Everything posted by Kevin
the build slowly gets bigger, and with a combination of planning what needs to be painted and what will be removed at a later date, im quite pleased with it the tie bars on the stbd side are waiting for the frames to be put into place, then it will all be repainted
- 83 replies
- marcle models
- card
i will try and get some better photo's, the ones above make it look far worse than it is, and the flash has washed to colour of the frames out, i am thoroughly enjoying this, i love the scale, and have a big build that is manageable in what will be 3 sections
- 83 replies
- marcle models
- card
as it go together, i is surprising just how rigid she is getting, apart from the frames that support the tween deck cargo hold, they are tending to get in the way
- 83 replies
- marcle models
- card
coming along a treat my friend, back to the (off track comments), i seriously believe thats part of the build log, any comments that are constructive and provide info to someone who wasnt aware of it, is all part of the great learning curve of our hobby
Good evening everyone, from a wet and cool somerset after a few weeks of nice warm tempretures progress on the build is going ok, in fact it looks better than the phots show it, time to start putting the frames in, the transverse girders are attached to this at the point where the frame changes angle all the port side one will go in , as this side will be fully plated on the outside, im not sure about how to complete the stbd side, as i want that opened up to view the insides some of the frames are not yet glued in so look a bit squiffy
- 83 replies
- marcle models
- card
TY for the replies, so if i went matt black i dont think i would be hung then, i do remember all the internal free flood compartments of warships and submarines being a thick black, so thats what i am tending to go with, plus it breaks up the build into defined areas, lol then i will go and cover it all over with hull plating
- 83 replies
- marcle models
- card
Lol what instructions, just lots of sheets saying where it all go,
- 83 replies
- marcle models
- card
- 83 replies
- marcle models
- card
as with the middle section, as the tie bars go in, everything stars to be pulled into place Middle section photo
- 83 replies
- marcle models
- card
the most amazing thing that i found with my Bismarck build was that i actually finished it, lol i wish i did smaller scales and kept it simple, but even my card build of the SD-14 has got a mind of its own and taking me in a direction that will test my stamina to complete, any way thank you for the kind words, and - i still think it looks better than mine lol
Good evening everyone I many options on how to display this build, but to do any of them i need to get it built, my preferred option at present is to display it in a cutaway format, so everything inside needs to be finished as per the real thing Grey primer from rattle can the bulkheads are in Red Ochre main box girders going in, the loose ended strips will slowly be tied in as the build progress, so i will avoid painting them for now as they indicate frame numbers
- 83 replies
- marcle models
- card
I think a 1/72 crew on a 1/70 scale would not be to out of place, lol but a bit like putting a 6' sailor on a submarine
- 83 replies
- marcle models
- card
wow well that throws the cat amongst the chickens, i love the idea but that means one seven foot hull, my mind is now ticking over on how to achieve that in 3 sections = im open to ideas everyone and thank you again for posting photos John
- 83 replies
- marcle models
- card
Thank you John, that opens many opportunities for a diorama
- 83 replies
- marcle models
- card
thank you John, very much appreciated, would she have had different material in separate holds or all the same
- 83 replies
- marcle models
- card
I need to find out how the insides of the cargo holds were lined, were they lines with stell on both sides of the frames or lined with wood on the inside, reason for asking, is the diorama setting where the internals will be exposed, lol life would be so much simpler, if i just stuck to OOB 1/350 kits
- 83 replies
- marcle models
- card
good evening all the admiral is enjoying me being in the house working, very strange. and so the build continues, and now number one cargo hold is defined by the watertight bulkhead going in this is made up by a port and stbd side being scored either side to form the correct shape, a bracing bar then helps keep the correct shape, and two pillers ans a beam keep everything in the correct place, i am at present securing it the the deck, and lining everything up
- 83 replies
- marcle models
- card
good evening my friend the build is still there, and tonight i took her out of storage, - my original kit of this build went to landfill, this one is going to be completed, the link is now in my signature strip
- 83 replies
- marcle models
- card
Not my photo it seams there are not two ships the same, each one has been adapted over time to serve a purpose
- 83 replies
- marcle models
- card
Thank you for the comments and likes well the tank top plating was completed the forward plate gets put on slightly later, when i have ensured everything is lined up and fixed into position these are the bow frames which support the forepeak now is the right time to let everything dry so tht i can be quite confident that everything is in the right place
- 83 replies
- marcle models
- card
i started this a few weeks ago, as an attempt to get some modelling done during the week, as since start my new job 18 months ago i just seam to run out of time in the evenings, and is not an attempt to see how many large scale builds i can have going on at the same time. i love my boat building but only doing it Saturdays and Sundays plus other domestic jobs around our home, i find quite sole destroying, as i am not able to get into a flow, this is something i can do indoor, with a minimum of mess and be indoors with the wife and doggie this is how the set arrives to prevent any warping when being painted, i have treated all the card with a PVA (modge podge) coating, hence the streaky finish seen in some photos The SD-14 is a double bottom hull, so of course that is where we start proving some straight lines are used on the work top, it is a lot easier to keep the centre line straight, are there is no keep to do it for me Double bottom longitudinal going in and the frames these are ten tied in with the tank top longitudinal s going in the centre line deck in temp position as it suggest you work from outside to the middle where i am as of tonight
- 83 replies
- marcle models
- card
Good evening everyone this is going to be my build log for the forward section of this kit, i have another for the midships section On a previous attempt to build this, we had a disaster, which resulted in the whols lot going to land fill, even though it was only fractionally completed, but I vowed to attempt again in the future To be worked on alongside the Victory and my HMS Fife build intentions are to build as 3 static displays with weathering, and led lighting The sheets 180 of them are well printed and the instructions are very clear,, here are a few photos as she arrived today, having been ordered yesterday from Model Dockyard mtaylor, Omega1234, justsayrow and 12 others like this Quote Edit Post Actions Please click on photo for a better image All the best Kevin
- 83 replies
- marcle models
- card
Posted September 2, 2016 (edited) Sometimes known as the replacement for the famous "Liberty" ship, the 14,000 ton SD14 general cargo ships are found under many different names and flags in most of the world's ports and all of the high seas. The designation "SD14" denotes "Shelter Deck 14,000 tons". The shelter deck is the second or tween deck in the cargo spaces and, when the ship is loaded down to her plimsoll line, she displaces 14,000 tons. By the mid 1960s, there remained some 700 Liberty and other war-built cargo ships still trading. Even the youngest were 20 years old and the question of a replacement was exercising the minds of ship owners and builders around the world. the emergence of bulk carriers and container ships pointed to the end of the "shelter Deck" design which had been used with little alteration since the turn of the century. Many felt that this design was no obsolete and that the future lay with containerisation. It was, therefore, something of a surprise when ship builders all over the world unveiled their plans for the "liberty Ship Replacement", almost all of which offered a two-deck vessel of 14,000/15,000 tons deadweight. Doubtless this choice was influenced by the requirements of potential customers. Most of the war-built vessels were, by this time, being operated by Greek ship owners of limited resources to whom these new designs, for a type of vessel with which they were fully experienced and priced at about £1 million with cheap credit facilities, were very attractive. A total of 30 designs were put forward as the "Liberty Ship Replacement" in the early months of 1966. Of these, the most successful was the SD14, developed by the Sunderland shipbuilders, Austin and Pickersgill. The first SD14 keel was laid on 8th. June 1967. Unusually, this was not at Austin and Pickersgill's own yard, but nearby at that of another Sunderland shipbuilder, Bartram's, who were building the ship under licence. The first ship, named Mimis N. Papalios, was launched on 1st. December 1967. She was also very nearly the first SD14 to be completed. However, Austin and Pickersgill managed to make up the leeway in their own building programme to hand over the first completed SD14, the Nicola, on 14th. February 1968, the Mimis N. Papalios following the next day. Between 1968 and 1988, a total of 211 SD14s were completed and it is interesting to note that, by 1990, only 10 had been scrapped for commercial reasons, a further three going to the breaker's yard after marine accidents. Of the dozen vessels reported as sunk, at least two fell victim to missile attack during the Iran/Iraq conflict. Like the original Liberty ships, which many thought would be scrapped as soon as the war was over, the SD14 was not ascribed a very long life by some early critics. Nevertheless, these ships are still in demand in the charter market, with average daily rates of $5,200 for a one-year time contract, and in the second hand market with prices ranging from $2.5m for an early seventies ship to $5.75m. for a newer example. One guide to the success of the SD14 is to look at the movement of the 211 ships through the second-hand market. Most of the ships now sailing are with only their second owner, a few remaining with their original purchaser. The oldest SD14 in service is the Wave Crest, the vessel which, as the Mimis N. Papalios, missed by one day the distinction of being the first completed ship of her type. The Model In 1978, while attached to Manchester Docks, George Robinson, a retired Merchant Navy captain, hit on the idea of providing the port fire brigade with an easy-to-build model of the SD14. In this way, the trainee firemen could easily and quickly become familiar with the layout of the ship. So, originated a 2-foot long, 1:70 scale model kit of the Forward section of the SD14. This first attempt met with such success that kits if the Midships and After sections followed in 1979, the complete model measuring an imposing 7 feet in length. Professional and international recognition followed in 1982 when the model won the "Shipwrights Model Competition" at the Guildhall in London. Quite apart from sheer size, the kit is remarkable, for it is, in fact, put together in much the same way as the original was in Sunderland. Space here permits no more than a brief glimpse of what awaits the builder of this miniature leviathan. The instructions, which, for the complete kit, run to about 60 pages, first explain that the model will be built by the dry dock method rather than on the slipway - the difference is clarified. You then proceed to lay the shell bottom plates of the Forward section to form the double bottom, between the outer surface of the hull and the inner surface of the holds. On the original, the space in between in used for water ballast, necessary to keep the propellor submerged when there is no cargo and to maintain an even keel. This last expression, in such common and, I suspect , often unwitting, usage, is precisely defined. The building progresses aft as the cargo holds are each constructed with transverse watertight bulkheads, hold pillars and centre line plates. There are even properly runged ladders on which to descend to the bowels of the vessel. In the After section, as well as a cargo hold, there is the engine room together with the propellor shaft tunnel and, by lifting up the after deck house, access is provided to the steering gear flat and the rudder stock. In the bridge superstructure, containing the crew's accommodation, every cabin is accounted for. The crew's mess room, galley and smoke room are each separately delineated as are the linen locker, baggage room and officers' smoke room to mention but a few. The model also incorporates the correct ventilation trunk ways, the significance of which for cargo handling is explained. In the course of construction, the instructions are supplemented by sections which explain the actual fabrication of the original, so that, as you work through the model, you learn about the SD14, how it was assembled and how it works.The operation of such components as MacGregor hatch covers, the keelson and camber in the original are fully expounded and you can then reproduce these to scale. Step-by-step diagrams illustrate the sequence of construction. It is perhaps worth remembering that ships are machines, the largest ever built by man. So it is fascinating to see how this great machine works and to reproduce it in miniature at the same time. The correct nautical terms are used and explained, showing how each part of the ship functions and how the whole design draws on centuries of experience to produce the modern ocean-going vessel. If, like me, you have wondered what exactly is a "Tween Deck" and what is its purpose, you need wonder no more. All is revealed after which you can actually build one. The kit is printed on 184 A3 sheets of top quality manilla card, there being approximately 4,500 pieces, and the modeller can choose to paint the model with an authentic colour scheme or one of his own choice. The three sections can be fixed together or left dismantled and the aft superstructure can be removed to give a glimpse of the various deck levels inside the hull. naturally, all the cargo hatches open to show the holds. . The model can be made either for display or, with suitable waterproofing (see "Cutting Remarks" no. 3), can be sailed, there being space for R/C gear. Although the original SD14 models were all sold out about 10 years ago, Marcle Models, under licence from George Robinson, reissues the SD14 kit. The complete kit, weighing over 17 lbs, is supplied in 6 cartons, complete with a tool kit and costs £280 including worldwide surface mail. The three sections, Forward, Midships and After, are each available separately at £105 each. Should you decide to have a go, this, the "Non plus ultra of card (and perhaps any other type of) modelling, should keep you busy for about a year. Christopher Cooke and Thomas Pleiner, with acknowledgements to George Robinson, John Lingwood and Ships Monthly. Article first appeared in "Cutting Remarks" No. 4, September 1992.
- 83 replies
- marcle models
- card
