RadMan
  • Gender
  • Location
    Abu Dhabi United Arab Emirates
Contact Methods
  • Skype
    radmanbg
1,091 profile views
  1. I have the same issue on my Constitution. The two sides just don't perfectly match to our exacting standards.
  2. Next on to the decks. I plan to use the same method as others here. Deck is sprayed with black paint, then I sprayed a light coat of tan, next the individual deck boards will painted randomly with one of three shades of tan (tan; tan with a drop of black paint; tan with a drop of white or brown paint). Once that is done, I will scored the deck to bring out the black underneath. I know others have done this painting by hand, but I am just a bit to shaky, so I will tape it off. Brings back nightmares for taping the hull but there isn't much curvature so seems much easier. Perhaps won't take me seven years.
  3. Well, one big problem I had was removing all the tape from the ship after laying around mothballed for 7-years. You can see the pink tape in the previous photos. I have some very bad tape residue to remove. I got it all off except in one place by the stern. The tape residue on the side I was able to get off but the residue on the stern just won't come out. I tried removing residue with new tape, dish soap and rag, olive oil, and finally windex. The combination of using new tape and then windex for the hard spots worked best.
  4. Well, after a 7-year break I have resumed work on Constitution...LOL, yes its true look at the dates in this log. I think my idea to shade the hull varying shades of copper was interesting in principal, but the shear enormity of the task and the relative little difference it makes overall was wasted effort. In any case I finally finished the hull. The photos are using light in a way to accentuate the difference in plate color, however, when looked at normally it is difficult to see much variation at all.
  5. mulwee, sorry to hear you also have 32.5 cannons, though, I now must admit that I have found the other 1/2 cannon.... I have no idea where it was in the kit but must have come loose and then got caught on some other black piece in the kit...trust me, I looked hard and never saw it. In any case, lambsbk came to my rescue by sending me some nice replacement cannons. As a side note, I am still working on the ship but have spent some months away from home and just now really getting back on it.
  6. I agree with all the comments regarding balance between the amount of detail and amount of time spent on the detail. So far, I have been spending lots of hours on the smallest details. The gun deck in particular is a bit of a dilemma. I will probably spent many hours doing the "AndyMech" method of deck detailing which nobody will be able to see...I have thought more than once that I could probably just put it in "as-is" and nobody would even notice (of course I won't do that). The way I am justifying the gun deck detailing is that it will be my practice for the spar deck which will be much more visable. Relating to the photo, I haven't done it yet, but when I do, I will let you know how. The detail will vary depending upon your printer and type of paper used. Also, you mentioned a "bit mapped" photo...don't start with a bit map, use tiff or jpeg. I may experiment a bit this weekend on it.
  7. Dave, nice job. I expected the exterior hull to look much worse after the drill-thru and putty. You really have to zoom the photos to even see the putty. Maybe I'll do it... I am just so enamored with my spray paint job on my exterior(LOL)... well, I will decide when I get to this step. I have some time. I am 60% done with the hull paint and still have the decks to do, so it will be a while before I must decide. However, I am really impressed with the detail for this part of the build, and I think I will try something similar.
  8. I really like the detail on the copper hull plating... it's probably the best wash technique I have seen. It almost looks like a dry brushing of black paint. I would be interested to know more on the technique you used.
  9. Hey Verne, I just found your blog. It looks like things are coming together nicely. I am enjoying all the true-to-life history of construction that I have learned since joining this forum. Though it makes perfect sense that the knees are made from the bottom of the tree and roots, I would have never guessed that. People really knew what they were doing back then when it came to building ships...I wonder today if we could even find trees mature enough to make the build. In any case, i will be following your progress. Welcome to MSW.
  10. I would be interested to see some photos of the exterior hull where you did the patch with the modeler's putty.
  11. Thanks for the info! I feel a little better now that I don't have to deal with the curvature, however, there is still the issue of warpage. I have two ideas, the first is to run hot water of the pieces and gently bend back to the intended shape, or the second would be just to ignore it and let the glue take care of it when I cement the spar deck down (though this won't help with my warped gun deck bow piece because according to the Revell directions, you don't glue this anyway). For the gun deck, I thought about just cementing some type of block or spacer to keep the bow piece from floating up (the warpage seemed to pull the bow up too high when I dry fitted it). Dave, and Force9, thanks for the clarification on the camber.
  12. I like the idea of the barrels for deck clutter, did you fabricate the barrels or purchase them somewhere? If purchased, from where?
  13. ARGH! THE DECKS ARE WARPED! Regarding the Spar deck. I started to prep the Spar deck for eventual painting (btw..I am still only 40% done on the hull plates). I noticed that the Spar deck pieces are warped and/or have a curvature to them. I realize that they shouldn't have any warpage, but the curvature almost looks intended. I also had some issues with the bow piece of the gun deck. If anyone knows a good way to straighten these decks, I would appreciate your wisdom. Here is a photo of the warped aft Spar deck: Below is a photo of the Spar bow piece with a slight curvature to it. All the Spar deck pieces have this curvature which is why I am asking if they should be flat or not.
  14. I am enjoying the progress on your gun lashings. I am also not happy with the Revell attachments for the breeching to the bulwark. In fact, when I was first trimming plastic for the hull, I almost trimmed them off as injection marks. They are suppose to have a small crack in the post where you insert the line, but most of mine are completely fused due to bad injection quality. I don't know how you were able to safety drill into the hull and mount eyebolts. The bulwark is maybe 1-2 mm thick, and I think it would be really easy to drill through the hull and if the hole wasn't deep enough, the eye bolts wouldn't stay firmly fastened. So, great work! I am considering doing this now. I just need to make my shopping list of things to get. Did you say you had a source for where to buy small brass eyebolts? Also, are you painting the underside of the spar deck (ceiling to the gun deck) white??
  15. Dave, a great idea for prepping the deck for gluing, especially the jig, I would never have thought of that. In the back of my mind I've been wondering how I would glue the cannons to the deck after putting primer, black, and tan deck paint on... there is no plastic for the glue to stick. It is an excellent idea, I might just buy myself a dremel when I take a vacation in the states in Nov.
