Chris,
What a wonderful space to work with! Just setting up your shop should be lots of fun, before you even start to use it.
I don't see much in the way of power and lighting but it looks like the main panel is in the far corner, so it'll be easy. Before you enclose the remaining walls, you might want to run some 110VAC power around the walls and perhaps in the ceiling for drops out in the middle of the room. Also, lighting of course. I moved into a house with a smaller available shop space some years ago and it had minimal P&L as well. I put in power outlets every 4 feet + or - along the walls, and about 4 ft above the floor so they would be above any benches I might install. And I alternated the outlets so adjacent ones were not on the same breaker. And - the ceiling lights I added are on their own circuit so if I ever amp out a tool circuit, the lights stay on. If there aren't enough breaker slots in the panel, you can add a shop sub-panel. That's what I had to do.
You might start by sketching and designing the final ultimate plan, and what activities and equipment will go where, and what the power, ventilation, separation from other activities, etc. will be needed. Then estimate the costs and priorities for each portion of the work so you can do it in a logical order when you choose to. This way, when you can add something, it fits into the master plan.
Congratulations on your new home, shop and growing family,
Richard
