Old Collingwood
  1. Thank you kindly Edward, I think my restraints now are governed by how much physical space I have. OC.
  2. Its like a Two man job just to handle those - impressive work mate. OC.
  3. Evening all, I was able to get the dio on my table - then glued down the 2nd KGL attacking from the front entrance, I also de-based some of my French and placed them attacking from the roadside and also in the Orchard - still plenty more to come yet. OC.
  4. If the hanger supperstructure is loose - try some Super Glue (Gel type) apply it to the bottom edges of the hanger using a pin or tooth pick type thing, then place back down but use some clamps or something to make it meet all the way round. OC.
  5. Evening all, a we bit more progress today, I cut the bases from the 2nd KGL that I had made earlier, these will be glued inplace tomorrow, I also took another pic of the resin 5th KGL wounded, they are slightly larger scale than my plastic ones not massivley so but you can see the difference, so what I think I will do is to display them on another section of the farm (like the kitchen garden) and keep them slightly distanced from the ohers so the scale wont be that noticable. OC.
  6. And to add to what Ken has said do you think it would conform with glue under it and pressure? as I know of an excellent glue that cleans up real well but is super strong. OC.
  7. That was my initial thoughts - how to get a natural look - so I bent some of the legs using the hair dryer and brute force, and messed around with their arms etc. OC.
  8. Evening all, my little pile up is finished apart from an airbrush flat coat to protect it. OC.
  9. Thank you kindly Mark, quite intricate work to do - just a case of uisng my fine brushes and going carefully between them. OC.
  10. Evening all, bit more work done to my pile - vests and trousers done. OC.
  11. Im so loving the decking also - really makes everything Pop. OC.
  12. Thank you Jack, thats just what I have seen some artists do using a stick with a soft end, will have to suss that one out. OC.
  13. I will try that Phil, thank you for coming up with some ideas. OC.
