UdoK
About UdoK
  • Birthday 10/03/1966
  • Gender
  • Location
    Westerwald Germany
2,583 profile views
  1. What about this ? 168011-13-instructions.pdf
  2. Before I begin installing the drive and rudder, I've already fitted the decks and cut out the openings. This helps with planning and installing the drive components and RC control parts.
  3. Blowing the dust off the build log.... The deck subtructure has been constructed and glued to hull in their respective height, measured from the top of the hull according the dimensions taken from the plan. Now that the deck cut-out defines the future access to the inner hull , I will start to determine the position of the built-in parts, drive and accessories.
  4. Thank you for your likes, much appreciated! The building cradle is finished, the stands were copied from the plan, cut and glued together with reinforment pieces to a wooden base plate. The hull has been lightly sanded from the outside. Filling in dips was not necessary. some dimple even imitate damage to the hull which I will leave as it is, the ship is supposed to show a lot of wear and tear. Next was to cut out and file the well deck wash ports on both sides. The construction of the deck framing has been started as well, photos to follow...
  5. Yes, the drive components arrived yesterday. I will replace the kit supplied shaft with a maintenance-free, bearing-mounted shaft from Raboesch. The engine is an Aeronaut Navy 720, it should be strong enough to power the model.
  6. Starting my build of the Boston Typhoon. I'am not showing the kits content since it can be found in my review of the kit earlier here on MSW. Here we go, the moulded Hull has just been arrived on the workshop table ! It has been washed with soap and rinsed with water to remove any residue may remaining from the moulding process. I will start with the usual activities like building the cradle and sanding and filling some rough spots and dips on the outer hull, etc. More to come!
  7. Thanks Cpt. Hook, don't be afraid. After sanding a few frames you will have developed the right feeling for it. Stern construction part I Basically the stern construction is a complex task and requires a lot of thinking ahead, prior to glueing parts together. I have started with the inner stern timber pack, parts 11-1 to 11-5. Due to the parts thickness (slightly oversized) the pack doesn't fit into the respective notches in the transom pieces. After glueing together parts 2-4 I have reduced thickness of both of this packs equally to fit the notches. The transom pieces 12, 13-1 and 13-2 are sanded and dryfitted in the jig together with the center timbers. The laser cut marks on the pieces ease sanding and bevelling the edges a lot. Next task is to construct the side counter timbers in the correct angle. More to follow...
  8. Frame treatment still in progress.... Although I was very careful with the frames it did happen. The small vice dropped off the blocks and the clamped frame broke off, fortunately it was easy to fix. To prevent this from happening again I have orderd the Proxxon FMZ vice, a much more safer way to clamp and work on the frames compared to my construction with blocks. To have a break from sanding frames I have started to work on the complex stern construction. All required parts have been located and cut off from the laser cut panels, ready for clean up. Next is to understand the stern construction and figure out what is the best sequence to puzzle it together.
  9. Patience is not a problem for me, rather the monotony of the sanding. therefor I 'am making a slow progress, sanding frame by frame with sufficient breaktimes in order not to loose the entusiasm.
  10. You are right, caution must be taken for sanding and clamping not to break them. I have started at the center frames and work my way up to the stern first. Frame 23 is the first one who requires some slight bevelling. When the frame parts have been aligned and glued together precisely, the laser marks provide a good template for bevelling.
  11. First frames are cleaned up and sanded... I have started with frames 20 and 21 to get a feeling for the numerous steps on the frames as the center frames are not subject to any bevelling. The employment of electric rotating tools is very limited at this stage and can only be used on the frames inner side. All the steps must be sanded with needle files and small sanding sticks. 34 more full frames to go, this will keep me busy for a while
  12. Building cradle completed.... All joints has been brushed up with wood glue, reinforcement pieces are installed on some edges on where I thought it will appropriate to stiffen the parts. As the instruction manual 2 instructs a conversion of the building cradle after the hull planking is completed, I made the top of the building cradle removable from the base plate to ease the modification. Now, since all full frames 4 to 36 are glued up and waiting for sanding and beveling, the real fun starts.
  13. Meanwhile the missing parts E are already arrived, 5 days after sending the message to Tom. Another sign that Tom is really concerned about customer satisfaction.... So, the building cradle has been completed, just dryfitted. The perfection and fit of the lasercut joints is really remarkable. Beside removing some laser char here and there and sanding the curvature on piece A8, no major sanding or adaption were required. The clamps are only in usage because some of the plywood pieces are a bit twisted, but not really an issue. Next is to fix the construction with glue.
  14. I have send an message to CAFmodel, Tom concerning the missing Parts E1 and E2. He replied right away with the information that he will send out the pieces immediately. That's what I'am calling a outstanding customer service........ The construction of the building cradle will be suspended until arrival of the pieces. Construction of the frames has been started with the first full frame number 4. In the first step of cleaning up and sanding the frames I have used my disc sander to sand the pieces front and end smooth. Afterwards the individual pieces are properly aligned over the drawing and clued together. For sure it will provide a lot of fun to clean up the laser char and sanding all the clinker planking teeth into shape on all the frames.
