Old Collingwood
  1. Evening all, so work on this has started again, - started by painting some of the small item like vents, then the next thing to be built was the front coning tower look out mast and legs - very fiddly and akward to get them lined up, after an hour or so I gave it a coat of paint and a bit of wash to show the windows. OC.
  2. First things first - I will have some bits to still fit to her - like the forward coning tower/look out bridge, and the forward 15in mounts, no need for me to worry about x and y turrets as they were blown off by the explosion on the rear deck, and I will be only showing the rear hull with only half of the open barbette for y turret showing as she looses the stern end first. OC.
  3. Thanks Mark, will be an interesting experience and another learning curve. OC.
  4. Here's a question - is the best way to do it - to place both hull parts in (say a plastic tub being used for the water mix) then pour the mix in and around both hull parts - then when set, cut away the plastic tub and then place the sea/hull parts on to the base I want to use, will the resin sea part be tough enough to keep the hull parts in place till I place them on the base? OC.
  5. Thanks Ken, will deffo make sure what ever I use is strong and/or water tight. OC.
  6. Thank you kindly Alan, I would imagine a plastic square container would be fine. OC.
  7. In the Uk there is a Hard Core group of Mill plane spotters with a sole interest in F15 Eagles they are called The Grim Reapers. OC.
  8. I so loved these Resin Water's I have a jar I have been using on my Waterloo build (Pond) etc. and seen online how you make a frame and poor your mixture in then when part set oyu place or push in your hull/s. OC.
  9. Thank you Alan, I have never done a sea scape in my life - but I think it will be different - I was thinking of constructing a wooden base but not cover the whole area of it with water - just use the water in the centre and and around both hull parts - putting focus on them that way. OC.
  10. This is the kind of dio I could do - Imagine the main forward section going back just behind the rear most funnel, and sticking up out of the water at this kind of angle - and with the stern going down fast with just this amount showing - with a wake of water between them with wreckage and floating bits on the water. OC.
  11. I have been reading as much info regarding her fatal encounter with Bismarck, and the nature of her destruction and blowing apart, and its kind of made me curious about possibly destroying her and turning her into a Two element as she was when she was blown up - with both the forcastle-mid ship and rear quarter sticking out of a dio of a small area of sea. As a kid I used to make Airfix ships then set fire to them on my old pond and watch them burn (weird) but this destruction would be a different thing. Just an idea going round in my head at the moment. OC.
  12. Hi all, I had another quick look over my kit earlier and think its savable, It wont be 100% as good as it could be - but think when I get back on it I might be able to make it reasonable. I had even considered making it part damaged as she was from her first hits from Bismarck before her fatal blow - she received a shell on her aft boat deck that caused ammo locker fires - but think that might be beyond my skills. I will have to have a think.........Stay Tuned..... OC.
  13. Evening all, more progress - I decided to make Three French men, and Three wondead - they had been made before and just need painting, so my normal routine - primer brushed on, then a basic face/hands coat then hair/facial hair then a wash and soe detail painting. OC.
  14. This is what I call a dio .............😲 OC. http://bennosfiguresforum.com/viewtopic.php?f=78&t=23430
  15. Thank you kindly Mark for saying that, I am sure as more and more is added it will reveal itself to tell a story. OC.
  16. Thank you kindly Alan, indeed my heart is in my mouth every time I move it on to the table. OC.
