Posts posted by Mike 41
Hi Chuck,
Good luck with the Philadelphia 2 practice makes perfect. I am currently working on an old English boat.
Mike
Thanks Andrew,
I agree Porta was a very talented artist and died way too young. I hope you enjoy this build log.
Mike
- mtaylor, gjdale, Chuck Seiler and 4 others
- 7
- Mirabell61, Wishmaster, gjdale and 6 others
- 9
- mtaylor, Jeronimo, Wishmaster and 8 others
- 11
- Elmer Cornish, Wishmaster, mtaylor and 6 others
- 9
Hi Michael,
The Fubbs is a nice size model and has a lot interesting detail. You are welcome to watch me fumble my way through the build and decide if you want to give her a try.
Mike
Hi Brian,
I will add the masts and standing rigging per Portia’s plans also. Thanks for the link to Gene’s practicum.
Mike
- Wishmaster, mtaylor, Mirabell61 and 2 others
- 5
- Elmer Cornish, Mirabell61, mtaylor and 1 other
- 4
Hi Christian,
Thanks, if you go to the Model Ship Builder website forum the practicum is under the Older & Inactive Projects section as a free download.
Mike
Hi Guy,
Completion looks a long way off thanks for stopping by.
Mike
Hi Brian,
I am using two practicums for references Romero and Bodnar. The practicum by Gene Bodnar uses a simple straight forward approach to the framing that I liked so I started with his style. I plan on using Romero’s book for the carving and fine detail work.
You did an excellent job on your Fubbs. Did you use Portia Takakjian’s method for the hull construction? I am using a gantry type building board.
Mike
The Frames:
The frame drawing just shows one half of each frame. I scanned the drawing and traced the frames in AutoCAD mirrored the images and printed two copies of the fore frame and one of the aft. One copy of the fore frame is used for the master assembly sheet and the other for patterns. By gluing the frames back to back beveling the frames is very straightforward. By clamping each frame to the two adjacent frames and sanding the edges flush makes assemble and final sanding very easy.
The foothook style of frames consist of six pieces and are double frames with a small section of the aft frame removed. I had considered doweling the two sides of the frames together but sense all the frames are glued together it didn’t seem necessary.
This set of photos shows the frames being assembled.
Hi Klaus,
Thanks the deadwood is European Beachwood it looks like oak but has a much finer grain.
Mike
- Mirabell61, MEDDO, jeff1395 and 6 others
- 9
- Elmer Cornish, Wishmaster and mtaylor
- 3
The model is based on the drawings by Portia Takakjian and the practicums by Gene Bodnar and William Romero
I am using the single foothook method. In the single foothook method the whole frames are made up in two halves and are glued to the forward side of the floor timbers.
This my first attempt at this type of construction so don’t be surprised if you see a few do overs.
Hi Don,
It looks like you are off to a great start. I will be following your build.
Mike
HMY Fubbs 1724 by Mike 41 - Scale 1:48 - second rebuild
Thanks Brian.
