Kevin
MSW Social Media Moderator
Everything posted by Kevin
  1. good evening everyone well most of the foremast is complete now, brackets for navigation lights, and placing some of the blocks, along with rope ladders still to be made although temp in place for now i then run a few of the lines from the bowsprit through and im quite happy with the result next im thinking of making up the main and mizzen im getting used to just making bits, they are not always pretty netting completes the foremast top
  2. thank you i am perhaps doing more soldering than required, and i think i am getting better, the one thing about the metal work, is that its a lot stronger than traditional Evergreen (other plastic bits are available), and once i left the bare metal on the upper deck it seamed to make sense to me to follow it on through the build
  3. thank you for the comments, makes me feel much better i have always wanted to avoid sounding childish over comments made, but thats the main reason i switched to doing the Aedes Ars diorama over the charismas period, whilst i decided on actually getting on with the AV it is slightly more difficult to avoid the trolls and comments some times, being a MSW Social Media Moderator, and perhaps i over reacted, but the comments at the time went much further i have still quite a way to go on the AV, and would love to completed her now rather than switching back
  4. thank you Jason, i stopped doing it when i was slated on a FB group, comments like how i should have left it to someone who knew what they were doing etc, kind of upset me in a way, im not sure if the confidence will return, and if it does i certainly will think twice before showing others
  5. So sorry i never followed this build, she looks fantastic, well done
  6. good evening everyone the foremast continues, everytime i look at the donar build, i see something new to add, looks like rope ladders next seams like a lifetime away from getting close to this
  7. thanks James, i can see a few experienced builders redoing this, and bringing to an even higher level
  8. thank you OC i am quite happy with what i am doing, i would be over the moon, if i knew what being done was the right size
  9. good evening everyone did a bit more to the display area, including rearraigning the ring main and ,moving eclectic sockets, i just want to put a extension lead in there to power the St Nectan and any other build that might have lights fitted, and fit the windows back onto the build today, and the foremast i presume the futtock shrouds are the right name for this type of vessel the top platform on all masts has spreaders fitted, another item not mentioned in the kit, aft of the platform is what i presume to be another line guide, i have no measurements for any of this, just trying to follow another build, but if wrong, i will do again futtock shrouds
  10. are you going to cut the doors out and remake them look a bit battered, or you could weather then to get an aged look, its going to look great . because you are good at what ever you do
  11. personally i would mount the masts first, as all the standing rigging will be hampered by the spars, and then mount the yards with all the required footings and blocks
  12. hello my friend it is the Mountfleet Talisman hull P.S Talisman (mountfleetmodels.co.uk) PS Talisman (Clyde Paddler 1935) Hull: 1434mm Hull: 56 1/2 inch Beam: 7 inch Scale: 1:48
  13. good evening everyone cabinet is now up and running, however it is to reflective at present to get any decent shots, blinds are next to be sorted, hopefully i will get some decent shots then, but for now i present, next week i will start to clean them up and repair/ redo a few lines
  14. good evening everyone coming to the end of this project, hope to finish tomorrow and get the boats in Thursday i needed a set of spot lights so stole them out of the kitchen, replacing the halogen GU10 with LED dont worry the admiral can see her cakes now
  15. i had to learn to solder, it is getting better as i tend to find reasons to do it now, learnt about different temp solders and found carrs green brilliant the etch primer i should think is out of date now i hate airbrushing, hence abandoned the build, i have a decent compressor, evolution guns, and never ever got a decent result on anything
  16. good evening everyone wallpapering and pained, also got the floor in tomorrow electrics and start the shelving
  17. thank you, its actually turned out better than i thought, will get all my builds in and and room for another couple of 7 year builds
  18. good evening everyone cabinet continued today walls prepared for paper, electrics/lighting and cabinets moved architrave/ window beading being put in, and test fit of the acrylic panels, hoping this will be completely finished by this time next week, i have a build to finish and put in there with the other dust collectors the replacement acrylic panels arrived today, and i have been told to keep the other stuff
