paul carruthers
Posts posted by paul carruthers
1 hour ago, michael101 said:
The answer for that is :
i have called caldercraft today and send them the pictures
i have talk with the guy how design that ship and he told me the middle gun deck mast be 145 !
so the problem is the bulkhead and just need to sand the slot and also the bottom of that bulkhead
and i asked hem if need to sand all the down part of that bulkhead or only the corners
the answer is : only the corners of the bottom and he told me dont worry you will need to take a lot from that bulkhead doing the fairing
also i have ask:
when i check the plans there is something wrong with the top of all bulkheads
take a look at this pictures
from the middle gun deck to the second deck its like in the plans but the third deck and the fourth deck is not suitable with the plans
the drawing and bulkhead are both correct. The drawing is a cross section through the centreline of the ship and therefore shows the midline of the deck; due to the deck camber this point is higher than the reference point you are using on the bulkhead shown in your picture (the middle deck has no camber which is why it appears to align correctly)
hope its will help someone
Best regards ,
Michael.
Not every bulkhead will go to the bottom of the false keel, perhaps it only goes to the level of the shown beard line, try matching that and see if it corrects the height
- michael101 and EJ_L
- 2
Yes just an example of the start, I'm using a flat permagrit tool
- Martin W and zoly99sask
- 2
I saw the waves and have fitted balsa blocks between the BH's to keep them straight.
- Dfell, zoly99sask, Tadeusz43 and 1 other
- 4
- Landlubber Mike and Martin W
- 2
- Angarfather, Martin W and Shipyard sid
- 3
The ply so far is good,
I used the rear deck ply to align the stern extensions.
The mdf is also very easy to work.
Commenced planking of the deck, still to scrape and tidy up
My first model was Cruiser by Caldercraft, a bigger model, I hope I can get my hands in to Pegasus as it gets more complex.
Is there a good source for strip wood in the UK?
- Martin W and Ryland Craze
- 2
Never done a billings so I've no comparison I'm afraid, the kit for me was good quality, just poor instruction for a novice.
HMS Pegasus by paul carruthers - Victory Models - Scale 1:64
Second planking ongoing, rear looks bad in the pics but in hand it's no too bad, hoping it looks much better after sanding.
