Posts posted by Mike 41
Thanks Nils,
I think on my next model I will leave more of the planking off to show more of the internal details like the stove and great room.
Mike
Jeff has finished the drawings and is working on a building guide. He plans to finish it next month. He has been very busy on his ‘day job’ and will finish the guide as soon as he can
Mike
- Saburo, qwerty2008 and WackoWolf
- 3
- kees de mol, Mirabell61, IgorSky and 2 others
- 5
Hi Patrick,
You have an amazing amount of detail in a ship that small. I built one at 1/48 scale and had trouble with my big fingers and the small parts. You have probably noticed a lot of the details in the AOS book have the wrong scale in the description just use your best judgment as to the size of the parts.
Mike
Hi Patrick,
The Pandora is an interesting build. What is the scale and what kind of wood did you use for the framing? She is looking very good.
Mike
- tarbrush, Model Mariner and mtaylor
- 3
I have been working on the head rails. The drawing showing the lower knee made a good pattern and fit nicely. The upper knee drawing did not make a very good pattern so I divided it into three pieces using the drawing for the end pieces and used some modeling clay to form the middle section. I carefully removed the clay and traced the outline on a paper pattern after some trimming the center section fit.
- mtaylor, Archi, Mirabell61 and 2 others
- 5
Hi Brian,
Thanks I will be adding four cannons to the starboard side. I added a set of stairs where the fifth one should be that also messed up the location for the boarding stairs. I am moving them between the third and fourth cannons. One small change can affect a lot of other things.
Mike
Brian I like the way you did your frieze and will try to do mine similar to yours.
HMY Fubbs 1724 by Mike 41 - Scale 1:48 - second rebuild
The forward stays as installed.
