juzek
Everything posted by juzek
  1. Everything perfect! super work. He is congratulating. How many nails did you stick?
  2. You're my role model . Fantastic
  3. Thanks albert, dvm27, fmartins. Oil is employed at the end. Dye - oil - wipe with a cloth. Good luck.
  4. Good morning Thank you J.P , druxey and fmartins I use dye teak and rosewood and then linseed oil. Such small models need to use veneer rather than slats. Anchor made of tin It was a small accident Everything is ok .
  5. Thansk Mike K. , mtaylor, albert, Oligator, Jeronimo, WackoWolf! It is very nice for me. Thank you that you appreciate my work. Hi Mike, ​In my scale (1:27) everything is easier and any mistake could easy fix. So far everything is pretty OK with plan, but sometimes I found small inaccuracies.This is my first model built this technique. I'm still learining.
  6. Fantastic . Precision super !
  7. I thank fmartins , mirek , albert Slowly ahead
  8. I thank Mirabell61 , albert , druxey . Everything already in the shipyard . Much work was . Now time off
  9. Slowly ahead. I thank Paweł , fmartins and druxey
  10. Fine work . He is congratulating .
  11. Continuation . I thank Pawel and biltut Without glue .
  12. Super the precision and the ideal job. Applause.
  13. I thank RichardG , michaelpsutton2 , albert I understand allanyed Plans Ancre they are explaining as Chisel .
  14. He thanks for the interest . allanyed , I don't understandYour question , google translator wrong translates
