Very nice detail, Antanas. Well done on the transome. Just another extra challenge ... you encountered
Carl
Thanks Carl.
   After the some delay the build is continued. The Master Korabel recommended for the pins use the brass wire. But I decided to make the wood pins. Used the toothpicks and drawings from my another model. But slightly reduce the size. As lathe used the Proxxon drill and stand. The file was turning tool. Turned, sanded and placed in the pin rails holes.
   The next step - anchor riding bitts. At the first sanded and slightly improved the look. And from steel pins made the square-head nails. Placed the nails on the standard and cross beams.
Regards,  Antanas
Always can be done better, always can be done more!
My builds:
          1.  75 mm Boat  - Master Korabel;
          2.  95 mm Boat  - Master Korabel;
          3.  Double boat  - Master Korabel;
Very nice detail on those squared nailheads. You are a blacksmith too I see ...
Carl
beautiful build Antanas,
you`ve done a very nice clean Job with the hull and deck.....
I`m also delighted of this kit and it`s good Quality, the laser pre cut Planks are just wonderfull and precise in shape...
This is going to be a real gem
Nils
Current builds
-Lightship Elbe 1
Completed
Carl, You are right.  But this is a big secret...  :D
Thank You Nils. Laser pre cut planks are good. You are right. But my hands not so good. I make too many mistakes.  :) But I believe the next time will be better.
Best regards  Antanas
My builds:
Antanas,
Every next time will be better ... it is a rule in general!!
Carl
Hello all!
  Some weeks I not worked on my model. Migrated from my old Windows XP notebook to iMac. It was not easy... But I do it and have some free time for my models!
At first make the holes for anchors rope. Painted the hole in black. But the most difficult place was the main plank-sheer. He was broken four o six times. But successfully glued in the place... When added the knees the situation will become much better.  Part of the plank-sheer painted in black using the ink.
Regards  Antanas
My builds:
   Now time for the swivel guns pedestals. Sanded to get the normal wood look. Every pedestal are individually adapted to its place. Then drilled the holes in the pedestals ends and glued to its places.
  Add the last two cleats and steel rings.
  The U shape mounts for the swivel guns are made from brass. They are simple photo etched parts and need the some sanding too. The details are small and I used the my magnifying glass. Before bending I anneal the brass parts, because  during the bending process they can break. Then the parts are chemically blackening.
  And finally from steel pins made the U shaped mounts axis. That's all at this time.
Regards  Antanas
My builds:
   The double boat was the first kit of the Master Korabel. And they use the Amati swivel guns. The quality of the swivel guns are bad. The bores seems very bad. But I do not want to change them. I think that this should be done only at the last resort. Otherwise, it would then model from a kit?
  I'll try to change the look of the swivel guns. At the first make the barrels more short. About 0,3 mm. Then repair the bore using the conical mill. Now the bore have correct shape. And corrected the trunnion shape. Rounded them and reduced the length. And blackening bores and trunnions. Now they looks much better.
  The next step is to add the handles to the swivel guns. I make them from the copper wire using the gas torch.  Make the beads at the wire ends.
Regards  Antanas
My builds:
Antanas,
The beads at the end, are those molten copper, or solder?
Carl
Hi Carl. The molten copper. Some years ago I try to make from the solder, but the result not satisfied me.
Regards  Antanas
My builds:
Thanks Antanas,
I'll have to give that one a try. It will probably turn out in burning copper wire
Carl
Carl, please the one end of the copper wire near the torch flame. The copper will begin to melt and will go to a ball. The diameter of the ball will depend on the storage time in the flame and wire thickness.
Regards   Antanas
My builds:
   The next - the rudder. Sanding the details to remove the dark surface. The rudder blank has been processed so as to more correspond to the actual rudder.
   To the kit brass parts added 4 brass tubes.Tubes soldered to brass parts. But before the brass strips shape are changed. For this I use the 1,8 mm diameter drill.
   The bras parts are chemically blackened. The tiller painted using the black ink. And everything installed into place.
  Regards   Antanas
My builds:
   Small update. The hatches looks not very well. So, I added the rings. Now they looks better.
   Improved the look of the chain plates. They are made from brass. But photo etched parts are not have very hight quality. The files and sandpaper help me.
   And mounted deadeyes.
   From brass sheet made the swivel gun pedestals fittings.
  Regards  Antanas
My builds:
   All jobs on the hull are done and now time to oil. I use the carnauba and candelilla wax based breathable tung oil. It dries within 24 hours, full polymerization time about 6 month. I place 2 layers of the oil. Now leave to dry for a week.
   Regards   Antanas
My builds:
Outstanding building Antanas :)
I've found your build log only today and have read everything with lot of interest. Definitely not an beginners-looking kit, mainly thanks to your improvements!
Fam
Joint building:
   Brick de 24, 1/48, jointly with Jack Aubrey (POB from Ancre plans)
Works in progress:
   USS Constitution Cross Section, 1:93 (POF bashed from Mamoli kit)
Completed models:
   Santìsima Trinidad, 1/90 (POB heavily modified DeAgostini kit)
   Genoan Pinco, 1/50 (POB bashed from Euromodel plans - my current avatar)
   Viking Knarr, 1/72 (POF from Dusek kit)
Thank You Fam. I add only minimum improvements. And this can do any builder, I'll think. Master Korabel recommended this kit as the first model for beginners.
Regards  Antanas
My builds:
Small update. The anchors and oars holders. The each anchor are soldered from two photo etched parts. The material is brass. Chemically blackened. Rings coiled rope, then painted in black. Stubble removed using a burner. The oars holders from steel pins.
   Regards  Antanas
My builds:
