Posts posted by Mike 41
Hi Christian,
I agree the mortar are too thick. I only have one carbide tipped blade for my Proxxon table saw and need to get a thinner one for fine detail work.
Mike
Hi Brian,
I do have a Byrnes drawplate and a Byrnes thickness sander they both work quite well.
Mike
Hi Brian,
It looks like I will be doing about the same amount of treenails that you used on your model. Your treenails look very nice I hope mine look that good.
Mike
Hi Jose,
You have chosen an interesting project. I will follow along also.
Mike
- MEDDO, mtaylor, Elmer Cornish and 1 other
- 4
- Elmer Cornish, MEDDO, tarbrush and 1 other
- 4
- tarbrush, mtaylor, Elmer Cornish and 1 other
- 4
Hi Brian,
I will treenail all the upper decks but not the lower decks that will not be seen on the finished model. Did you treenail all nine decks?
Mike
Hi Brian,
Hobbymill is an excellent source for wood. You did an amazing job for a first scratch build.
I get most of my wood from Metro Hardwoods it is close to my home and I can hand pick the boards I want to use.
Mike
Thanks Guy,
I like to take a lot of pictures.
Mike
Thanks Richard,
It looks like we are neighbors. LOL
Mike
Hi Michael,
The best attribute of the jig is being reusable. This is the fifth model I am building with it and it is still holding up well.
Mike
Hi Michael,
Thanks, if you are interested in the building jig I use take a look at this post.
http://modelshipbuilder.com/e107_plugins/forum/forum_viewtopic.php?5571
Mike
The deck ledges were installed next. Do to the type of frames I am using I couldn’t use the jig described in the practicum. I marked the beginning, end and midpoint of each ledge then marked the top of the ledge at these three points from the top of the frame with a compass and glued the ledges in place. The ledges for the lower decks are the only ones installed at this time.
- mtaylor, DORIS, Elmer Cornish and 4 others
- 7
Chuck,
I will put her on my ‘to do’ list.
- mij, Elmer Cornish and hexnut
- 3
- hexnut, Elmer Cornish, mtaylor and 1 other
- 4
HMY Fubbs 1724 by Mike 41 - Scale 1:48 - second rebuild
This set of photos shows the rest of the lower decks.
