Everything posted by juzek
ancre La Salamandre by tadheus - 1:24
juzek replied to tadheus's topic in - Build logs for subjects built 1751 - 1800
Everything perfect! super work. He is congratulating. How many nails did you stick? -
Super Paweł , super . -
HMS Naiad 1797 by albert - FINISHED - 1/48
juzek replied to albert's topic in - Build logs for subjects built 1751 - 1800
You're my role model . Fantastic -
Thanks albert, dvm27, fmartins. Oil is employed at the end. Dye - oil - wipe with a cloth. Good luck.
Good morning Thank you J.P , druxey and fmartins I use dye teak and rosewood and then linseed oil. Such small models need to use veneer rather than slats. Anchor made of tin It was a small accident Everything is ok .
Nice work. I like it very much . Congratulates .
- 2,625 replies
- kaiser wilhelm der grosse
- passenger steamer
ancre Le Fleuron by juzek - 1:27
juzek replied to juzek's topic in - Build logs for subjects built 1501 - 1750
Thansk Mike K. , mtaylor, albert, Oligator, Jeronimo, WackoWolf! It is very nice for me. Thank you that you appreciate my work. Hi Mike, In my scale (1:27) everything is easier and any mistake could easy fix. So far everything is pretty OK with plan, but sometimes I found small inaccuracies.This is my first model built this technique. I'm still learining. -
Fantastic . Precision super ! -
I thank Mirabell61 , albert , druxey . Everything already in the shipyard . Much work was . Now time off -
Fine work . He is congratulating . -
Super the precision and the ideal job. Applause.
I thank RichardG , michaelpsutton2 , albert I understand allanyed Plans Ancre they are explaining as Chisel . -
He thanks for the interest . allanyed , I don't understandYour question , google translator wrong translates -
