gkharrin
Posts posted by gkharrin
1 hour ago, wefalck said:
Not sure that the downloadable files and those on the CD-ROM have the same resolution.
I was certain I had compared them before, but as my memory is highly suspect, I double-checked. The dimensions of the web file and CD ROM files are the same. For example, 8415 x 6139 for the construction drawing of De 13 Søskende. More than adequate for building a model - you can see the grain of the paper.
3 hours ago, Mirabell61 said:
Unfortunately the prices (evan for used books) are out of reach in the moment.
The sad thing is, I bought the book and decided to build the eel drifter. Years went by and a CD with high-res scans was made available. So I bought that too. More years went by, and now all of the drawings in that book can be downloaded for free from the Maritime Museum of Denmark. This includes the German drifter:
LinesMaybe you already have these in your research. I'll search out your build log also.
- mtaylor, Mirabell61 and wefalck
- 3
10 hours ago, Mirabell61 said:
.... It looks like an danish offspring of a Zeesenboot.
Nils
It most definitely is. I first learned of eel drifters from this book:
All the boats are Danish, with one exception: it includes a German eel drifter for comparison to the Danish one. It specifically states the German boat design was adapted by the Danes. This article (same author) has the same information in somewhat greater detail.
However, I'm sorry to say I think the Danish design is the more handsome one 😉
- druxey, mtaylor and Mirabell61
- 3
Yet to be done:
- Turn belaying pins to use as the counters, one set from brass and other of some white metal (aluminum, stainless?)
- Inlay some belaying pins or other decoration on the sides?
- Inlay the name "Aspinet" or add a brass plaque? If I inlay the name, I would carve it out and fill it with colored epoxy (after several trial runs). No way I could inlay script letters and I would not want blocky ones. The plaque would be safer.
- Egilman, Old Collingwood and mtaylor
- 3
I had custom cards printed by youreondeck.com
Backs are the body plan for Aspinet
Spade pips are replaced by eye splices
Diamond pips are replaced by rigging blocks
Heart pips are replaced by .... hearts
Club pips are are replaced by deadeyes
Each face card is a different fishing schooner from Chapelle's book
Though not used in cribbage, the jokers delivered with the poker deck may as well be custom. Since it fished the Grand Banks (or so I presume), I made them cod.
- Egilman, Javlin, Old Collingwood and 3 others
- 6
I am pretty disappointed with myself for over-sanding and over-estimating how far I was driving the holly into the grooves (as opposed to just crushing the top that got scraped and sanded away). The pieces that were driven in well are still nice and white. Those that were not got sanded too far, and the glue is making it look gray. However, most people said they like the effect (maybe just being kind), and I'm afraid that if I try to fix it at this point the cure will be worse than the disease.
- Javlin, ccoyle, GrandpaPhil and 5 others
- 8
- ccoyle, GrandpaPhil, Baker and 3 others
- 6
- GrandpaPhil, mtaylor, Egilman and 1 other
- 4
- Egilman, Old Collingwood, mtaylor and 1 other
- 4
- Egilman, mtaylor, Old Collingwood and 1 other
- 4
- mtaylor, GrandpaPhil, Egilman and 2 others
- 5
The chisel is from a set of micro chisels with much longer shanks. This one broke when I carelessly applied too much side pressure while working on my dad's board. The broken part hit the brow of my eye. No glasses on. Learned a lesson there. I held on to broken chisel. Now that I needed a narrower chisel than any in the original set, I cut back some of the wood and squared up the round shank that was exposed to my desired width. Then I filed away a chisel point.
Nearly all the carving was done by using the chisel as a scraper, not driving the edge into the wood. As mentioned in the previous entry, I started by running it sideways at a slight angle. This simply helped me stay in the groove scored by the hobby knife. I then scraped away with the back of the chisel instead of the side, gradually moving it upright for the full width.
- Egilman, mtaylor, Harvey Golden and 2 others
- 5
I started by scoring the lines with a #11 hobby knife blade. There are a few wobbles here and there. I would have gotten better results if I'd cut out templates to press the knife and chisel against, but I got the impression it wasn't needed after a deceivingly successful test run doing it freehand. Even when applying light pressure, it is difficult to keep the grain from taking the knife off line.
The template was made by pasting the scanned drawing into Solid Edge 2D and "tracing" the lines and holes I wanted over it.
- mtaylor, Egilman, Old Collingwood and 1 other
- 4
This is not a ship model in the strict sense of the word. I hope you will allow it.
This is my first attempt at wood inlay. I was inspired to build a board for myself when, early on in the process, I damaged the one I was making for my father. There is a big chip from the router on the bottom of the board, hidden except when you turn it upside down. I started over and set aside the damaged piece. Years later I've finally gotten around to making it.
The wood is from a cherry tree felled by Hurricane Isabel in 2003. It was in the back yard of one of my wife's coworkers. Very pretty color! The finish is Watco Danish Oil.
The board I made for my father is a relief carving of the Isle of Palms, where my mother lived as a child and where they both are now in retirement. It's nothing to do with the new board, but I'll show and explain his board too. You start at the house near the left/south end of the island. There are a few novelty features that we never play, but it was fun to add them. The first is for the inside player only. If you peg 5 you have to do a 3-point penalty loop. You've stopped to watch the ladies play beach volleyball (thus the bikini) at the Windjammer (their logo is the sail), a very popular beach bar owed (partially?) by my aunt's childhood classmate. The second is for both players. If you land at 40 you have to play a hole of golf at Wild Dunes. There is a four-sided die for your tee shot. If the inside player lands at 80, he/she has a 2 point diversion while listening to my sister sing (music notes) at Morgan Creek Grill. The outer player has a similar penalty for charter fishing (hooked fish). The outer player has a 3-point penalty for swimming in Breach Inlet (badly carved "dangerous current" sign at far left). Incidentally, this is where the submarine Hunley exited the intercoastal to attack the USS Housatonic. The shrimp is just for fun. The local shrimp are excellent. The "To 'Da Beach' sign depicts the one at the end of their driveway.
Not Aspinet (clearly)
Keep reading and I'll get back on topic
The card backs are a painting my aunt did of my parents and their dog at the beach. A new deck was given last Christmas to replace these worn ones.
OK! So much for the background. The following posts will be all about my new board.
- Mirabell61, mtaylor, bruce d and 4 others
- 7
Aspinet 1908 by gkharrin - FINISHED - Scale 1: 120 - ship-themed wood inlay cribbage board
in Non-ship/categorised builds
Posted · Edited by gkharrin
I see my post was moved to "Non-ship/categorised builds". I get that, because it closer to scrimshaw than a boat model. But when I looked at the rest of the posts in the category, I was dismayed my ship-themed item buried among dozens of plane and tank models. Why are those even on this site at all? At least mine is a ship.
It was also changed to "finished", which isn't quite true. Not a problem. But as noted earlier, there are still a few details to add. This is the first of the belaying pin counting pegs.
