Everything posted by wefalck
Model Shipway Ratline tool
wefalck replied to fnkershner's topic in Modeling tools and Workshop Equipment
I think the challenge will be to transfer the assembly to the model ... -
With global warming, there may be no need for a reindeer with a glowing nose anymore anyway
Thanks, gentlemen, for your kind comments and 'likes' ************************************************ There are numerous ideas for constructing ladders or stairs for shipmodels. Together with gratings, this seems to be something that pre-occupies the the mind of shipmodellers. Perhaps because spacing saw-cuts evenly is a challenge with hand-tools. Having machines with tool-slides, controlled by spindles with graduated dials, at one’s disposal takes away most of that challenge, at least in theory. It seems logic to transpose the common techniques for making ladders just to a smaller scale, say with thinner saw-blades to cut slots into the spacing device. Preparing a spacing device for stairs However, the sizes of the materials to be used in itself poses a challenge. Treads in (wooden) stairs are typically 25 to 30 mm thick, which translates to roughly 0.2 mm in the 1:160 scale. The stringers of stairs may be somewhere between 40 and 60 mm thick, which translates into 0.3 to 0.4 mm on the model. The treads are usually notched into the stringers, so that the outside of the sides are smooth. This is a technique that would be very difficult to reproduce at this small scale because milling notches 0.2 mm wide and 0.2 mm deep into material that may be as thin as 0.3 mm is practically quite difficult to do consistently. The other difficulty is to cut the treads to exactly the right lengths. This problem also appears, if one tried to simply butt the steps against the sides for glueing. The clean glueing, without fillets appearing, also was a challenge, at least for me. Cutting notches for treads into stair-stringers of bakelite-paper Initially, the material of choice was bakelite-paper, which is very stiff, but rather brittle at a thickness of 0.2 mm and has attracted all the issues mentioned above. I then tried polystyrene, which is much less brittle, but also much less stiff. It has the advantage that it can be glued, or rather welded, using dichloromethane, allowing nearly invisible joints between close-fitting parts. While all these properties are useful, the styrene proved to be too flexible to be sanded to size on the milling machine, compared to the bakelite-paper. After various trials the most promosing method for stairs that emerged was the following: 1. cut strips somewhat wider than the stringers of the stairs from 0.2 mm bakelite paper. 2. arrange these strips in a pack on the micro-vise; count as many strips as needed for the stairs, plus a few spares, and a couple of sacrificial/protective ones at each side of the pack. 3. push the strips down into the vise and then sand them as a pack to equal width. 4. incline the vise to the angle of the stairs and cut slots at the required distances with a fine-toothed saw-blade of 0.2 mm thickness. Cutting slots for steps into stair-stringers of polystyrene 5. cut strips slightly wider than the width of the treads from 0.2 mm bakelite-paper, clean them up and round one edge slightly. 6. cut the treads slightly longer than the final length from those strips. 7. take two stair-stringers and insert the treads, which should be a tight fit, with the rounded side first. 8. adjust one side so that it is straight and the steps are only protruding slightly – everything should be square, of course. Glueing together the stair components 9. infiltrate thin cyanoacrylate cement into the slots and let set thoroughly. 10. adjust the opposite side to the right distance and repeat as above. 11. nip-off excess tread material on the outside. 12. file the outside of the stringers flush with a diamond nail-file and/or the disc sander 13. glue a second layer of 0.2 mm bakelite paper to the outside of the stair-stringers Sanding to thickness the stairs 14. transfer to the vise on the milling machine, slots down, and sand down the stair-stringers to just above the steps. 15. turn the stairs over and sand them down to to the scale width of the stringers. 16. sand the stair-stringers to the required thickness. 17. clean-up all burrs etc. 18. the stairs are now ready to be trimmed to length. Selection of stairs (not yet trimmed to length) I have tried to follow the same procedure with brass-sheet and soldering, but using bakelite-paper gave crisper results. Perhaps one should have etched the components and then soldered them together, as I had envisaged at the very beginning. This would have allowed to hold close tolerances of the individual parts, requiring less clean-up. However, I found setting up the etching process to onerous and also wanted to see, whether I could fabricate the stairs usind classical workshop techniques. The hand-rails and other fittings will be produced later, together with the railings, as they will be very delicate. To be continued ... soon ... first I have to go to Helsinki on business – and to have some Rudo-steak, now that Christmas is over
Liked that luxury long-nosed clamp in brass to catch rigging lines etc. There used to be something similar with a slightly flexible 'nose' (like a Bowden cable) about 10 cm long for electronics people to catch wires for testing in old-time wired boards. Concerning printed flags: as not all ink-jet printer dyes are permanent (as mentioned by someone further up), I retraced the printed designs in acrylics with very fine brushes. The draw-back is that you loose (some of) the transparency.
- 749 replies
- albertic
- ocean liner
Thanks for the kind comments I am shortsighted (+4 something), so when I take off my glasses, I get a sort of 'loupe' effect immediately. For many tasks, particularly those involving machines, I am wearing just a pair of protective glasses. I also have set of protective glasses that are magnifying (factor 3) and for really small work, where I need to see in 3D, I indeed use an 'optivisor', but don't find it very comfortable. Some years ago I purchased a set of frames with little telescopes attached to it, of the kind dentists or surgeons use, but found that the field of vision is too small and the working distance to wide in order to work comfortably when sitting at the bench. I gather they are designed for towering over the patient while standing up ... so I don't really use them.
It has been almost a year since the last post. I have been too busy business-wise and been side-tracked by various tool-making projects, which seem to be easier to do with the frequent interruptions by business-travels. There has been some small progress, however. Though this was not easy, as I have been struggling with the possibilities of the available materials and with my own skills. The 1/160 is pretty small, if you have set yourself the target to put as much detail into as one would do in say 1/96 or even 1/48 scale ... One of my struggles has been to produce acceptable ladders, on which I will report in the next post. ********************************************************* The officers’ mess skylight produced previously did not turn out quite to my satisfaction. It was not as crisp as I had wished. It was build up from layers of bakelite sheet around a milled core of acrylic glass. The mouldings present on the original were simulated by 0.4 mm copper wire milled to half-rounds. This all entailed messing around with cyano-acrylate cement, which is not my favourite and at which I am not very skilled. Officers’ mess skylight milled from a small block of acrylic glass It then occurred to me that much of all this could be milled from a solid piece of acrylic glass. One has to start from a block that envelopes the maximum width and depth, including the mouldings, and then has has to plan strategically which layers to mill off until the desired shape appears (reminds me of the joke, where an old lady asked a sculptor during an exhibition whether it was difficult to sculpt a lion – the artist replied: not really, madam, one takes a big block of marble and knock off everything that doesn’t look like a lion ...). The mouldings were left standing as square protrusions. They were rounded off using a draw-plate fasioned from a piece of razor-blade and held in a pin-vise. The half-round notch was cut using a thin cut-off wheel mounted on an arbor in the milling machine. Micro-drawplate for half-round moldings It is, of course, not possible to simulate panelling by this method. However, some parts can be left standing and the other completed with thin styrene-strips. For reasons of material stability, I am not such a big fan of polystyrene, it becomes brittle with age, but it has the advantage that it can be ‘welded’ onto acrylic glass or onto itself using dichlormethane. This results in invisible bonds and you cannot smear any glue around. Trial of milling out skylight window-frame The next challenge were the protective grilles that were laid into the wooden frames above the actual skylight glass-panes. The bar of brass or bronze had a diameter of less than a centimetre, which translates to something like 0.05 mm on the model. However, the thinnest brass-coloured wire I could find had a diametre of 0.1 mm, so is slightly oversize. Recently I came across molybdenum wires that are readily available down to diametres of 0.02 mm ! It seems that they are used in the repair of mobile phones, to separate the front-glass from the LCD-display. I obtained a selection of sizes, but have not worked with the wires yet. The wires are supposed to be tough, so I do not know how easy it is to cut them to length. Spool of gold-coloured molybdenum wire I tried various methods to construct the window-frames with exactly spaced out bar. In the first instance I tried to mill-out the frame from a thin piece of acrylic glass. Evenly spaced notches for the ‘bars’ were milled with a pointed engraving bit. However, I did not manage to get the edges and corners as crisp and clean as desired. Milling notches for window bars Placing wires as window bars I then wanted to construct the frame near-prototype fashion. To this end I drilled holes for the 0.01 mm wires into the edges of 0.5 mm by 1.0 mm strips of styrene. It proved difficult, however, to align the four parts of the frame well enough. Drilling frame for protective bars In the final version I welded 0.25 mm thick strips of styrene onto the milled acrylic glass body of the skylight. The block then was presented at the correct angle to an engraving cutter in the milling machine and the notches for the wires cut. In the next step the wires were glued into these notches, which was a major challenge – for the steadiness of my hand and my patience ... Built-up frames In situ milling of notches for wire bars The frame was completed by another layer of 0.25 mm styrene strips. As the total thickness should have been only 0.4 mm, the excess was sanded off on the milling machine. Finally, the edges were trimmed to size and rounded with the draw-plate described above. Sanding frames to scale thickness The officers' mess skylight will receive an outside protective grille on the basis of an etched part. Completed skylights for the pantry (left) and the officers’ mess (right) To be continued ....
Another version of the 'Third Hand'
wefalck replied to wefalck's topic in Modeling tools and Workshop Equipment
Rather than bakelite (which is phenolic resin filled with wood flour and which is essentially isotropic) I received ‘Novotext’ rods. Novotext is a composite of phenolic resin and cotton fabric. This is bad and good news. The bad news is that its temperature resistance is lower than that of bakelite and, hence, the clamps cannot be used for soldering as originally envisaged. The good news is that Novotext is much less brittle and more elastic than bakelite because the cotton fabric takes up the strain, as does the steel in re-enforced concrete. The material mill and turns well, and you can cut threads in it. So the design is the same as that for the metal clamps. In the end I got some nice clamps out of it, nicer than the wooden ones I attempted. Third hand with made from ‘Novotext’. Some people asked me about the construction details and below you find an ‘exploded diagram’ of the tool. Third hand ‘exploded’ -
Not having used the tool/product in question, I am not in a position to comment on its utility. However, I would prefer to work 'in situ', that is having the shrouds set up properly before starting 'rattling out'. I would find it difficult and too nerve-wrecking to transfer the net, that is effectively constructed, onto the model without some distortions occurring. In practice, I drew the layout of the shrouds and ratlines on a piece of card that is inserted behind the shrouds. It's then like working on a drawing and you will see any pulling-in of the shrouds and uneven spacing of the ralines immediately. Don't fix the knots until you are finished completely so that you can adjust things if still needed. -
Stevenson's ER32 Collet Blocks
wefalck replied to KeithAug's topic in Modeling tools and Workshop Equipment
Personally, I would not put a collet-block into a lathe-chuck. If you are looking for something to hold smaller diameter stuff and can't exchange the 3-jaw-chuck on the lathe with a collet-chuck, or if you lathe spindle doesn't have a taper to take in collets, I would use a round collet-holder like this one seen in a random ebay-offer: There are literally dozens of offers. They are too long to be taken into a 3-jaw-chuck, but you can shorten them using an abrasive disk or even on the lathe itself with a carbide cut-off tool. They start from ER8 collets upwards and cost from 6€ upwards. Another option would be to fashion the blocks oneself from square or hexgonal stock. The threaded clamping nut is a bit special inside and is best bought in. -
Thinning water based paint
wefalck replied to grsjax's topic in Painting, finishing and weathering products and techniques
Alcohol has higher vapour pressure than water, hence it evaporates faster ... What effect alcohol has on acrylic paints depends on the brand. Some brands actually use alcohol in their spray-ready formulations and these are recommended to be thinned with alcohol or an alcohol/water mixture. These paints are quite complex emulsions of acrylic polymers, pigments and solvents. If you change the composition, e.g. by thinning, the emulsions can break down and the acrylic polymers and pigments might curdle - in the worst case they may clog the airbrush or at least you might get an uneven coverage. The 'drying' of acrylic paints is a combination of processes, in addition to the already mentioned evaporation and sucking up of solvent into a porous substrate, the acrylic polymers slowly beginn to develop physico-chemical cross-links between each other. This process can take several weeks. Thus, initially the paint surface is typically quite soft and rubbery and only hardens with time. -
Levin, Hardinge and other manufacturers of watchmaking lathes have been selling such collet-blocks for a long time. They come together with a sort of V-block for simple grinding, sawing, or milling operations in the lathe: Picture borrowed from http://www.geocities.ws/dushang2000/Horology/Lathe Tools/Lathe Tools.html, as I was to lazy to take a picture of my own set. These blocks can be used with collets as well as the various types of chucks. I also use them, of course, in the vice on my milling machines. In the picture you see at the end a knurled wheel. This is not the draw-bar wheel, but sits on a fine thread at the back of the holder and thus forms a finely adjustable depth-stop. Some time ago I got some hexagonal bar-stock and plan to fashion a hexagonal collet holder from it, when I have time ... Incidentally, many year ago I also fashioned an upright collet holder that clamps to the table of the mill: -
P.S. will post a picture of the parts 'exploded' as soon as I get around to take it ... The foot obviously is a one-of antique piece, but I think one could upgrade the cheap commercial ones along these lines, though these feet are a bit small and light. -
Got the chuck and collets from ebay. It is same as shown by someone in the thread on the pencil drills. The price actually was 2.50 € per piece, but still ... Just search in ebay with "10Pcs 0.5-3.2mm Collet chuck" and go for 'cheapest item first', as prices seem to vary by 100% ! Michael, I thought your wooden clamps were inspired by the steel ones, not the other way around ... also tried some in wood, but they didn't turn out well with the beechwood dowels I had. -
As to doors: it probably depends on which parts shrinks more, the door or the frame - as the vertical frame of the door is a single piece of wood, it might shrink more than the door that is pannelled or even made from plywood. As to rope: when the fibres swell in increasing humidity their diameter and the diameter of the strands increase; as the strands are wound around each other they need more length to give a certain length of rope - or in other words the rope will shrink. If the fibres were all nicely arranged straight and parallel to each other, then the rope would indeed become longer, but they are actually running at an angle to the lenght of the rope.
- 3,618 replies
- young america
- clipper
Inspired by Michael Mott’s excellent tool (https://modelshipworld.com/index.php?/topic/14463-restoration-of-bassett-lowke-albertic-by-michael-mott-scale-1100/&page=5&tab=comments#comment-452268 and newer version further down in the thread as well as BANYAN’s review of it: https://modelshipworld.com/index.php?/topic/15249-michael-mott-designed-third-hand/&tab=comments#comment-473797), I decided to put into action something that I had planned to do for a long time. From my late father’s estate I inherited a cast-iron foot that presumably belonged to a some sort of chemical laboratory equipment. Not being impressed with the commercial ‘third-hand’ I kept this piece of cast-iron with the view of converting it into a tool with less and better controllable degrees of freedom. Also just having a pair of cheaply made alligator clamps didn’t add to the useability of that tool that, in consequence, spent most of its life on the shelf. I also inhereted a good quantity of pre-war quality alligator clamps. Third hand with small hooks for rigging work The cast-iron foot was de-rusted and a proper seat for the bar-clamp had to be filed – I could not find a way to clamp the piece to the table of my milling machine. The foot then was primed and painted in my favourite ‘bottle green’ (RAL 6007). Third hand with small clamps in steel Working predominantly in small scales with tiny parts, I sized the tool appropriately. The main bar is 6 mm steel and the two pillars are 10 mm aluminium. I actually prefer steel, but in this case working with aluminium was faster on my small machines. The arbors for all the clamps are 4 mm steel rod. The diameter of 4 mm was chosen, as the alligator-clamps have sleeves that are meant to be pushed over 4 mm-banana-plugs. Third hand with alligator clamps Thinking about the likely kind of applications, I made a pair of small sprung clamps from steel, a pair of larger toolmaker-style clamps (excellent idea by Michael, btw) in aluminium to be used for soldering, a pair of small hooks in 0.5 mm piano-wire for rigging tasks, and a pair of collect-chucks. Third hand with toolmakers-style clamps in aluminium The collet-chucks are a commercial products from China with ten collets that clamp from 0 to 3.2 mm. I thought this might be a good idea for clamping wires and perhaps ropes safely without distortion or marring. They were so cheap at 1.50€ for a chuck with ten collets that there was no point in makimng them myself. Third hand with collet chucks to hold wires etc. I also plan to make set of clamps from bakelite for soldering, but have not received the material yet. The thumb-screws are also bought-in, as I have local source here in Paris that sells them for one Euro a piece, which is not exactly cheap, but good value considering how much time I would have spent making them myself.
I have been thinking of adapting a dentist's angled drilling head ('hand-piece') for such purposes, but the problem is that it only takes short inserts with a fixed diameter. So one would need to construct a collet/chuck as well. The problem with smaller motors is that they have higher RPMs in order to deliver power. Otherwise you don't get enough torque. This in turn needs a well-balanced chuck in order avoid vibrations. In your case I would replace the Philipps-screw with a headless screw (which is what these little collet-chucks come with anyway, as far as I know)
HMCSS Victoria 1855 by BANYAN - 1:72
wefalck replied to BANYAN's topic in - Build logs for subjects built 1851 - 1900
Found a recipe: 40ml 25% H2SO4; 5 g SnCl2; 50g Thiourea. Add the sulfuric acid to 700 ml distilled water and dissolve the tin-chloride in it, add the thiourea and add more distilled water to give 1 l solution. I would divide the recipe by 10, as it seems to go a long way, the tin layer being only a few micrometres thick. Also the thiourea breaks down after a while which you can see from a yellow layer of elemental sulfur on the inside of the bottle. I have this effect in my commercial product, but it still seems to work. Not sure what the thiorurea does in the recipe.- 1,013 replies
- gun dispatch vessel
- victoria
Actually, no. This is a deoxidiser for soldering-iron tips. Something different from a tin-solutions that plates brass etc. through a chemical reduction reaction.- 1,013 replies
- victoria
Pat, it is not really a brand, but was sold by a German trader specialising in modelling tools (https://www.fohrmann.com/). I just checked, but they don't list it anymore. Ther German term to look for would be 'Glanzverzinnung'. Actually, I do have a very useful antique book from the 1880s or so that has a lot of useful recipes for making all sorts of workshop solutions and materials yourself - from a time, when you couldn't just go into a shop or mail-order such things. I should check, whether there is a suitable recipe in it - though nowadays with all those safety and environmental concerns it becomes difficult to buy the ingredients ...- 1,013 replies
- victoria
Pat, the tinning solution I use is a German commercial product. They don't give the composition, but it most likely contains Sn(II)-chloride, hydrochloric acid and thiourea. You just dip the copper or brass part into the solution and by a currentless (so it is not a galvanic process) electrochemical reaction a thin layer of tin is formed. In itself it may be too thin for soldering, unless the two parts are really pressed together, but with a bit of soldering paste one can easily solder together etched frets. As a matter of fact, I almost always tin my etched frets in this way to facilitate soldering, unless I want the brass colour. Also, when the painting is not perfect, the silvery colour shines through and looks more like iron than the original brass colour, of course. I also tin like this other brass parts that are meant to simulate iron or steel - this is usually better than painting.- 1,013 replies
- victoria
Air Brush Paints
wefalck replied to Worldway's topic in Painting, finishing and weathering products and techniques
It depends also on what size of areas you would want to paint. For small quantities I use pre-thinned ready to use paints. Of course, you buy a lot of water there, but it saves the hazzle of messing around with thick paints and trying to get a homogeneous dilution. Over here in Europe I have used Schmincke Aero-Color (artists' range), as well as Vallejo's modellers paints. There are quite a few specialist suppliers for modellers on the market now, e.g. Gunze from Japan. -
PROXXON has been doing something of similar size over here in Europe for many years, but it is a 12V cable-version: There was a problem with the take-up of the end-thrust by the motor-bearing alone, but I sorted this with a small metal disc at the free end of the electric motor.
I know this etching-problem very well: for instance, you cannot have raised rivets on both sides of a part with just one go in etching. You have to have two parts back to back. I designed my frets so that I have register-holes through which I can insert locating pins and then soldered two mirror-image frets together. As noted above this also has the advantage that you can work with thinner sheet, which reduces the amount of undercutting. To facilitate soldering with a minimum of solder, I cleaned and degreased the frets carefully and then plated them in a tinning solution. For the actual soldering you only need some flux and a tiny amount of soldering paste.- 1,013 replies
- victoria
I made such things from silk-covered copper wire, which can be bent into the desired shape and direction. The eyes have to faked and wound with very fine thread.
- 3,618 replies
- young america
- clipper
I wouldn't necessarily subscribe to the statement that 'historic' paint mixtures have a shorter life than modern mixtures. It always depends on what you are talking about. Mineral paints based on mineral pigments are essentially permanent and form a strong chemical bond with the substrate. For instance, any houses, e.g. in Italy, haven't been painted for centuries and the paint as such remains intact, apart from the general weathering of the surface. Paint on wood is different, as it not normally forms a chemical bond with the wood, but kind of mechanically holds on to it by locking into the surface. 'Modern' and 'historic' seem to have different ageing and weathering behaviour: while old, e.g. lineseed-oil based paints seem to weather over the whole surface, becoming dull and eventually wearing thin and becoming flaky, modern e.g. latex-based paints may have a higher weathering resistance over the surface, but eventually the paint film develops cracks and weathering occurs underneath the paint film, so that it detaches as large flaps.
