Everything posted by kruginmi
This is the day I bid her adieu. I found a friend that was willing to host the ship. I really don't have room so worked out for the best for both of us. It was a 40 min drive to his place. Ready for transport I In the back of my CRV I found Nestling in my winter coat was pretty solid. I was going to avoid the 90 MPH curves and turns haha. In it's new home. I told him I never wanted to see it again and any tales of woe have no need to be sent my way LOL. It will never look this good again and that is how I wish to remember her. As for a case or improved stand - that is for him to worry about. Cheers, Mark
Well, let's jump forward a few months (haha). Boy how time flies. Lots of things going on so for 2024 I just knuckled down and worked on the Vic when possible. Following Nepean's guidance I added a TON of added blocks and lines. I also used the provided sails and was quite happy with the result I achieved with a little paint and my airbrush. She is now done and in the rear view mirror. I had a lot of fun working through the rigging. I did get a little creative in some of the tie down points but balanced practicality, visual appeal and accurateness. I used a backdrop to emphasize the lines but found out even that had issues. Use a black one and remove all the standing rigging, use a tan one and remove the standing. This did work out very well when actually rigging to keep your eyes from going bat crazy. Mark
This model has been perfect for working on my rigging capabilities. I have spent a bit of time off line working on learning / remembering / identifying what is the Mark Krug way of doing things. Also the ship needed a lot of clean up and various bits and bobs put to right. My midterm (freshman year) was to get those main stays configured and put into place. All this was scratch - the Heller kit does not include any heart blocks. I also reconfigured the marine walk a bit for the preventer stay. Things seem to be coalescing well. I rigged up everything off ship - just required the last seizing once installed. Both main stays installed. I am happy with the length to blocks and the look. Unfortunately the loop seized to was a tad bit too low and got mostly lost in the grating. Everything checks out. I will be adding the stay to stay weave. Now onto the fore stays. These also will have open and closed hearts added. Mark
Well, the Vic is a large and complicated model (haha). My just jump to the rigging has been a major case of SQUIRREL!! Fix this, no do this, but first do that. Lots of hours with little to show for it So....opted to do something. The man item dragging down the looks were all the broken hammock irons. I methodically went through, dug out the remains of all the broken ones (drill bits work great for this) and replaced with fresh new ones. One part of me says don't do it, you will break them off yourself but I threw caution to the wind. The hammock pieces are inserted but not yet glued into place. Obviously not including the nets yet. I tried out the netting jib provided and the end result is really not bad. If you do not have any 3rd party netting at scale this is entirely usable. I am thinking of not wrapping this from one side to the other, but to cut a panel for front and back (leaving the bottom empty). I will try some prototypes and see how it goes. With all three (irons, netting and hammocks) they should be a little more resistant to snapping off at the first sideways glance. Some paint touch ups is next. The main deck opening needs to be painted black to provide some visual breakup. Also other places. My aim is to balance time consuming work with the clean up (show progress) work to keep me motivated. Stay Building My Friends, Mark
A quick discussion of my aims and direction: The following are my goals for this build: Get better in MODELING rigging o Sometimes not the same as actual ship rigging Learn the nomenclature better Don’t sweat the details (vague – I know) o Not an exact replication of the Victory, but close as practical (in Krug terms) o Don’t turn the Heller model into a scratch build – stay out of the box for most. Have some fun o This will not be a multi-year project To repeat the first post, this kit was started (very well I might add) by someone who has since passed. I am using this as a learning tool and to honor that person. As such, there will not be a gut job. The deck is not painted – so be it. The fore and main lower shrouds are affixed so the rest will be installed in the same manner (using the Heller tool and the ratlines glued in place). As a person born in the 60’s I remember the warped pieces of plastic that passed off as kits back then and loved building them. I now have a few wooden ships under my belt (the HMS Druid sits just across the room) and enjoy the process of building and stretching skills. I am lucky to have 1.5 more kits of this for experimentation, repair and adding on where needed. The excel spreadsheet attached was my go through of the Heller plans to render into English the names of all the lines and deck tie down locations (eg A7 is the Flying Jib Staysail Downhaul). Once you have the name and know the function, tracing the line across multiple diagrams is greatly simplified. I have Identified 9 lines not in the plans (boomkin stays, leech lines, etc) that I will add as well as 12 lines that I believe are duplicative or unkown (see end of first tab). I will NOT declare it without error. As I build I will methodically go through what is written and verify so it will get better. If it helps you, great, but use your own knowledge to see if it is helpful to you. There is a cross reference to the Anatomy of the Ship Line # as well as Rigging Period Ship model page numbers. The references I am using (items sitting on the build table) are: Heller 1:100 Plastic Kit HMS Victory Instructions Krug’s Rigging ID Guide to Heller 1:100 Kit Line and deck tie down translation to English – Excel Sheets (Attached below) Full size Plans Used in Longridge’s Book Percival Marshall & CO Ltd HMS Victory: Her Construction, Career and Restoration Alan McGowan The Anatomy of Nelson’s Ships C Nepean Longridge Others on the bookshelf: Rigging Period Ship Models Lennarth Petersson Anatomy of the Ship: The 100-Gun Ship Victory John McKay I was VERY fortunate to get the full size plans from my Uncle. So much more readable and usable then the fold outs. Beautiful detail. I look forward to advancing this build forward. Lots of things still to do on the main deck but that will wait. My focus now is to get the standing rigging up and in place to kick this off. Mark Krug Victory Rigging Lines.xlsx
Good Day William. Mind if I pull up a seat and attend the show? You are going in really deep and I respect that. Great progress!
Well, the process worked out and it was pretty easy also. First shot shows the mouse and at the desired distance laid in an eyelet in the thread. I then looped around the mainmast head and fed the lower end of the stay through the eyelet and fed it up until it was stopped by the mouse. It had the look and seemed right at home. Second line was a repeat of the first. I offset the eyelet a little farther in to provide some separation. No glue required here, that join will not loosen up under just minimal tension. Finally the money shot of the two stays. Next up is the heart block at the lower end of the stays. I am also in the process of modifying the walk to allow the two lines for the preventer stay to pass through better. I am actually going to interweave the two stays since I believe that look is also pretty iconic when you view pics of the Victory. So many things I want to do, just need to focus on one at a time (maybe two haha - that foremast breast backstay add is pretty easy and straightforward). Stay building my friends, Mark
As is usual, so many things to do and without focus hours will be spent without any discernible progress. Also, I usually live in the 1:48 world so new techniques (and limitations) will be found and explored. I opted as a first visible task to replace the foremast stays. The kit only supplies regular blocks (3 sizes). I think the open and closed hearts pretty iconic so decided to do something about that. Secondly, I wanted to use the worm topside to secure the stay to see if I could do it. I am assuming a lot of these techniques have already been stated and shown but I invite you in to my attempts. This pic shows my hand created hearts (sans the two at top which I had in my spared box). Slightly different sizes for the primary and secondary stays. For the worm itself I am using Elmer's glue all (on a scrap piece of line) to see if it looks alright. The line itself (3 cords) could be separated and the cord passed through itself. This would produce an eyelet that will be very stable and perfectly sized for the cord used. Although I did not spline the lines, all will be brushed with a 50/50 glue water mixture to allow it to set. Once I combine the worm and eyelet the result looks pretty good and effective to me. The line passing through the eyelet is not fixed and can be pulled either direction very easily. Of course the worm will be painted black and with the glue wash all lines will be laying flat and invisible. Hopefully should have the foremast stays affixed and looking good in a day or two. Mark
As I move into retirement (and the peasants rejoiced) I had wanted to spend some time focusing on rigging. Well, I was given this Heller Victory with the hull pretty much done. The backstory was the gentleman had passed away and this was picked up in an estate sale for next to nothing. His work was superior and once I saw the hull I decided this was a good subject for my goal. There was the inevitable broken components but that was largely confined to the royal masts and (of course) the jibboom. The accompanying box of parts was incomplete but I have another 1.5 of these in the stash (bit of a story there). I would have done some things differently (like the deck isn't painted) but for what I was going to use if for and for actual looks that was fine. I have a friend that already has asked to have it upon completion for his library at home, which is perfect. I have dissected the plans and have defined each and every line so am over that hump. I did notice some differences to actual practice. I have a set of the plans that Longridge uses in his book (thank you Uncle Leo) and have defaulted to that presentation where practical. For example the foremast stays did not include the Breast Backstay so I am adding that. Not going crazy or over the top but where it makes sense will make those changes (for example, will use the supplied plastic blocks). I looked through my stash of 'rigging' line and have chosen to use 6 types. The Heller supplied line is white and didn't want to dye. So this morning after getting the remnants of the broken pieces removed and things prepped, went ahead and primed the necessary replacements. I am using Vallejo acrylics. It will be interesting to see how close I can get to the existing yellow shade. I should be working on this at least 2 days a week at a minimum. My first task is to scratch some open and closed hearts for the fore and main mast stays. These seem pretty iconic and need to be there but aren't included in the kit. Stay Building My Friends, Mark
Alright after a bit of a hiatus I am back. More importantly, as of last Monday I am now retired (and the peasants rejoiced). Bit of a crazy few months but that is all behind me. I have time, I have the motivation and I still have the ship. The Jylland has been dusted off, some minor repairs to the hull planking (gaps) fixed up. Lots of things on my daily list but progress will be made. Looking at getting the stern set to rights window wise then right into the upper faux planking. - Mark Stay building my Friends
Wefalck - really fighting the hand dealt me here. The kit stern is very different from the one you highlight. This is my first cut and then ponder on kit/reality to make the best adjustments I can. I do appreciate the input. The lower windows are locked in (bottom wise) to the line of the gunports so that is one fixed point - but I can force the swoop up a bit to allow more room for the JYLLAND name as well a provide a better profile. The size of the decoration roundly defines the second (swoop of lower garland). Will probably be replacing the decoration so I can 'adjust' there a bit. Definitely thinking higher and smaller but within constraint. The real ship pics reflect an in between view also. Mark
Dragged the ship upstairs, at least do something. Need to work out the positioning of the 4 stern windows. I started by creating a smooth line from the lower gunports, which provides the top and bottom line of the lower windows. For a reference point I used the decal. I taped where I thought it should be and poked holes through the window corners into the wood. My intention is to carve into the wood and inset the frames (not use the decals). Didn't look half bad (especially at the 3 foot mark haha) but did some tweeking. Arrived at what I thought was a good position. Still need to make the upper windows less wide but will think on that. Lower ones same size as gun ports. Decal already started falling apart, but that is a battle for another day on how to replace. Mark
A bit of clarification (and last): Contractor working upstairs slit water softener drain line. So....40-50 gallons per minutes pumped at 4:30 AM. I found out at 6:30 AM. Home still filled with fans / dehumidifiers / other. Another day or so and I can start the rebuild process. Veterans Remembrance Day in the US today. My hats off to all who have served (US or any country) and especially thoughts to those who gave their lives. Mark (former 1LT, US Army)
Do you ever have that recurring nightmare that a water line will burst directly over your workshop? Good one. Well, it happened. Right now in the middle of cleaning it up. Could have been worse. The ships were saved, some of my other endeavors - not so much. Food pantry significantly hit as well. Needed to clean that place up anyway..... 🙂
Okay - you had me with the water-colours for the bow and stern LOL. The decals supplied being over 50 years old leaves little doubt to their usefulness. I will take a look hopefully this weekend. Keith- I do not believe rubbing strakes per se. My best guess at this point (looking at everything else) is that this may have been an artifact of it being dry docked and for the initial shoring (before it was finalized). Just my gut. Mark
Finally added the mysterious vertical pieces of lumber (7 per side) located between main gun ports. The adjustment of the chain plates sure came in handy. I did some adjusting on positioning - focusing on the location between gun ports. These ports do not 'exactly' correspond with what is seen on the ship so keep that in mind. Visually they look correct (the 3 foot test). The hull has had some manipulations into its current form. Almost set to begin the 2nd layer planking. Mark
Wow, Wefalck, that is quite a list. Definitely shows some research and comprehensive look at the subject. My ship is a 3-fer: Stand 3 feet away and squint and you should be able to say what it is (haha). Being a (raw) kit from the early 70's (I believe) there was a whole host of issues to tackle. Being made for my Uncle who bought it originally, I am straddling a wide gap. Started with insufficient information, with drawings that were not to scale and differed from the images I found on the net I am trying to make a presentable model without binning the whole thing. Appreciate the comment - that is for sure. Any help or guidance on the direction I am taking is always looked for. Mark
There must be a hotline available to call for help in such times (haha) Spent this evening and......raised the chain plates up a 1/16". All is right in the world again. Made a world of difference in this 1/100 scale model. One of the deciding points was that since it will be veneer planked, I could easily wood fill any scars and sand smooth. Okay note to self: don't do that again. Stay Building My Friends, Mark
Got the entry port cut out and the platform inserted. Was moving on to the external vertical posts between some main gunports. When comparing to the actual pics I noticed something..... I had put on the chain plates even with the deck beams (in this case the false deck). Never thought a second about it. But....as I looked at the ship pics the positioning was different as defined between the upper and lower ports. Moving the chain plates up a 1/16" (equal with the decking) made things a whole lot more consistent. Bummer. The CPs are totally locked in, glued and looking perfect. Given the rest of the kit is a 'representation' with several issues all around I am thinking of leaving things as is. My Uncle isn't getting any younger. BTW: There will a leading trim piece added to each long edge of the chain plates once the actual chains are added (to capture them). So much more tidy than trying to drill holes and insert them. Any thoughts? Mark
Thanks Keith, appreciate it. Using a dowel, I created a pseudo mast to replicate the masthead height for all three masts. This allows me to verify the width of the chain plates as well as the location of the shrouds themselves. Quick easy tool that has loads of benefits. You can also see I have created (and attached) all of the 6 chainplates. Ended up using 1/16" Basswood keyed into the hull. Pretty darn strong this way - just hope I do not snap any of these off between now and the end of the build. Additionally allows pretty precise placement (over and over again until glued). I still have the platform for the port of entry to do, then on to the vertical wood beams between gun ports. Mark
After slicing the tip of my thumb off (not even hobby related) back to getting the chain plates on so I can start the second planking. For strength I like to key them in. A little more work but I think worth it. First step was to sand the facing edge flush against the hull side. Important step is to get all the bevels correct so chain plate parallel to waterline and not perpendicular to hull. I can still work the mating surface for an even better fit but keep remembering there is still a veneer planking which will cover the entire joint. Mark
Next step was to mark the copper line. Put the ship back into the building slip and (gently) ran a fixed pencil line at the appropriate level. The copper section will be replicated using just paint. The upper section will be planked with veneer. I then marked ribs at 5 foot scale intervals. This will allow me to align the plank ends up. Probably going with 15 foot scale plank lengths. To finish everything off I marked off the chain plates. These will be built next and keyed into the hull for strength. One of the bonuses of double planking is that the planking can effectively cover up any joins. The hawse hole rings are currently press fit and can be removed easily. Just having fun. Mark
Catheads and braces, along with hawse holes in place. Now to define the dividing line to the copper plates. Additionally will pencil in faux bulkheads every 5 feet (every 5/8 inches) from this line to top of bulwark. This will allow me to stagger the joints of the 2nd planking. Still need to figure out the width of the planks themselves. Looks like 4 rows per gunport is an estimate. Question is, do I do 2 rows to make it look better at scale. Mark p.s. Need to identify the locations of the vertical posts. Might be better to add prior to 2nd layer planking.
