Everything posted by wefalck
  1. This could be an inherent design problem with these 'continuous' machines. Perhaps you can unwind the individual threads and then gather several unwound threads as a strand. On a machine with fixed distances between both heads, you would, of course, run multiple threads as one line, zig-zaging backwards and forwards between the heads, which automaticlly puts the same tension on all strands.
  2. I had seen this before and it is quite amazing. For the parts of a vessel that are permanently under water such complicated joints with many angles and corners may be not such a good proposition, as there would be many places prone to attack by rot. On the prototype the joints would have been tarred before assembly, which would be not so easy to do successfully with the complicated patterns. Besides, such joint are very costly to make, requiring a lot of fitting ...
  3. Even when working on platic kits, you may still need a lathe ...
  4. You don't say what finished sizes of 'ropes' you want to arrive at, but I see that you are working in a 1/90 scale. This may require some rather thin ropes in places. For these you may want to look into 'fly-tying thread' as used by the fly-fishing fraternity. They are man-made fibres. My preferred brand, due to sizes and colours available, is Veevus from Denmark. You can fish such threads in the wellknown bay.
  5. ... one is never at the merci of the kit designers (who have to - to be fair to them - find a balance between the amount of work invested in them and the profit they can make from a kit), one can always do one's own research and/or study reputable sources.
  6. I would obtain a copy of HARLAND, J. (1985): Seamanship in the Age of Sail.- 320 p., London (Conway Maritime Press). This book is probably the best modern compilation on handling ships, giving examples for when, how and why certain sails were set or not and how they were handled. It is based on an extensive research on contemporary publications, pictures and other records.
  7. I gather using full length planks has the advantage of making it easier to get clean strakes and hence to look neater on a model. Whether this is prototype-fashion is another question in addition to the scale plank length. The problem is to get the butting ends aligned properly. Perhaps the best way is to fit a full length plank and then to cut it into shorter sections before attaching it. This ensures that the planks have exactly the same wiidth at the butt.
  8. The fewer layers between the material of the hull and the coppering the better. Any additional layer can become detached and may be incompatible with the cement used for the coppering. CA is problematic due to the fact that copper ions can 'poison' the polymerisation reaction, which then will not take place. CA is also a sort of 'redox' agent, i.e. it reacts with the fine film of copper-oxide that forms immediately once you cleaned the copper. As a result, CA can leave stains on the copper. A contact cement would be the best choice.
  9. I don't know anything about these boats. In general, the details of rigging tend to depend very much on the person in charge of it. So it could be useful to find out more about the background of the people involved, e.g. whether they were American or British, had a RN or merchant navy background, etc. This can give you some hints of the likely practice employed for a given period.
  10. Of course, I did not imply that anyone should ever attempt to drink sulphuric acid ! I tried to point out the difference between 'toxicity' in the scientific-medical sense and other detrimental health effects. Peolple tend to confuse these. Oh, btw, I have a PhD in geochemistry and many years of practice in chemical laboratory work
  11. NB, sulfuric acid is not toxic ! I doubt that you could drink enough to experience any toxicity from the sulphate ions ... sulphuric acid dehydrates and oxidises organic tissue, which is something completely different. It is important to not mix up different categories of hazards. Otherwise, people get worried about things, while in reality materials can be safely handled with the proper procedures and precautions. Having said that, for me there would be certain no-nos in certain working environments. For instance, I am working seated at a wooden workbench. This means that I would shy away from using at this workplace strong oxidising acids, such as sulfuric or nitric acid. A spill is difficult to control on a wooden bench and when seated, you cannot get out of the danger zone quickly - you will have it all in your lap.
  12. Looks good, Chuck, but when one can see the strands like this, one could also really splice the rope
  13. I gather the answer to your question also depends on what kind of vessel and what period we are talking about. Without such information one can only guess, but the real practice may have been rather different.
  14. Moxis, here in my building-log you can see some applications: https://modelshipworld.com/index.php?/topic/8957-sms-wespe-armoured-gunboat-1876-of-the-imperial-german-navy-by-wefalck-–-1160-scale-when-first-commissioned/&do=findComment&comment=465372. I am laminating e.g. MDF with it and manually engrave plate-lines etc. Not easy to see, but some 20 years ago I built the shell of this dinghy from planks cut form 'hard-paper' and cemented together with CA. The reason was that I needed very thin planks and due to the clinker-construction could not really sand the surface: If this Polybak® is less brittle than the phenolic resin-based material, this would be of advantage. However, with a 0.3 mm end-mill at very high speed, but low feed you shouldn't have any problems on a CNC-mill, if the material it clamped down properly. I am using ordinary HSS- or carbide-metalworking tools with it. Single-lip engravers also work well, as do diamond-impregnated tools. One has to remember that these materials, Polybak® and 'hard paper', are laminated materials and not homogeneous. In the very thin qualities you have essentially a very thin layer of pure resin, the resin-impregnated paper, and then another very thin layer of pure resin. The pure resin is rather brittle, which is why one has the paper in between to take up the tensile stresses, just like the steel bars in re-inforced concrete. A tool jerk my cause chipping of the pure resin layer. When machining 'hard paper' in a router, i.e. when generating a lot of dust and heating up the tools and the material, one should have a reasonably good ventilation. I bought a life-time supply of 0.2 mm and 0.4 mm 'hard-paper' sheet from a small company specialising in such materials in Berlin, where I lived at the time. There are various German companies on the Internet that offer the material, but I don't know, whether they would sell in small quantities and to private people. Thicker qualities, 1 mm and above, can be bought in small pieces from electronics supply houses (e.g. Conrad in Germany, Austria, and France).
  15. Interesting discussion. The material would be called 'hard paper' (=Hartpapier) in German and is essentially a variant of Bakelite. It is paper soaked with a phenolic resin and pressed between steel-plates while setting due achieve a smooth surface and uniform thickness. It is commercially available down to 0.2 mm thickness and was/is used as insulating material in electrotechnics. Before being superseded by expoxi-based materials it was also used for circuit-boards. There are other variants of the material that are based on layers of cloth soaked with the resin that are used for making silent gears and the likes. I am using it a lot in my models because it is stiffer than polystyrene and does not contain plasticisers, so that it has a better long-term stability. Basically bakelite artefacts have been around for some hundred years now without degradation. Polystyrene will be brittle by that time. 'Hard paper' has some good properties, but is also rather brittle and may splinter easily when duller tools are used on it. One has to learn to work with the material. This Polybak® seems to be an interesting stuff. Unfortunately, their safety data sheets do not say what resin they use, it is only labelled as 'proprietary' compound. Otherwise, one could look for a similar product here in Europe. I would be very interested, as the phenolic fumes that are given off when machining my 'hard paper' are not all too pleasant and possible not too healthy either.
  16. We don't really know, but popeye2sea is most probably right. However, the question 'bluff bowed' or not is not so simple. You would need to ask 'bluff in the waterlines or in the cross-section'. You can have bluff waterlines and sharp cross-sections or vice versa.
  17. ... actually, I would have thought that the part is really U-shaped, or even slightly V-shaped - the position to which the stay will attach is not defined in the way it is modelled; the stay would in practice slip to one of the corners and then pull slightly sideways.
  18. JerseyCity Frankie, that's a good point - haven't thought about this.
  19. Dafi's sail-making technique would also make nice flags ... In another forum (http://www.shipmodels.info/mws_forum/viewtopic.php?f=59&t=163736&start=120#wrapheader) Jim Baumann discusses how he makes flags by printing the design onto ordinary white paper and then splits the paper to only retain the top layer. Two mirror-images of the print-out are glued together. These flags can be nicely shaped. The figure-modelling fraternity uses tin-foil (better, but now difficult to obtain - in the old days chocolates were wrapped in it) or aluminium foil.
  20. Send them an email last nigth, enquiring, whether they could deliver directly to a non-professional. They called me up this morning, curious what I was going to use them for. I had to 'confess' that it was for modelling purposes. We then had a nice chat about the applications and needs. In fact, HORICO did offer the strips and other tools from their range to a modelling supplier, but somehow it did not catch on. They realised that they would need some sort of holder for the strips. I gather, they are thinking about this market. Their carbide rotary tools seem to be of good quality, but rather expensive for us modellers - even when you consider that these burrs my last a modeller's life, there is always the risk that you break a small 25 € tool ... That is probably, why they could not sell to our market. In any case, exceptionally they will send me my strips
  21. At this link you can see the whole range of HORICO strips, both diamond and carborundum: http://www.horico.de/en/praxis/separierstreifen/2-uncategorised/91-alle-streifen.html
  22. Glad to see that my interpretations/guesses were correct. This arrangement with two back-stays and a sort of triatic stay running from the fore-mast top back down to the main-mast cap is rather intriguing. I don't remember having seen this before. It actually makes it impossible to have stay-sail running on the main top-mast stay.
  23. That's the kind of price I saw on Amazon, while dental supply-houses in Germany charge around 4 to 6 € for the dozen plus shipping ... actually the 30x series is not diamond-coated, but carborundum-coated according to HORICO. The diamond ones have a different number. The thin steel backing with a total thickness of 0.1 mm made them particularly interesting from my point of view, as you can widen narrow slots and the likes with them. No other file or sanding-paper is that thin.
  24. How much did you actually pay for these HORICO Stahlcarbo® strips ? The only Amazon-offer I saw today seems to be grossly overpriced. So far I only found suppliers that would only sell to professionals or traders, but not to private persons. May have to contact the manufacturer directly.
  25. Actually, the first drawing puzzled me somewhat: I gather the bow is to the right ? So what is shown in the top of the main-mast ? This means that single or double back-stay goes down from the fore top-mast to the cap of the main-mast ? A rather unusual arrangement ! By the middle of the 19th century iron caps have come into use together with eye-bolts as fastening points for triatic stays and the likes. Likewise, a lot of forged iron-work began to replace certain ropes or chains - less maintenance required. I would interpret these 'square' structures between the stays and the caps as some sort of U-shaped iron rods that are bolted to the middle of the cap and provide the attachment point for the stays, the angle of which adjusts itself. Never seen something like this before, but it makes sense mechanically.
