Everything posted by knightyo
US Brig Syren by knightyo
knightyo replied to knightyo's topic in - Build logs for subjects built 1801 - 1850
This is great info. I've filed just about every micrometer of each of the cannons in order to correct casting/shaping errors, etc.. Hopefully they'll accept the blackening agent.... I'm going to hunt for wire tomorrow so I can get the breech line rings done. Worked on the "shingles" of the quarter galleries tonight. The tops of each are nearing completion. My eyes are NOT used to looking at things close up any more. I'm really hoping they can "adjust" again... -
Hi Larry, Here's what I'm going to use... It will be interesting to see the results... But now that I think of it... The wire I use for the breech line rings won't be pewter... Hopefully the product will have the same oxidizing effect on whatever wire is used, so everything looks uniform..... I suspect I'm being naive, however -
Well, this year the following events occurred; Got married Finished school Started a new Job Purchased a home For some reason, I didn't get a whole lot of modelling done. I'm tinkering away again now however, and am working on the carronades! The slides are shaped, but still need to have the blackened photo-etched hardware installed, etc. I'm intending to blacken the carronades (pewter). Does anyone know what type of wire should be used for the breech line rings? Definitely don't want to have bright shiny silver breech line rings! I should also mention: The slides were made from Black Walnut which Rusty kindly sent to me many years ago when I was working on another smaller project (still unfinished of course). I want Rusty to be pleased on this part, and to know that his generosity paid off, even thought it's taken many moons! -
Excellent tutorial. Chris is right about how you can end up with amazing miniatures simply by applying washes. I used to paint a lot of 40k miniatures, and had many appreciative comments about my paint jobs. I'd always giggle to myself, because I didn't really have any skill at all.. It was all in the washes!
GREAT memory, Augie.. Thank you, good sir. -
Hey guys, I was able to sneak into the garage today and get some work done on the carronades! Does anyone remember which Syren builder simulated the elevation rod in his carronades by using a threaded rod? For the life of me, I can't figure out where to get a threaded rod that small. Alan -
Thanks David! If it was you, would you round them over, or leave them "straight"? Alan -
Thanks guys. It's a pretty fun mini project working on these things. Not much to report today. I was able to squeeze in a quick bit of time to cut off the lower portions of the "ugly" wood, and sand the "shingle" area down. I think I'll finish the "shingling", then glue it to the new pear base, after it is constructed. Then I'll start work on the window and lower sections. I'm intending on using a mild acrylic black wash on the quarter galleries in their entirety when they are finished, in order to match the method I used on the stern decoration way back when. I think that method will also be used on the figurehead when she is done, so every pear component matches in color/look/feel. I'm still not sure whether or not to round the shingles. at this point I think it's the right thing to do, but I know once that process is started, there is no turning back, and if I foul it up, a LOT of time will have been for naught. Rounding the shingles will also give me the opportunity to correct/disguise the uniformity errors with a few of them and help to make all of them to appear to be as symmetrical as possible. -
Some random shots to update/re-create the build log. Just took them, and that's about where I'm at. I chuckled when I saw the dust in the gunport, and had to take a pic. Alan -
Thanks guys! I've got a LOT of catching up to do! I did run across another pic on my system. I've periodically snuck in time here and there to sand little "shingles" for the quarter galleries. I'm not quite sure whether to sand them down flatter, round the edges over on each, or quite what to do. You guys wouldn't believe how small they are. About the only way I can work on them is to gently hold them in tweezers, and use a very fine sandpaper to shape them. I'm about 4/5 finished with the one, and the other is about halfway done. I'm basically working my way down on these, trying to make them as ornate as my skills will allow. I'm thinking of using microscope cover slides for the window sections..Perhaps hollowing the structure out from the back.... My goal is to have every surface on these be of pear for consistency... The pear also matches the stern ornamentation and the figurehead. I don't seem to have pics of my stern ornamentation to show for comparison against the rest of the planking, but I'll work on getting a few more pics up. Alan -
Thanks David, it sure is fun to be back! -
David, that is an outstanding point! It also seems like scraping can really give a nice polish effect as well. Definitely fun to experiment with sanding vs scraping. Hmm.. tried to quote David's message and respond... But it didn't work... Looks like I'll have a learning curve with the new site as well as getting back into the groove with modeling. lol -
The figurehead was inspired by an old plastic Heller model of La Sirene. I took a pic of the figurehead, and scaled it down to size. Then it was a matter of printing out, gluing to a piece of pear, and cutting out. She currently looks like an ancient idol. Much work to be done on her! -
Creating the cannons (cannonades? carronades? I can't remember ) was really fun. I turned a master in my mini-lathe, then created a mold. The metal is pewter. The other cannons shown are for my Lexington which is also collecting dust. I think I'll finish the Syren first, then the Lex, then the Confederacy. I also have a tiny model I've been fiddling with in my spare time. And of course the Triton. And YES. I know if I'd focused on one project at a time, one of them would be done by now. I just couldn't resist starting each project as it came down the pike! -
Deck is done. I remember that I used a black Sharpie marker to color the edges of the planks before gluing them in. This created a very nice effect once the planks were installed and sanded, BUT the ink from the Sharpie reacted with a Mastic I applied to the deck, which required me to resand. It ended up fine, but was very scary for a while. Lesson learned: Always test paints/stains/inks on scrap pieces first... -
Now since I knew that pretty much everything I installed from this point on would be visible, I slowed way down. I used graph paper to help myself plank the deck properly, and to make sure I didn't end up with any surprises. -
I think I used simple painters tape in order to tape off the hull. I knew it didn't have to be a perfect line as the copper plates would eventually be overlapping the paint line. -
I think I stole this idea from Chuck. Used a dremel tool cutting disk to shape a beaded molding pattern in an old Xacto blade, and ran the "shaper" down a piece of planking in order to create a beaded molding strip. -
