) on the tips of two planks which I thought would be a plausible solution. The planks butt at the stern and nib at the bow as I've seen it on many deck plans in Chapelle's book.
  12. Today I received my copy and I love it! Shipping costs are quite high (33€ including the ridiculous DHL handling fee) but as the price of the magazine itself is a steal I think it's still worth it. As international shipping has been quite abusive to the magazine`s spine and covers, maybe one can implement an extra option for sturdier envelopes into the ordering process. I would have paid for it, so it doesn't reduce the margin. Anyway, thanks a lot for your time and effort sending out this helpful publication 🙂
  13. Oh no! Get well soon! I'm sure the hull will be waiting patiently.
  14. Nice, clean hull. Very well done. Good luck planking and don't fall down the hatch
  15. Phil, thank you very much for your help! In the process of learning I sometimes feel foolish but you're absolutely right, mishaps and misconceptions are inevitable, especially for a newbie. I'll upgrade the mock up cardboard deck with frames to figure out the planking pattern.
  16. When I went to bed last night I realized I made a fool of myself. Laying out the whole deck, then joggling the planks and after that building the covering boards accordingly would have been the right way. that's what I will do. Oh dear..
  17. Last week was slow as I continued painting, or was learning to paint... I put on a paint job in the evening, let the color dry over night, corrected an error or part I was not satisfied with and so on... In the end I learned a lot and I'm finally okay with the result. I was happy to finally get to planking the deck but first I had to think how it should look like. The manual just said to simply butt the planks to the bulwark and glue a stringer on top. As I already deviated from the width of the planks which I think are too wide I want to go for a more realistic approach and add more details. Therefore I will use two 4mm stripes as king planks (regular planks are 3mm), add covering boards and staunchions like on Mosquitobit and Flying Fish shown in Chapelle's book and on on Pride of Baltimore II. How to make covering boards was a tough nut to crack... First I cut a template of the deck out of cardboard and wrapped some tape around it to test fit the planks. Then I cut a 4 mm covering cardboard as mock up I traced the cardboard to an oak stripe and fit it to the bulwark. Port side fit best so I continued accordingly. Next step was to place sandwich paper over the stripes to determine how to joggle the ends. I read that joggling would be done if a plank joins the covering boards at an angle wider than 45°. Afterwards I cut the sandwich paper, traced it to the cardboard, cut the cardboard and traced that to the oak stripe. I guess it was a step many many but it felt safer... Last thing was to cut some test staunchions from scrap wood to loosely test fit and I like it. I know on Mosquitobit and the other ships the planks did / do not go directly into the covering boards but in a separate margin plank next to it but I have to compromise on that. Their planks are considerably thinner so I think it looks best as it is.
  18. Ist ein bisschen spät hier zu schreiben aber vielleicht hilft es für zufünftige Vorhaben: "Lupus Brünier Gel" ist gut zum brüniergen von Zink, Messing, Kupfer oder Bronze. Das Ölbad nach dem Brünieren ist wichtig, am besten so 8-12 Stunden einwirken lassen. Ich nehme Ballistol. https://lupus-pro.de/c/waffenpflege/brueniergel-brueniersets/antik-fuer-kupfer-messing-bronze-und-zink (It's a little late to respond but I think it might help for future builds: A very good product to darken zinc, brass, copper or bronze is "Lupus Brünier Gel" It's important to soak the pieces in oil for about 8-12 hours to complete the process. I use Ballistol )
