MrBlueJacket
Everything posted by MrBlueJacket
  1. Next was the tryworks extension and the tools. All that's left is the chimneys and the doors.
  2. Finished the bricks, sprayed automotive red primer, spackled and wiped it down, then added the pots to the top.
  3. So, 2 years and 11 months later, I have picked up this build again. got the last brick layers on and the top bricks as well. Still need to trim the stepped face.
  4. Congratulations! Your customer file now reflects a 10% discount on your next kit purchase from us. Nic
  5. Actually, I think a model is never "finished" because you can always see something to add...... Finished means you have decided to stop working on it. Nic 😉
  6. I don't think the name was patented or copyrighted. And then, first they'd have to find this thread....
  7. Never really blew a deadeye out like that, but I have had deadeyes where the separation between holes failed. Nic
  8. Yes they did use wire. 3mm dia wire is VERY strong. personally, I use CA when I cut the wire so it doesn't unravel. To fasten, I loop the wire through an eye, when use a 1/4" piece of 1/16 aluminum tube to crimp the wire in place. Nic
  9. Yes, printing 11 x 17 worked perfectly. That must have been the size of the original instructions. Nic
  10. Hi Clare, I did, but it's still too small, even filling the page. but you gave me an idea to try - I'll see if I can print it on 11 x 17 Nic.
  11. Unfortunately, it is the correct instructions, but it only prints out on 1/4 of a page, much too small to be useful. Thanks anyway. Nic
  12. Thanks, but that is for the 1/200 model. I need the 1/100, which is much more detailed - the instructions are 38 pages Nic
  13. Need instructions for the Aurora Heller 1/100 kit. hismodel.com has a pdf, but it prints too small to read. The Heller.fr website has it advertised, but out of stock. Any help is appreciated. Nic
  14. Hi, Our Constitution is based on 3 years' research by Larry Arnot, including interviews with Constitution Commander Tyrone G. Martin (Ret). Larry also scoured the log books from that period as well. Our kit has been deemed the most accurate representation of that period by the USS Constitution Museum. I also agree with Jose Gonzales about the lower sails being put up out of the way in battle. Best regards, Nic
  15. Hi, Unfortunately, Charlie passed away in Oct of '20 - Make the deck to fit the boat, or possibly the base of the stern is thicker than the top? Nic
