paul carruthers
Posts posted by paul carruthers
On 2/4/2021 at 1:01 PM, chris watton said:
Overall length will be around 785mm (with bowsprit), hull length will be around 610mm
When can I send you the money? I want one!
- chris watton, mtaylor, austristan and 1 other
- 4
On 1/30/2021 at 4:17 PM, chris watton said:
OK, I never meant to plank the whole Sphinx hull, as this model will be thrown away once all the info I need has been taken from it. But couldn't help myself. this is a very quick planking job (a day), using scrap 1x4 Tanganyika instead of wasting the pear on a disposable hull - no filling, just a quick sand so I have a smooth (ish) surface for checking all parts that are to be fixed to it. I am happy with the hull lines, nice shape to plank, too.
What are the dimensions? Thankyou.
- mtaylor, hollowneck, KentM and 3 others
- 6
On 17/01/2018 at 1:50 PM, michael101 said:
Getting rady to the next stage
I saw some plank clampers at the internet also i saw them in some build logs ...
but after talking with Moxis i decide not to buy the due the expensive price and also i heard that the metal clamp its very week ...
so i decide to make my clampers by my self ...
i got the idea for the screws from Moxis ,
for the handles i have use the head of the push pins , i took the pins out and drilled the holl with 2 mm dia
the screws that i bought was 1.8 mm by the Moxis advice
and after cutting the head of the screws i have glue them to the handle by epoxy glue ,
for the clamp i have cut drill and bend aluminum
here is some pictures:
- mort stoll and EJ_L
- 2
On 15/01/2018 at 3:25 PM, jwvolz said:
Run the rope over some beeswax. That will help relax it, and reduce some of the fuzziness as well.
Then hit it with a hair drier, use this technique on all my rigging.
Nice work, I’m doing a lot of smaller items for my Pegasus, my question is were the side mounts one piece or several sandwiched bits of timber?
if one piece why the step design.
i too had lots of trouble blackening my small barrels, yours looks good.
- Canute and thibaultron
- 2
Query, did you clear coat the copper plates?
thanks
For those who can't fabricate jigs you can purchase photoetch benders
Definitely not wide as the strips sit right on the photoetch high points
I looked a Blue Ensigns build, if you look at page 2 mine looked like his with the top red border not parallel, so I measured from the plans and added a splice to make it 4mm as per the drwg and as his page 3. I have checked that all the windows side and rear fit as per his build.
- Waitoa, Mirabell61, Tigersteve and 2 others
- 5
- Martin W, Tigersteve and Ryland Craze
- 3
- robdurant, Landlubber Mike, Martin W and 1 other
- 4
- Martin W, DBorgens, Mirabell61 and 3 others
- 6
RB emailed cannon enroute😎
- zoly99sask, Martin W, Dfell and 1 other
- 4
HMS Sphinx 1775 by James H - FINISHED - Vanguard Models - 1:64
Waiting for the release!
